so you take a 30MHz FSB hit on FSB with corsairs outch
that happened to me on 965 asus boards stangely enough but not on other chipsets
i might try different ram as well during testing
Only for boot. Either set will clock up to ~670FSB on this setup after it's on the desktop. F4f seems to have tighter boot PLs, so that's probably the hold up on it for boot FSB. The C7Ds definitely have some tighter secondaries than the Ballistix too, so that probably has a lot to do with why they won't boot as high either :)
I will be messing around some tonight and will see if the C7Ds will do 3D01 at the same FSB/primaries/PL that the Ballistix did. I'll report back ;)
Please do, we'll all be curious :)
no funny cold bugs with EP45T Extreme i have man except for cold boot bug of -76C :( but i can boot at 6GHz at that temp so no probs here :D
operating temps on my chip go down to -151C before it crashes heheh
in terms of nvidia chipsets and funny behaviour under cold make sure you do not flex the board much....also loosen F1 mounting enough that it;s just holding it in place first and then just do small turns
i was able to increase my cold bug with 790i like that.....but it was still not going past say -110C on chips which did -140C with biostar for example or other intel chipsets which is weird as Vince didn't have those problems heh
i don't know if Vince knows hipro5 cold mod for CPUs though...i wish i could have that mod
Try covering the thermtrip pin on the socket.
http://download.intel.com/design/pro...hts/318726.pdf
Cell 2M on page 45.
Weird about 790i, I had 3 chips doing -125 in it no problem, one of them was good for -130.
I think you jinxed me Chris ;) It was flying through 3Ds yesterday like 650FSB was 500. I realized that 3D01 above was on SPi tweaks, not 3Ds, so I messed around and did like 10 3D01s getting things as tight as possible, rebooted for a fresh run with the settings and it kept locking on boot. It would stop just about anywhere, but "CE" was the most prevalent code. I thought I killed the mem or something, but it wouldn't boot with the other set of Ballistix either. For some reason, it likes the C7Ds when that happens though :shrug:
It's a pain because now every time it's a bad BIOS setting and tries to reboot with defaults, I either need to swap mem or try 20x to get into BIOS and raise MCH before it locks. If we get an MCH mod, that should fix the default voltage problem just the like Vddr mods did for the old Corsairs :)
I wish I could have those temps. I don't think G H Z paid much attention when I told him how close I was benching to crashing it on temps until Taipei LOL.
The quad I used before the event bugged in this board at -68C :( With a load, it would go all the way to -71C LOL. I was petrified we would wind up with something like that there.
Nice Gautam! Getting just the right one will be tricky though ;) Is it feasible just to cover its pad on the proc instead? Just curious since you specified the pin rather than the proc. I am thinking maybe some silicone or nail polish on a toothpick would be really easy on the CPU. Got any recommendations on how to do it? :D
hey man its board related
let me give you an example
we had -87C boot and window bug during comp and on second board it was -135C boot no problem :rofl:
just plain weird
that mod doesnt do much aside from increasing cold boot to -100C or so but not always from what we've tried
i've been luck with GB boards i guess cause i always get really good results with them....with best temps of all boards including Biostar which everyone reckons gives good temps
I figured it was the board. Just seemed so odd that the temp limit on so many different 8600s was +/- 1-2C in mine. You should've asked if you could buy that one that was -135C, I would have :D
I might give that pin mod a shot anyway, just to be sure, but it will probably be at least a week or 2 before I can think about it.
LOL, I forgot about that, that sucked :down: One or the other, but not both :( I like my FSB and the cold limit isn't that bad, so I'll live it with :D
