try for max fsb plz. i hope it does higher than 500mhz :)
Nice. This would had been my motherboard of choice but it has that wierd SATA setup ... not good :(
Originally Posted by Johnny Sack
How about these?
http://www.iamxtreme.net/andre/P5B-D/1.JPG
http://www.iamxtreme.net/andre/P5B-D/2.JPG
http://www.iamxtreme.net/andre/P5B-D/3.JPG
Now does any one know what fsb these boards are capable of?
Great work Kyosen... youre a true pioneer!
good work
@kyosen: do you experience any boot problems or problems getting higher than FSB400? the Administrator of the german Forumdeluxx got a P5W-DH, too and he uses a Vapichill.
he has experienced several problems so far: not getting above 400
reboot bug at app 350mhz FSB
might this be a "Coldbug" like the AOpen had?
Nice PcCI2minial! Got one for me? :D
This board has *only* upto 450MHz FSB setting on both BIOS & Ai Booster.
My E6700ES reached MAX FSB, so x10=4.5G:)
SuperPI-mod1.5XS 1M: 11.218s
<img src="http://222.151.148.34/c-board/file/11.218s_E6700_4.5G_ST.png">
SuperPI-mod1.5XS 8M: 2m22.922s...New WR
<img src="http://222.151.148.34/c-board/file/2m22.922s_E6700_4.5G_ST.png">
AquaMark3: 223956...New WR
<img src="http://222.151.148.34/c-board/file/AM3_223956_E6700_4.5G.png">
3DMark05: 24881...New WR
<img src="http://222.151.148.34/c-board/file/3DM05_24881_E6700_4.5G.png">
And several answers for your questions:
Stelios> Kyosen , do you find this board faster than the Intel bad axe ???
At least in FSB:RAM=1:1 setting, P5W-DH is slightly faster than
D975XBX@FSB=1067mode, I think.
Nasgul> That E6700 can't do 4.0ghz on air? How about using a Tuniq Tower 120?
Sorry, I've not tried air-cooling...
Vanovich> kan you tell me if the lightspeed clamshell kan fit on/around the cpu?
What is "lightspeed clamshell" ?...I don't know it, sorry.
Waus-mod> Now does any one know what fsb these boards are capable of?
As mentioned above, it limits upto 450.
I hope that BIOS or/and ClockGen update will help it...
FischOderArl> do you experience any boot problems or problems getting higher than FSB400?
Hmm...BIOS has no Vcore and no multiplier choice for Conroe now,
so I always start FSB350...
FischOderArl> might this be a "Coldbug" like the AOpen had?
My E6700 system freeze below about -150deg-C,
and cold boot needs -140deg-C above.
-80~-90deg-C (and Vcore=1.624V) is enough for 4.5G 3D run, in my case.
And many thanks for your interests:)
Very nice Kyosen. :toast:
Now lets see some DFI action :rolleyes:
thanks alot :toast: that Board looks good :D good I preordered it :D
but you increased the Chipset Voltage for 450mhz FSB now, didn't you? would be insane if not :woot: 450mhz FSB without Mods or rising voltages :D
KYOSENQuote:
Originally Posted by kyosen
Simply the best
OMFG :eek:
allmost 25K 3dMark05, with the same cards as MM's 20k run :slobber:
Kyosen, have you a link for Bios 0401 ?
I have an Asus P5W DH Deluxe with Conroe E6600 and with my prommy (-35° CPU) impossible to have a FSB > 422MHz ??? The maximum is 9 x 442, 9 x 423 = FREEZE :(
I have modified multiplicator and 8 x 423 = Freeze...:confused:
Thank you.
Can anyone confirm one way or the other whether you can fit the Vapochill LS clamshell on the P5W DH motherboard? I guess from CornerJacks post you can fit the Prommy one...
Did you run 3D01? Can you show us pleeeease?:toast:
Hello kyosen :
http://img471.imageshack.us/img471/7...roopmod3td.jpg
Do you think so this will be safe ?
best regards
yea this is a very important factor ,for all of us with light speed .kyson thanks , heres a link to the clameshell .its nr 3 .http://www.cluboverclocker.com/revie...ages/parts.jpg.Quote:
Originally Posted by Durzel
:confused: :confused:Quote:
Originally Posted by AndreYang
now andre
thats not so totally overwhelming isn`t it ....
for most of us the intel claims of better memory performance
of the 965 chipset is the interesting question
so what about some everest memory benches of the unmodified P5B de luxe board
and don`t force Kyosen into a benchmarkbattle :) :)
:lol: you always http://www.xtremesystems.org/forums/...s/smackbum.gif other users for quoting images and now you're nothing better http://www.xtremesystems.org/forums/...ilies/slap.gif ^^Quote:
Originally Posted by mine
:D
yeah there were three
and one slipped out of my hands .....:slap:
I, too, would like to know this. Are those mods really necessary to push Conroe to 4Ghz on water with this board?
Veq(Vr value)Quote:
Originally Posted by quent
http://img395.imageshack.us/img395/9039/vdroop3dh.png
Maybe a 200k VR would be OK.
I don't know wich resistance is needed to get the Vcore stable. If somebody can test this..
kyosen, can you change the vcore in that BIOS?
Vcore options are greyed out on our board and OVP kicks in at 1.610 with hard mod :(
:rolleyes: maybe it's possible to find a OVP mod :)
kyosen, as always very helpful info and results :toast:
