http://hwbot.org/submission/2362846_
Booooooom
Booooooom
Someone trade my 4 480s for one of these lol
Yes everything is set to 120 but it never gets there 108 max then it clocks down then up then down.
In the areas of 3d11(first two tests) i notice the throttling most, i read live voltage during those two tests and when it down clocks voltage goes to 1.02 then back up to 1.22v if i have the added .37mv thats when it down clocks??
It also down clocks/volts even if i dont have the added .37mv in those areas.
I wonder if there is someplace else in the voltage table that needs to get adjusted for full 1.22+v all the time.
I really need a spot or two to mod so the dang card dont even see the power limit no more and just be done with it,then we can move on to other mods...right?
May be total board power limit of 108. I look in the bios to see if i can fix it.
Hmmm that sucks. Maybe it's more complicated. Will have to have another look through the bios.
New drivers out... 314.14... http://www.geforce.com/drivers/results/58183 beta
Thanks you guys we all appreciate the work you do for the community
Tested card two today
i knew that it was a better clocker during some easy testing while i modded the cooling on the other one.
Al least this one runs 1200... ok it goes down to 1160 sometimes but its better then the other one is at stock before cooling 1150 was shakey 1160 hard lock.
Great titan vantage scores i'v been seeing at hwbot the last few days ..keep it up :)
http://imageshack.us/a/img824/3995/tvantage55725.jpg
Hmm, I was playing BF3 with my new Geforce Titan card (non overclocked), and after a while I got the following error: DirectXFunction "GetDeviceRemovedReason" failed with DXGI_ERROR_Device_Hung: Device hung due to badly formed commands. GPU Nvidia Geforce Titan Driver: 314.09
I'm hoping this is due to some early drivers that are not yet 100%?
I get this....my first ever DOA.
http://i46.tinypic.com/28gxu7b.jpg
maybe drivers, maybe bios, maybe faulty hardware. let's hope it is because of drivers or bios.
I already tested with two other Titans. They're working fine on the same test bench. Funny that the defective one has the newest serial number and little Torx T6 screws instead of Phillips heads.
Here you go
http://www.filedropper.com/xsbiom
Holy :banana::banana::banana::banana:, at 2560x1600 everything maxed I was getting dips into the 30's FPS with SLI Titans. Crysis 3 is BRUTAL. Good luck playing that with 680's lol
Hello,I just joined to xtremsystems. I follow this forum but was not registered. You are doing good work for people aqui. I see several people of other sites. I am with the same nickname "zupernico" in hwbot.
I have two titan. I'm thinking flash the bios, but I've never done this in nvidia, Ati is very easy. I do not know if I will dare, I will try to learn here. There are many people who know much here, but my English is very bad and I am a bit clumsy for this. thanks for the help you have given me unknowingly and for the help I will receive in the future.
Regards
Just make your usb stick dos bootable.
Put NVFLASH on it and flash with nvflash -5 -6 xxx.rom
That's all...if you're searching for the bios and nvflash, send me your email!
Hi Dancop,thanks
Nacho Arroyo put this nvflash: http://www.techpowerup.com/downloads...ash_5.127.html
And
CrazyNutz put this kgb https://www.dropbox.com/s/dk54rmgce0...gb_titan.zip?m
it?s ok??
my problem is make usb stick dos bootable in this moment :( and flash the bios $(
Guys, what does KGB do for Titan?
Dancop very nice vantage(and the rest too)runs man!
that guy AngelNa had some great runs yesterday too.
BUT since no public vmods its all cpu right now,hopefully we can get some guidance in the next few weeks from the pros.
Thanks Dacop,
I could flash the bios, but I had no improvement. I set the power limit to 120 and the fan in auto, but nothing. The same or worse :(. The bios is good and i?m bad??, I do something wrong?
I try with another BIOS? which?
new result ? common :up:
You did nothing wrong
I would think it would be ok to flash different makers
ok, thanks Cowie,
then increase the power limit is not useful for overclocking in this gpu?
But if it does not improve voltage, the overclock will not get more than the initial bios?
We are still trying to figure out WTF is going on with the power limit, I am starting to think it's hardware capped..........been really busy with work though haven't had a thorough look in the bios.
come here at price of 1326 usd . card is very tempting but too expensive i can get a second 7970ghz from 526. want this too much but i am passing this :(
speaking of voltage
poparamiro from lab501 was nice enuogh to post this
http://imageshack.us/a/img26/8747/p1310459.jpg
http://forum.lab501.ro/showthread.php?t=21&page=9
Got it done tests today
But word from ftw is so so results
Yeah power limit still kicking in yo. Remember TiN mod 680 for power limit bypass ;) This should be next mod.
Got that one done already :yepp:
Testing vmod now but i think i will still hit pl.
Perfect timing i was starting to get borded with the card,this should add some playiblity if it helps or not :)
Be good to see some results :)
Waiting for results of Vmod and how affects to clocks high to limit !!! :)
Well i hope that everyone has better results then me.
38k ohm gives me .92v 2d up to 1.26v 3d that is when it stays there
vread i use in the ss a few pages back
Well at least i found a way to run 950 3d at only 1.08v,but thats not what we are after is it :(
Sucks? ^ surprised the power hard mod had no effect. what does TiN think?
Some quick 3-way action Cards stock @ 1045 MHz / 990X @ 4.7GHz
http://i720.photobucket.com/albums/w...k990x47ghz.png
Holy sheet thats sweet you have three
Just testing up to 1.27v
Can run up to 1296 60% of the time with clocks going as low as 1189.
tried with pt mods but after vmod i had bad throttle i took them off and put the bios from cryptik just to see
how that was.
I'd have to leave ram clocks alone to run the core up to get anything over 1250 to run 1.27v is all i tried
Heaven was being bad to me at this point
http://imageshack.us/a/img707/9673/tvmv2.jpg
tried to split the c/m power balance some
http://imageshack.us/a/img14/5093/tvm3.jpg
Not to sure how much i'd put into these digi vrm or not but 1.30v should be ok if you get over the pl
i did add a 4 inch long 15 cm wide heatsink on the back of the card it gets hot there.
http://imageshack.us/a/img191/1968/imgtvm.jpg
Gives me something to play with so i am happy good results or not :p:
Yeah I have 3 for a short time, I'm selling the 3rd one. We still have no stock here after the initial run sold out and although it's better for Crysis 3 to have 3 no way can I justify the price.
Really sucks about the throttling! There must be hardmod that can be done to reduce the power draw the card is seeing, but the odd thing is they seem to be throttling earlier than theyre supposed to and no matter where you slide the TDP or temp slider it makes no difference, people are getting throttling at 60*C at 90% TDP - ManuelG from NVIDIA says they have reproduced the problem over on Geforce forums, hopefully a new bios can fix it, so that may help too.
New PB for me:
P15225 http://www.3dmark.com/3dm11/6152524
Thats at +200 using the Gigabyte utility, what are you guys using? Aftreburner? I miss the monitoring as OC Guru has none.
Cowie - where did the volts come from? Hard mod? I am water cooling mine so a little more volts would be great.
Which mod have you done for 1.27V?
He posted a pic guys of the vgpu mod a few posts back. Post 138.
Nice score there aussie :) Sure you don't want to try SLI, I know where there's a card, your wife won't even notice ;)
I need it in more detail!
I think so far from my results dan its best to just try this guy maarten12100 bios at ocn's titan thread\
http://www.overclock.net/t/1363440/n...ners-club/3310
he has a couple bios in the thread one even has 1.24v full time(without added .37 in ab)so really start there.
If you want to go and do mod just to have fun with mod after that i tell you as best i can in more detail its easy
I just get kick out of doing the mods i need to to them for my fix,results normally come hand in hand with them but this time not so much
Just like picture shows
50K vr to the point marked in the pic it also shows him using one of the legs off power plug for ground.
He shorted two of the 5m0 power sence resisters also
You need vread also, that i went to inductors to get.(in pic i put up a few pages back)It all happens on front of card so stock cooler no go
So just try bios first then post up results of them
Which bios is the 1,24?
He posted a lot!
hold on i look now i renamed it
Think it was this one
in post 3286
but i think maybe clock issues hmmm or was it this post 3312 one that was more better?
Try to see i went thruogh a few.
and this will give me 1,24V without mod??
1.22 then add 37 mv with ab up to 1.249 read live with dmm
And which one is it?
#1, #2 #3?
stay away from 3(since 1 guy bluescreens with it) use the ones in the other #posts as i said they all behave same way in 3d
Please dan go right to him with any input on bios would help all that way.
I tried 1 and 2...but voltage change through ab wouldn't help...It doesn't work...it goes all the way back to +0!
Give me a minute i will read voltage on them i think its no matter you still get 1.24
hold on
Tested #2
Its ok dan you dont need to move slider
idle 2d lp3d 1.223v in 3d 1.249v without slider so your go to go
So you mean, not shown in AB, but v?a dmm?
Yes read with a digital voltage meter,ab(alex got too pissed with noobs asking why volts go up and down lol) and all software is just in ballpark.
Not to get too complcated,it does matter some on where your gpu read and ground is with your dmm but i went with the logical spot.
See that was easier then hardmod right.
Now try vantage at 1300 :D
So that No2 bios will give me 150% power and 1.249v ?? woohoo I will try it after I put my water block on.
:D
Thanks mate, I did a little better too, still with 24/7 and gaming clock on cpu:
P15436 http://www.3dmark.com/3dm11/6152854
yEs it has that voltage but pl is read upwards of only 108ish%
http://www.abload.de/thumb/screenshot.237o9upe.jpg
looks promising...doesn't it?
Is that right? 1.2v 2D also? Does it still down clock in 2D or is that why the voltage stays up?
No down clock on some i tried see post below
i will take a look becuase i went thruogh a few this morning he was poping them out fast .
Some have too high of a clock for mere motals :p:
I will get back to you if dan does not answer first.
Some bf3 action at 1250 have some vids at 1280 too will post later
http://www.youtube.com/watch?v=Gdgi4FcUBcE
Tri Titan :D
http://img248.imageshack.us/img248/1893/3d11p30050.jpg
http://img23.imageshack.us/img23/8806/3d11x15123.jpg
I get my best results with stock bios, one of my cards hate voltage and throttle a lot with 1.2+
Best result in sli:
http://img24.imageshack.us/img24/3713/19207e.jpg
http://img839.imageshack.us/img839/9437/192071.jpg
Cowie - are you on stock cooler or water? If you find a bios that gives a voltage bump and still downclocks 2D I will try it, I have an EK VGA supreme in my loop waiting to go on. Two nights ago I benched easily at +200 but last night it would lock up or bsod at +180 so maybe lower temps will make it more consistant.
I can now say for sure that these cards aren't hardware capped. I just hit a 125% power limit, my ups seems to back up those claims.
Anyone else getting the "DirectX function "GetDeviceRemovedReason" failed with DXGI_ERROR_DEVICE_HUNG: Device hung due to badly formed commands.. GPU: "NVIDIA GeForce GTX Titan", Driver: 314.90" message when playing? I also tried the lasted beta drivers, same thing happens.
I first had a GTX 580 and had no problems. I upgraded to Geforce Titan, even used drive sweeper, and only installed the newer drivers. I can't get rid of this problem. On average it happens every 5 hours or so.
I monitored my videocard and it's not getting too hot or anything. It's also not overclocked. Is this a HW problem or SW?
KEPLER BIOS TWEAKER V1.25 download
http://www.technic3d.com/download/ov...aker-v1.25.htm
Naennons bios that works great for some at ocn
http://www.overclock.net/t/1363440/n...#post_19490729
What can this do? (sorry browsing from phone so it's easier to ask)
Baba - what did you do to get 125%? What vgpu and clocks have you achieved?
I'm looking a voltage and power bump while keeping 2D clocks lower, has anyone done this yet? That's assuming the 2D clocks and parts load clocks aren't increased.
:D
i don't own one but i "sell" them...
http://sphotos-a.xx.fbcdn.net/hphoto...18599386_n.jpg
I'm using a modded bios that I got from OCN, the one that Napalm linked. It supposedly has a vgpu of 1.21v. The bios had 115% power limit by default and my card was hitting that and throttling. So I bumped it up with Kepler bios tweaker to 135%. Now it hits 125%. I saw someone on OCN mention that at 1.21v in software that he read 1.26v or so with a dmm. So my card may be doing something similar.
Whats your ASIC and what clocks are you running? That's a high TDP.
i actually work at Micro Center, we sell it for $999.99 before taxes
That was under the default 1202 (on that bios).
I ran Heaven and the power limit topped out at 99%. That 120%+ was when playing Hard Reset. I don't know why that stresses my card so hard. I had always wondered why that game made my card throttle so badly.
The asic quality rating on my card is 70.7%.
I know that is a really high tdp but I'm running using a full cover block so that helps keep the vrms cool. I wouldn't feel comfortable bumping up the power limit that high on the stock cooler.
Cowie - I already have a universal gpu block in my loop as I thought I would be able to keep using it over a few gpu changes and it works well, but I leave the stock backing plate on to cool vrms etc. Yesterday I decided to remove the cooler and fit my block but one of the Allen head cover screw seems to be rounded out, I undid a few but I can't get any bite on this one, has anyone else found this? Or do you just remove everything together via the Philips head screws through the pcb?
While this card pumps the scores it seems to me that it doesn't do that well in BF3, I get erratic fps anywhere from 85-170 (on 120hz screen) and that's on high !! I am sure my 680 Lightning pushed more than that on ultra. I have not tried ultra with Titan yet, I'm still using the settings I used with the 670 I just sold, but at the same settings it doesn't feel much better.... Odd indeed.
Baba would you share your bios with me? Does yours still downclock in 2D ?
napalm linked it aussie a couple pages back. still downlocks but some were saying it has 2 speeds now 2D and 3D.
If you messed up the torx screw then just try 1 size bigger and put some wieght into it or drill it out with a small bit.
I have No plate its all off I take that sht off and go custom sinks and direct airflow first thing.
I only run a single 1080p monitor 60hz ultra settings for bf3
If you look at vid i posted on wake, my titan with just core clocked is 15 -10 frames faster at times never slower then my 1440 clocked 680.
in this vid
http://www.youtube.com/watch?v=atVww9ACUik
It takes around 1600 to get close to titan with 680.
Will edit in some more titan vids
So how does 1080 at 120hz compare to 1600p ? It would be a similar load right? So maybe what I am seeing is real? I played at +100 last night and got the device lost error, I think this thing really needs water ASAP.
No I didn't round the screw, no tool I inserted would get any bite at all, as if it was already rounded out.
A full cover block will fix it....
:D
Hi, Has GTX Titan got any hardware voltage limiter? Can we give above 1,2v with any bios mod?
That what the AB fps graphs tell me, but thats playing online so i guess many factors come into play. Titan definitely benches much faster, 2800 gpu points faster in 3D11.
Now I got 2 EK blocks for the Asus Titans, and I am ready to overclock!
What about a guide to flash the Titans, and a list of Bioses that works great? :)
emertX: Can you make a guide for noobs like me? :)
You'll find a lot of guides through www...
Type this in dos, bootet from an usb stick including nvflash and the rom!
Here's a guide:
http://1pcent.com/?p=277
BTW. I strongly recommend that you also read up on it on OCN for a better overall understanding.
Dan really kick as5 scores!
rsannino CtrlFix and ftw got some great scoring also at the bot
keep it up guys
Put a card on dice
Same 1.28v at 44c that got me 1267 but now -40c 1320+ np even for bf3 :D
http://imageshack.us/a/img705/2150/t3d1117232.jpg
http://imageshack.us/a/img687/4382/tv58048.jpg
Did not have(find) cb but need to swicht dvi connector at -15c to other for bls, BUT cbb -46c sucks cus it still shows normal voltage not like the 680 which goes to ..68v when it cold boot bugs
Will try more later
-40 1320 lol nice man
so the hard mods working to get around TDP limit and throttling?
Guys, nvflash gives me an unable to open nvflash driver error, what does this mean? I did --protectoff before attempting.
Is this OK in windows or is bootable USB better?
Edit: I got it working P16317 with much more to come ...
Nice aussie
Its ok around where i got it for now,i am not greedy
ok how about we run some 3d03 action for the next week,not so much for total score but since even with stock bios oc'ed card pl is max 60% (cept we bit part in gt4) so high clocks should be np for all :D
I used the nv280335 one, 1.212v and 116% power. It's in the 1% guide linked in this thread but power level drops with repeated runs and so does the score so I think it will be even better under water (EK block on the way). Then I might try Baba's 1.25v one ...
