look more carefully ;]
there is a jumper there ;]
but its soldered do the PCB ... just check it out ..
im sure that there is a connection between 4th leg of regulator and this "new jumper"
its large place to solder .. so its also easy ...
its the same PCB as the "new" one ..
galaxy just cuts the cost of the cards. They took away jumpers for voltage (useless any way .. 0.05 increse) and bios change. Theres also no buzzer (but i never used him and never heard a sound from it :P ) ...
