Hehehe...look what I just dug up :p: But not only is that a good time @ 3350, the fact that Kinc did it on AIR is what impresses me the most :clap:Quote:
Originally Posted by K404
http://cryo-laboratory.com/upload/us...5/13x2601m.jpg
I don't think so:) Great mem.performance, but it seems no performance advantage over 265-275 2-2-2-5 1T ram:( When I compare these results with mine 2x1 gb value rams with Sammy UCCCs there is only 0.6-0.7 sec. difference @ 272 3-4-3-5 1T:( Not a big improvement from 272 to 600 mhz IMO.Quote:
Originally Posted by funkflix
I can see whre part of the boost is coming from with the x13 multi and tighter rrd/wtr timings, but DAMN I really gotta get looking for more tweaks :slobber:Quote:
Originally Posted by s7e9h3n
:D More inspiration for me to try and raise my game :)
No not at all. The win install of winxp is optimized for 3d. I aint much for spi :)Quote:
It seems AM2 cant use the bandwidth available in spi. In 3D I see a really huge increse in perfomence.Quote:
Originally Posted by DStealth
I love air cooling. It took me 2 hours get the system stable enough to complete 1M over 3300MHz. I almost had it through at 3399MHz. But when the temp outside started to climb so I went to bed :)Quote:
3355MHz with an aircooled dualcore!
:wierd:
Everest latency?
Nice PC8500 Kinc and real nice air clocks :toast:
Perf. gains are much more present in 3d IMO too.
That aircooled system has got to go over 50K in 3dmark 01!! :slobber:
kinc,i tested 3 fx62, heavy coldbug,
fsb limit under (250),and loosing all mem timing.
to bad,
setup my rig.
Fx62 1.4V 3G,ddr2-1200,cl4448 2.5
7900gtx sli mod. 860/930 , of 03 only scores 44K
does someone could tell me , gpu and ddr3 of vga safe voltage,i will put those 7900gtx on ln2 or di.
Congrats Kinc, Nice to see you back in the game :)
Long time eh? :)
Though I second the request for some sandra mem benchies :D
Perkam
For GPU i'd say 1.55V under DI 1.65-1.7V for the mem, don't go over 2.25VQuote:
Originally Posted by hicookie
Nice clocks Kinc, on both the CPU and the memory.:toast:
You should be able to nail some really high Sandra, let's see some:D
OPP
For the core voltage you can probably do 1.85V on LN2.
I think KingPin uses 1.81V or so, but I'm not sure.
I have used around 1.81 on my cards at -80C. But I usually run them at around 1.78V
OPP
I was told week4 of this month.Quote:
Originally Posted by Willis
OPP
thanks,opp.
will try later, my sli-pots will done tommorrow,
there is pity, my fx62 just can do 3.2G stable on air.and heavy coldbug.
how does that compare to conroe average overclocking in 3d applications away from superPi?!
Lol, i thought he wanted to know some safe voltages. :DQuote:
Originally Posted by OPPAINTER
Well they are safe voltage with xtreme cooling:D My cards still run fine.Quote:
Originally Posted by Zeus
OPP
1.65-1.7 for the mem?? I thought default is ~ 2.2V? :confused:Quote:
yup,so wierd.:rolleyes: mem is 2.15 default ? right?Quote:
lol, he means 1.65-1.7v for the CPU, and no more than 2.25v for the mem. ;)
OOPS! :eek:Quote:
Originally Posted by Gautam
lol...ok. For a second there, I was afraid that running the mems @ 2.3 on this borrowed pair of gtx's was gonna result in a cooked card :p:Quote:
12.5K buffered for sure.
Lets see it :D
3.2-3.3G for sure,Quote:
Originally Posted by jrw
tested the m2n32-sli, can do 900 1T max,
4dimm(4GB) ddr2-1200 cl 4 stable ;)
Yeah, Quad-SLI gains alot from membandwidth so AM2+FX-62 can challange conroe for the 03 and 06 nr1 spot. Got some water cooling ready to try a little higher clocks. Do not think I will end to far from 3500MHz with some ice water. In a few days I will have som nitrogen to try and reach as good as ever possible cpu clock on hight htt.Quote:
Originally Posted by k|ngp|n
Originally Posted by perkam
Thanks guys!Quote:
Will have som sandra scores for you as soon :)
