Thnx for sharing benchmark scores... :)
This thread made me decide to buy a D805 to "play with" until Conroe/Merom..
Very Nice PcCI2iminal@ :) thnx 4 this Great mini review . :)
I got mine 805 4.1g@~1.5X~ vcore [watercooled with a chipset block :D ] but i dont tried any bench yet Couse of my 1Xddr2 533 awaiting 4 another one day by day .
http://img63.imageshack.us/img63/4799/dsc055659zd.jpg
Pentium D 805 2,66@3,8 Ghz (190x20) cooled by TT Big Typhoon
ASUS P5P800SE
2x256 OCZ GOLD PC 4000 @ 237 2,5-4-4-6
XFX GF FX5200@stock
3d04 6568
http://service.futuremark.com/compare?pcm04=3208240
is it good result?:)
Demek how much vcore are you pushing in for that speed?Quote:
Originally Posted by demek
1,5 bios but real its 1.41~1,42
edit
same voltage
http://service.futuremark.com/compare?pcm04=3208548
PcCI2iminal:
I couldnt find the scythe anywhere in stock in the UK so I got this:
http://www.viperlair.com/reviews/coo...ltake/clp0014/
It sorted my cpu temps out but now i've got a whole new problem. For some reason the chipset heatsink is burning up, temps report at 38c but it feels way hotter than that and some components/transistors near the cpu are definitely too hot to touch (see pic). I'm completely stumped because everything is on stock voltages in the bios excpet the cpu which is at 1.4v to get 3.8ghz, the funny thing is even if I go past 1.4v upto 1.5v I cant post any higher than 3.8ghz and I dont understand why the chipset is so hot because i'm not even surpassing 200fsb which it should support out of the box anyway :confused: .
http://img391.imageshack.us/img391/9...dbig4ll.th.jpg
I've got a 120mm intake and an 80 outy plus the psu exhaust. I've lifted the chipset sink and got rid of the thermal tape but it still made no difference.
Originally Posted by davvy76
congrats man
the TT BT is a good find
i used a P5LD2 Deluxe times ago and that mobo can easily run 280-300 fsb with stock NB HS
check your DDR2 settings
vdimm?
i tried my 805 under water and it's not too bad:D
but at 4600 it becames incredibly hot:eek:
in fact i run 1 superPI and then i couldn't reach that freq cause the water was too hot :( not bad maybe i try it under ln2 next week or i sell it..pc2 your cpu is a b0 rev or a c1?
thanks
nice work FabiusQuote:
Originally Posted by Fabius88
4.6ghz on water is awesome
i used water + ice to get a nice screen @ 4.66ghz
B0Quote:
5ghz is so real!!!!
get that on LN2
:toast:
my little oc:)
http://www.pctuner.net/img_wb/test805/5308.jpg
http://www.pctuner.net/img_wb/test805/valid5309.jpg
asus p5wd2-e premium
corsair 5400 ul
cpu LN2
work in progress
awensome!!
cinebench will be <30sec!
:eek:
congrats
maxxxpct any mods on P5WD2-E ?
i have tested 805 in 3 P5WD and the max vcore for all is 1.6v like your screen.
oooooooooooooooooooooooooooooooooooooooooooohhhh Yeaaaaa.
@maxxxpct Can u remember the AirCooled-WaterCooled bench frequencies of this litle diamond ?
wow, thats one heck of a performer for 140 bucks new!!
805@5.3G ~:thumbsup: GOOD!! O/C :toast:
I don't have the same CPU as you but I do have the same board... I really don't think you need that much voltage... I can do 4.0Ghz with my cpu on that same board and stock volts. The trick is to set the FSB to the next level up. In your case.. Not the stock 133 but use 200 instead. It should boot with stock cooling. Well it should anyway. it does with mine. Mind you I can get to 4.2 stable but then I start to overdraw the PSU I have now.Quote:
