this is such good news...
now where to find a conroe...
Quit thread crapping guys. This aint a "where did you buy your conroe?" thread :stick:
E6600 ES Stepping 5
P5WDH no mods
2 x 512mb XMS2 Pro CA3
hi end pump with low profile water block :(
Cpu @ 1.62v
NB @ 1.65v
bios 0602
room temp @ 25C
http://img301.imageshack.us/img301/9...391xmscpui.jpg
E6400 allendale ES with 4Mo L2 ( stepping 1)
Noctua NH 12 + 120 mm paspst
asus P5W DH bios 0065
2Gigs Gskill 6400
Vcore 1.4v
Vfsb 1.5 v
Vmch 1.65 v
http://img301.imageshack.us/img301/8436/snap1eo0.jpg
can boot@400 mhz but not stable with benchs and multi is locked at x8 :(
Unless I missed the markers there needs to be a seperate section or identifier for ES chips. We all know the retail won't perform like the ES and it's just going to be confusing.
How many E6300-E6700 retails have been posted at XS? Answer: 1Quote:
Originally Posted by Sanborn
I think 1 result is too little to judge. If you remember not all X6800 ES did well. Why do you think you see more lower end models? Nearly all of them have performed well.
Hi everybody,
This is my first post in XS so I felt like I need to start here first of all. I would like to be listed in the list above and join your community more active.
First of all the used system:
CPU: Intel Core 2 Duo E6300
Cooling: Scythe Ninja PLUS
Mainboard: Asus P5W DH Deluxe (0078 BIOS)
RAM: Corsair TWIN2X1024A-6400 - 2x512MB DDR2-800
VGA Card: Sparkle Geforce 7900GT
PSU: Scythe Stealth Power 450W Semi-Fanless
Now some screeners
http://www.pcmasters.de/forum_pix/bo...z-3h-prime.jpg
http://www.pcmasters.de/forum_pix/bo...hz-superpi.jpg
http://www.pcmasters.de/forum_pix/bo...z-3dmark01.jpg
I hope you are ok with my results and accept to add me to the list. If not let me know since I can bench again.
3.1Ghz were sort of unstable but I'll work it out soon (hopefully).
Greetings,
Bolef2k
nice results !
:welcome:
E6600 @ 1.65vcore
P5WDH stock, fan on NB
Kingston Hyper X PC2-7200, 2x512mb
X1800XT 256mb
Vapochill LS
4102mhz
http://valid.x86-secret.com/show_oc.php?id=109025
Super PI 1M
http://star.walagata.com/w/fetuskiller/12.531.gif
Hi epox4life,
ncie one. How about showing some temps?!?!? I would like to see those. I'm going to purchase such a tool soon to kick ass my 955EE ES.
Greets,
Bolef2k
CPU temp around -25C
NB temp 36C
have you test your CPU in AIR ? or water ?Quote:
Originally Posted by epox4life
max stable on air is ? on water ? with vcore at ?
thanks
CPU temp around -25C , water :p: ? nah this is phase change.Quote:
Originally Posted by damsxx
E6600 stepping 6 b2 spoiler allert from aspire @ holland :slobber:
http://www.vanderblom.nl/stefan/conr...963_resize.JPG
http://www.vanderblom.nl/stefan/conr...965_resize.JPG
http://www.vanderblom.nl/stefan/conr...966_resize.JPG
http://www.vanderblom.nl/stefan/conr...967_resize.JPG
http://www.vanderblom.nl/stefan/conr...968_resize.JPG
http://www.vanderblom.nl/stefan/conr...973_resize.JPG
http://www.vanderblom.nl/stefan/conr...974_resize.JPG
Duel prime stable 3.94 Ghz 1.55v in bios,
http://img283.imageshack.us/img283/3...vinbiosya2.jpg
E6300 (OEM from TD) on a GA-965P-DS3, Scythe Mine HSF w/ AS5, 2x1 GB OCZ El Gold running at 5-5-5-15 800 MHz
Stock voltage on everything but the ram (2.0 volts, which is what its specced at):
http://img513.imageshack.us/img513/4...ourssp6.th.jpg
Intel C2D E6400 Step 5 @ 3.4Ghz [Watercooled]
Gigabyte GA-965P-DS3 [PCIe @ 100Mhz | VCore @ 1.325v | VDimm @ 2.2v]
2x1GB G.Skill F2-6400U GBHZ
http://people.freenet.de/chris070719...00/Prime-5.jpg
EDIT: UPDATE
Intel C2D E6400 Step 5 @ 3.52Ghz (1.36v Load) [Watercooled]
Gigabyte GA-965P-DS3 [PCIe @ 100Mhz | VCore @ 1.40v | VDimm @ 2.2v]
http://people.freenet.de/chris070719...00/Prime-6.jpg
nice overclocks. couple questions though. why not super pi 32m test??? also arent you suppose to run dual super pi to load boath cores?
Prime 95 is much, much harder to run than simple 32m.Quote:
Originally Posted by dziuggy
E6300 @ 7x487 = 3.4Ghz 1.45V dual SP 32M stable | Air Big Typhoon| Gigabyte GA-965P-DS3 F4a bios| Corsair PC8000UL | FSP Epsilon 700W PSU
http://img220.imageshack.us/img220/1784/32m3400ma8.jpg
for dual 32M i can set the VCore to 1.35v in Bios and it run stable! But it is notQuote:
Primestable!!
Gotheb1ues - E6400 Retail 3600 MHz Pi 32M Stable (1.55v) | Low end water | Gigabyte DQ6 Bios: F3d | 6400HZ 2.1v
http://img152.imageshack.us/img152/8...mstableda6.jpg
E6400 @ 3312 mhz on Gigabyte DS3 bios F4c, Big Typhoon air cooling, 1.475 Vcore. Dual prime stable 1 hour.
http://img146.imageshack.us/img146/1992/stable1up7.jpg
http://img464.imageshack.us/img464/5282/primext3.jpg
6300 oem + bad axe 304 bios mod + balistix 5300 @ 4-4-4-8 + alphacool nexxos XP
SWEET :D
6300 at 3.5 - 1.376 Volts
DS4 F2 Bios: G.Skill 2GB DDR2 HZ-Micron 1:1 500 FSB
Water cooled
12 Hour Dual Prime Stable Test
Test running for 30 mins
http://www.theasgard.demon.co.uk/prime30mins.JPG
Test Complete
http://www.theasgard.demon.co.uk/12hourfinish.JPG
I have more snapshots through the 12 hour test if required
wow ! nice chip :eek:Quote:
Originally Posted by The Asgard
