Yes, I realized that aswell today.Quote:
Originally Posted by VictorWang
The additional layers could be for the FSB interconnects between the two cores.
No K8L is scheduled to be backwards compatible with AM2 (DDR2 memory), but will launch at the same time as AM3 (DDR3 memory)Quote:
Originally Posted by PGHammer
the added thickness of the PCB upon which that specific proc is built should not have any effect on the LGA775 socket nor any LGA775 heatsink by the looks of it.
the lga type socket is partially designed for expandibility, the pins are very spring like and are designed to be compressed, which have an envelope that can be worked with. also i think the IHS can be trimmed a wee bit to be within spec for the increased package. no new socket :|
this is finally my first post! after i registered like 2 weeks ago i never got a confirmation email but i guess one of the mods heard my cry for help a couple days ago. thanks!
as long as it will work on 975x, which you guys say it will
then i see no problem hsf, they all screw down anyways dont they
