I do not think they designed it with extreme overclocking in mind and all the voltage hack mods. If you keep it within it's design limits it will be reliable. If you are going for higher voltages on your memory (which is out of all memory specs so you cannot pin that on a mobo as the fault of memory blowing) then yes the Asus or DFI's will be more user friendly. You just haven't heard of blowing memory on them because nobody has them in mass quantities yet. Once people start running their ram way out of spec on them they too will burn out some memory, but like I said before it is not the mobos fault for you running memory with way more voltage than the memory is designed to handle.Quote:
Originally Posted by Devious
