Originally Posted by
WhiteFireDragon
dam, i may have spoken too soon. 700/1500/1180 might be stable just for GPUgrid, but it's not stable for 3dmark vantage. now i'm having doubts as to which application is more demanding.
i think a good compromise would be having high shader clocks for GPUgrid, while only having moderate core and memory clocks to satisfy everything else. Otis11, you pointed out earlier in the thread that it's probably best in terms of stability and clocking to keep the shader and core linked, so hopefully 685/1515/1400 would work for all applications (moderate core OC, high shaders, stock memory). i'm testing that out right now.
edit: it's also a pain in the arse every time 3dmark vantage gets errors, because then the GPU downclocks and i can't seem to bring it back up to even stock speeds unless i reboot the computer
