I like the addition of 8-phase power supply to P5WD2-E. That or most likely P5WDG2-WS Pro will be my conroe m/b's. :up:
After googling I found few people using Scythe Ninja with Bad Axe and it has caps also cose to socket...
I believe that it will fit.
Arg....heatpipes.
Glad to see I'm not the only one to hate this..Quote:
Originally Posted by Shpoon
I find they're just a pain in the ass. If you want watercooling, you're :banana::banana::banana::banana:ed. You'll be forced to use yet another fan. Aftermarket CPU HSF, still :banana::banana::banana::banana:ed if the fan isn't "just right"..Quote:
Originally Posted by Vric
Removing the heatpipe and replacing it with a stock cooler, next to impossible to do :/
And can you believe they usually charge more as it's part of everyone's "premium" series?
When does the new P5WD2 come out? :D
Can anyone clarify if the ASUS P5WD2-E Premium pictured here is the same revision of the board currently available at etailers like Newegg? Thanks in advance.
and when you have a BTX style case like me (Silverstone TJ06) you're :banana::banana::banana::banana:ed also. Heatpipe upside down doesn't sound like a good idea...Quote:
so Half of those board a ruled out for me.
P5WD2-E is near the same than P5W DH, in power design, the socket pcb area is nearly equal...
BTW WTF happens with the P5W DH ?? Just 4pin ATX connector ?? :confused:
Glad to see finnally a P5WD2-E rev1.03g(?) :D I have here a 1.02 dead waiting for it, to be RMAed... :stick:
I'm not buying conroe. Waiting for Kentsfield. :D
When will those boards be revealed ? :D
Can somebody say what rev of P5WD2-E premium is 8 phase and conroe support ?
It has. U need to take a good look @ the picture... ;)Quote:
Originally Posted by DaWaN
That polished copper on the first board :slobber:
It looks so smooth.
LoL. Are you able to see the rev on that pic ?? Me not...Quote:
Originally Posted by JoeBar
BTW id bet it's 1.03g. As said some times before. ( and not 1.3 )
