Still No good on the Defaults
Lord Trident:
Not sure what additional settings you're asking for so just let me know if you want anything specific. The Voltages that I use at 3700 other than what you can see above are CPU HT 1.320 Volts & 1.220 Volts on the chipset.
I just set everything back to the defaults -- All clocks & voltages except for my ram which is at 2.1v (1066 Ram and needs 2.0 - 2.1). The results at my stock cpu speed of 3200 for virtualization and Amd-V are exactly the same as above. Both tools still report that they are not enabled.
