This is the same PCB as you can see in the other photos. You must pencil r451.Quote:
Originally Posted by zoran555
We need VDDQ mod for this card. I think the VDDQ is to low to handle vgpu and vmem mod.Quote:
At stock voltages I can get my 7300gt at 550/890. If I add voltage to the gpu I get 650MHz on 1.43V but then I can't get mem over 790 to be stable :?
I bumped the memory voltage a tad, but didn't seem to do anything.
[quote]3. DO NOT volt-mod the memory with the above resistor 437 .. I think it does exactly the opposite: it decreases memory OC. Wipe any pencil trails from it with acetone or technic alcohol.[/quote]
It increase memory oc but only if you don't make vGPU mod. Becouse if you make boths mods card aren't stable.
