Nope, I might've had prime95 open, but it wasn't running. My laptop however had loads of stuff running and its been on for 36 days straight. I can check the scores between the 9600 and the 9850 tomorrow, I'll be able to show how much memory bandwidth actually makes a difference in the app, just to show that it doesn't affect the score like you said.
I took a quick look at the fractal page on wikipedia to get a better idea of what exactly is going on. Maybe you could do one mandelbrot, then do a couple of zooms, like 10x, 100x, 1000x, and then a different type of mandelbrot such as the cubic or quartic or maybe a julia since its all relatively the same to program. I do like where the benchmark is going, one of the more creative ones I've seen. Keep up the good work.
