DFI or ASUS for sure
nice ass result though brah
absolutely sure is DFI LP UT C19SLI32-T2R/G..........! look at DFI roadmap and think a little ! look at latency settings...is caracteristics for sli mobo's....and asus say nothing about conroe's mobo on his roadmap for june,but DFI say...!!
Very nice, Andre! :up: Anything more left in it or that's more-less about MAX on this cooling?
What RAM is that, G.Skill HZ by any chance?
that would be great if its the new g.skill 8000 2gb kit....as for it being DFI i guess that would make sense in all with the roadmap posted.
It's impossible to be Gskill, GSkill is impossible to be up for that timings.
also same way running, OPB's results is faster though
Originally Posted by bachus_anonym
STT DDR2 800 CL4
You've got to move to more xtreme cooling andre. It's about time!
Originally Posted by thunderstruck!
So you think E6700 2.66G@3.7G is not Xtreme Overclocking? or every post needs to oc conroe 4G+ is called overclock?
its extreme enough for me. I'd be perfectly happy if i can get my conroe clocked up to 3.7G.
i dont see how anyone could really complain about that.
almost every chipset is capable of that. Besides that fact that we know a DFI board is coming, there is absolutely no reason to assume that this is it. There are probably 20+ conroe boards coming in the next month or so.Quote:
Originally Posted by bogdannovaceanu
but it was andre who told us we'd see dfi 975x board in august. I think it is DFI myself, but no way to judge what chipset, it may be the Infinity 975X/G
I think what he is getting at is that he wants to see how much further this cpu can go on phase, not taking away from your air clocking.Quote:
Originally Posted by AndreYang
Originally Posted by Cpt Twitchy
ok...I will try air cooling limit later.
i don't think u have to prove something for someone's words.Quote:
env temp,cooling stuff,and voltage. in ur env, 3.7G stable,that's awesome!;)
Right, didn't mean to offend you. Spectacular results for air cooling.Quote:
3.7G cannot run 3D mark. It just finish 32M.Quote:
Originally Posted by hicookie
Air cooling limit
Bios temp 7x
voltage 1.6V
380X10=3.8G 1M
http://www.iamxtreme.net/andre/Conroe-E6700/3800-1M.JPG
I cannot run more on Air Cooling.
very nice results for air :banana:
Very nice indeed...I'm really hopin' for a DFI board on this one, they haven't put out a new Intel board since the 925XE how long ago...better be... :cool:
amazing score for air
what temps are you seeing at that speed on air?
btw. nice oc :D
Hery Andre... I know you know exactly what you`re doing...could it be power? :) Brilliant resultsQuote:
On a side note, are there enough results to start grading overclocks and tell the general limit of the chip for each level of cooling assuming decent voltage control?
K
E6700 max stable on air was exactly what i was hoping to see :) thanks andre
guessing max stable is around 3550-3600 ? that would be real sweet as this most likely will be my next setup.
Current setup 30.xx Sp 1M next setup 15.xx Sp 1M :eek2: :eek2: :eek2:
:party3: :YIPPIE:
can they throttle at high temp ?
AWESOME air cooling overclock. Man AMD is going down :(
Anyway can you say what chipset ? I don't care about brand if it is 965 or nVidia or ATI chipset i'll go nuts :D
Very Nice :D
Try water ? :rolleyes:
really good :toast:
