Looks like an IKEA Workstation. Is it?
I love their Glass WorkStations. All my desks are from IKEA. I couldn't be more happy with them.
Anyways here is my 27" iMac Setup. Desk is always a mess.
My PC is down awaiting its rma'd gpu so this is my setup for the week
http://i.imgur.com/WtW4V.jpg
Kewl... For all whoms interested, here my little setup...
http://static.ultraneo.com/pub/_MG_9...509-092302.jpg
http://static.ultraneo.com/pub/_MG_9...509-092229.jpg
http://static.ultraneo.com/pub/scrnT...509-092334.jpg
Why do all the computers in this thread look the same :confused:
.....oh crap, I think I got lost again :brick:
:sofa:
http://img12.imageshack.us/img12/5927/img0429bj.jpg
My Hackintosh!!
Resolution: 1024 x 768
Camera used: Apple iPhone 3GS
Orientation: Horizontal (normal)
Focal length: 3.9 mm
Aperture: f/2.8
Date/Time: 2010-11-20 04:54:16
Exposure time: 1/15
Lens F-Number: f/2.8
ISO: 400
Whitebalance: Auto
Metering mode: Average
Exposure: Program AE
Jpeg Quality: JPEG (old-style)
UltraNEO, nice Axiom :) I've got one of those babies sitting in front of me too.
curious if anyone mods iPad cases around here.
I recently got a "hand-me-down" an iPad2 and I remember seeing the Otterbox Defender for iPad1 @ Target for $24 Clearance price (Retails around . So most of outside features for iPad2 is not readily accessible for the OTDef iPad1 case understandably, but with a little drilling and filing this could be resolved. Plus according to most reviews on Amazon of the OTDef iPad2 case, doesn't have the same ruggedness and heavy plastic coverage as of the iPad1 case.
It fits snuggly inside the iPad1 case. And it does gives you the feel that this case can take the beating.
Just curious if anyone else have modded their iPad cases around here.
http://img846.imageshack.us/img846/3780/119pi.th.jpg earphone jack is not lined up
http://img804.imageshack.us/img804/4387/111ku.th.jpg need to create more holes for the speaker
http://img521.imageshack.us/img521/2767/112yg.th.jpg rubber handles for grip
http://img405.imageshack.us/img405/3325/113cah.th.jpg
http://img834.imageshack.us/img834/986/114pw.th.jpg some accent around the logo
http://img6.imageshack.us/img6/5906/115bv.th.jpg going to drill a bigger hole, so far the bottom edge is blocking
http://img840.imageshack.us/img840/8305/116ws.th.jpg
http://img88.imageshack.us/img88/6817/117in.th.jpg volume toggle cannot be reached because of the bevel, so making the hole bigger wider, a finger should fit --- gonna be trial and error here
http://img210.imageshack.us/img210/1808/118ed.th.jpg
I ditched the optical drive in my 17" MBP, and dropped two 120GB Sandisk Ultra II's in.
http://farm8.staticflickr.com/7016/6...bf80414b_b.jpg
http://farm8.staticflickr.com/7167/6...638ff4c1_z.jpg
http://farm8.staticflickr.com/7030/6...96006155_b.jpg
It does fairly well. Speeds might be higher on the compressible benchmarks if it was SATA III, but its an ancient Mid-2010 model.
The sandisk is sata2 ssd so a sata3 mobo wont run it any faster and to be honest the Sandisk ultra ssd is rather slow and expesive there are better alternatives...
The drives were purchased knowing they would be used on a SATA II controller, so I didn't swing for SATA III drives. I would have went with another drive if I had SATA III on both slots. These happened to be the lowest cost option, and reportedly reliable with its 32nm NAND flash that is rated for more writes than 25nm counterparts.
I don't really care about synthetic benchmark numbers, and the newer SATA III SSD's aren't much faster at writing uncompressed video. The 'peak' numbers sure are higher, but they don't perform much better at writing uncompressed video.
Reliability, performance, and cost were all concerns. The Sandisk Ultra II's happened to most adequately fit my needs.
What does your system get on the Blackmagic Disk Speed Test?
My RAID0 setup with SATA II Sandisk Ultra II 120GB SSD's on a SATA II controller, is over 200% of what a single Chronos Enhanced 120GB SSD on SATA III will do.
http://farm8.staticflickr.com/7141/6...2d29b7744e.jpg
It's all in the snazzy Sandforce compression.
I havent tested my software raid but am using 3 ocz agility 3 of 60 gb each which each hard drive is half the price as the sanddisk and i would say at least twice the speeds I will test them and let ya know...
The Sandisk Ultra II is rated at 30,000 IOPS 4KB random read, which is 50% higher than the Agility 3. The read/write speeds are similar, at 195 MB/s read 130 MB/s write, in AS-SSD. This would indicate a maximum throughput of 390MB/s and 260MB/s respectively on the Agility 3, of which my real life setup achieves around 85% of, on a SATA II controller.
http://www.newegg.com/Product/Produc...82E16820227726
The 120GB version is $30 more than I paid for my drives for identical capacity.
I did a bit of research, and these drives appear to be the best bang for the buck, along with being one of the higher performing SATA II SSD's on the market. I'd love to see what your 3 SSD RAID0 setup will do in Lion on the same benchmark. All the evidence I can find suggests the Sandisk drives are fairly good.
Fair enough on the MBP unfortunately my macbook wont run aja benchmark neither does my Hackintosh for some reason and lets not forget we are using Software raid and one of the mean reason I bought it was cos of sata 3 and my motherboard limits the speed of my sata 3 ports so am running it on the sata2.... Ill use Disk speed test and let you know... and in the UK HW seems to be cheaper?... I paid £60 around 100 dollars... the reading on the sata2 raid of 2 ssds is around 450 reading (windows mind you) and the random write @4kbs is 50.000 iops...
Can anyone show something different, jesus, their like clones.
I figured out why I couldnt run the HDD benchmarks, it turns out I got to allow it, by changing the hard drive to full access, anyway I got a nvidia controller on my MacBook so most of the time my Sata 2 controller will run the SSD at 1.5 instead so the benchmarks arent great, till it uses the full 3Gb full speed, by the way the hackintosh flies thanks to my 4 SSDs on raid (still only software raid) cant find a decent raid card for both win and mac.
Try here for raid cards :)
http://eshop.macsales.com/Search/Sea...ntroller+Cards
cheers :)
OK so finally here are my tests with my MacBook 8.2 with 2 SSDs Agility 3 in RAID 0, I think is good enough for the crappy Nvidia sata2 controller :)
Attachment 125172
Not the greatest Picture I know....
http://i1149.photobucket.com/albums/...4rr3l/mac1.jpg
http://i1149.photobucket.com/albums/...4rr3l/mac2.jpg
http://i1149.photobucket.com/albums/...4rr3l/hac1.jpg
http://i1149.photobucket.com/albums/...4rr3l/hac2.jpg
http://i1149.photobucket.com/albums/...4rr3l/hac3.jpg
http://i1149.photobucket.com/albums/...7at32443PM.png
^^ Pretty Nice!!
This place seems a bit barren, I'll add something.
http://i.minus.com/jh5fDqq9CmInD.jpg
It's the bargain bucket AOC i2367FH.
It's 23" IPS display with a matte anti-glare coating.
Cheap and cheerful really.
i think that is the HP 27xi. It is currently on sale at Costco for $220 before tax.
http://www.bestbuy.com/site/hp-pavil...7-00007bb2a68c
edit: didn't see nightmares response, haha. I'm way off.
Mid 2-12 macbook pro 2.6ghz, with boost to 3. something or other. 27 inch asus hd monitor (2011) 8gb ram, Set up for recording sound libraries offloaded to a 1tb hd.http://i185.photobucket.com/albums/x...06.03%20PM.jpg oxygen 25, mbox 2 and whatever is left from pawning gear to make it through college(less than half my gear)
