Nohto very good dude. You picked the correct resistor. BTW that 8 legged chip right above the resistor that i used a pencil on is the one to mod. So instead of a pencil on the resistor. Connect pin 1 to pin 4 lower left and lower right pin in that pic via 50k ohm variable resistor is correct. Don't ask what exact value. I change by the minute.
Also if you have the newer revision 3 boards and it has the extra ISL 6522 chips. Then mod them chips all the same. Just like VDD mod. Again don't ask me resistance values. But all the people with 3 of them ISL 6522 chips got it real easy for volt mods.
WildCard thanks and great o/c dude. I'm a bit confused about what you did. It sounds like you replaced the resistor with a vario 1k ohm resistor. But anyways everyone please refer to my directions above.
Bowman 1964 Vref mod did not work for you because you must increase VDD as well as Vref. Try this setting just to see if this works. Set VDD to 3.075 and Vref to 1.490-1.510. That should get you to 400 if you're lucky enough. According to samsung data sheets Vref needs to be 1/2 of VDDQ. Well i think they meant 1/2 of VDD actually. Do not set Vref above 1/2 of VDD it doesn't help. Set it to 1/2 of VDD or slightly below that. Each card will be different and experimentation is needed. Set your VDDQ to 2.975 to 3.00 (above 3.00 does nothing and in fact your score gets worse) Set Vcore to whatever works for you. Set VDD to 3.00 and Vref to 1.490. That's a good starting point. Then increase VDD when you get white dots in 3dmark2k1 and increase Vref when you get black artifacts. If you get wavy lines or some real nasty sheit then Vref is probably either too high or too low or your PSU really is a POS. LOL good luck dudes.
er opps sorry OPP i passed you up and took #5. But hey at least it's a SoCal dude that did it. :cool:
