Congrat for b-day and WR :D
Happy B-day kyosen.......Way to go.......:D
Congrats on the special day and the WR - sensational bench!
Still dryice-cooling:)
...yes I know that stepping 5 E6700 & X6800 are awesome, but I got 4M sub 1min. at first;)
32M: 10m50.485s @4605.6MHz ...New WR
http://222.151.145.37/c-board/file/1..._4605.6_C3.png
8M: 2m13.297s @4701.3MHz ...New WR
http://222.151.145.37/c-board/file/2..._4701.3_C3.png
4M: 59.797s @4683.3MHz ...New WR
http://222.151.145.37/c-board/file/5..._4683.3_C3.png
2M: 25.860s @4701.1MHz
http://222.151.145.37/c-board/file/2..._4701.1_C3.png
1M: 10.688s @4701.1MHz
http://222.151.145.37/c-board/file/1..._4701.1_C3.png
My rig:
http://222.151.145.37/c-board/file/2...ce-cooling.jpg
And several answers for your questions:
bachus_anonym> They are very comparable to what I get with 6400C3 on AM2 - 32M @ 450Mhz 8-3-3-3.0 and 1M @ 460Mhz 8-3-3-3.0 with 2.5v...
Your information was very helpful for purchasing 6400C3, many thanks!!!
eva2000> what's that block in between the chipset block and the video card ???
sierra_bound> I think that's a CPU block that's attached to the loop. He probably just took the watercooling set-up from an old system. I believe his notes say it's a Socket 754 block!
sierra_bound said all:)
Celeron Gamer> how do you make that temp sensor, anyone got the schematics/blueprints/whatever on how to make on of those?
OMEGA3> It is thermometer kit sold by the "Akizuki denshi" of Akihabara.
Thank you OMEGA3, OMEGA-san...BTW, pronunciation of '3' is 'san' in Japanese:)
Yes, my thermometer is same as OMEGA3's.
rick_fx> will we see under 10 minutes SPI 32m with conroe soon?
X6800 B1 will arrive here in Japan in this week or so.
I did not order it this time...I hope other japanese OCers will break 10min;)
ZX7891> how much does water cooling the chipset on the P5W help?
Difference was ~8MHz in my case.
In same condition (Corsair XMS2-5400UL, Vdimm=2.42V, Vmch=1.90V) except chipset cooling,
by air -> 472MHz
by water -> 480MHz
Edit: IP address maintenance
Congratulations on becoming the first to break one minute barrier in 4M. :toast:
And you did it with less than 4.7GHz. ;)
Gratsz sub 1 min 4M
This super pi race is getting sickening :)
I'd like to give a special thanks to kyosen-san for taking the time to anser many questions :) As a "top" clocker, I'm sure he could find many other things to do ;)
Awesome job kyosen!
:toast:
how much vmch are you giving it?
Thank you everyone:)
Waus-mod> how much vmch are you giving it?
Vmch=1.95V;)
Great.. you still have room then in the vmch
How high could you go with the standard 1.65vmch?
Waus-mod>How high could you go with the standard 1.65vmch?
Scaling Vmch/Max FSB under water-cooled north with Corsair 5400UL.
Here 'Max FSB' is limitation of SuperPI-mod 1M complete run.
Vmch : Max FSB
1.56 : 419.4
1.60 : 431.3
1.65 : 446.8
1.70 : 460.5
1.75 : 470.1
1.80 : 474.8
1.85 : 477.8
1.90 : 480.8
1.95 : 482.0
water on chipset help a little?
As already mentioned above, 472(air) -> 480(water) in my one case.Quote:
Originally Posted by d@rkn1ko
I don't know how do you feel ~8MHz difference, but at least for me,
It's beneficial;)
Just what I was going to say...very nice bday present...truely a nice job. :toast:Quote:
Originally Posted by realsmasher
oh sorry :) thx :toast:Quote:
Originally Posted by kyosen
Awesome kyosen-san, respect. :toast:
:woot:
Incredible 32M action!!
simply awesome :slobber: :clap: :slobber:
Amazing results:slobber: :worship:
Have you planned some SPI action with X6800?
Man ur 2M beats my 1 by almost 4 secs :(
Hi Kiosen
congrats for the result...
Did the Vfsb mod helped a lot to reach 480 FSB?
Did you test the difference with and without Vfsb mod?
Can sb tell me what exactly Vmch is? voltage of NB? and what Vfsb is?
This is my max on aircooled northbridge and 1.9vmch :(
http://i72.photobucket.com/albums/i1...w5-e6600/7.jpg
nachthymnen> Have you planned some SPI action with X6800?
Yes, of course...but after official release;)
giorgioprimo> Did the Vfsb mod helped a lot to reach 480 FSB?
giorgioprimo> Did you test the difference with and without Vfsb mod?
Vfsb-mod did almost none, or very very a little.
I could reach 482FSB with Vmch=1.95V, Vfsb=1.50V...
...but I still hope that Vfsb-mod may give +1MHz FSB:)
zbogorgon> Can sb tell me what exactly Vmch is? voltage of NB? and what Vfsb is?
Vmch = Voltage of Memory Controller Hub, and MCH = North Bridge.
I think that Vfsb is FSB termination voltage...described as VTT in the Pen4 datasheet: Page22
ftp://download.intel.com/design/Pent...s/31030801.pdf
There is also VCCA as voltage relating FSB, but it seems that same voltage is supplied
to VTT and VCCA, at least for P5W-DH and D975XBX.
Waus-mod> This is my max on aircooled northbridge and 1.9vmch
Hmm...I still suspect that each Core& Core2 series CPU has its own FSB wall:(
I'd like to push my step 4 6700 to these heights, thanks for us showing it's possible kyosen. Really nice results :)
