Originally Posted by t024484
Everything I have tried including FEAR is running without any problems (so far), but the last thing I would like to suggest is that Riva Tuner is always better than Coolbits. It happens to be so in my case, but the reason why is written in the stars.
I am absolutely not against any cause.
All I say is that this and similair Samsung gddr3 is used all over the world without any problems. Why should it be the cause of trouble in the 7900GT. Because of that it seems unlikely.
On the other hand, there is such a thing as a power supply that could malfunction, so far no prove of that, but it is already more likely than the Memory chips.
Next to that is the Clock generator. How well is this circuit designed, and how is the clock instructed to change the frequency, probably by the GPU, but we don't know.
A fact is that the memory is not producing its own clock, in fact the memory knows nothing about clocks although it should be clocked in the proper way. So when in an overclocking situation, like you describe, the memory gives up, is it the memory, the power supply or the clock generator. It can also be the GPU that is not able to read and write to the memory in the proper way or being not able to instruct the clock generator properly.
There are so many reasons, so without any further knowledge or hard facts, it is just guessing.
I think time will learn
