As I can see, you have listed wrong memory on me. I used Corsair, not Geil.
I am sorry :eek: will have it fixed :banana: :eek:Quote:
Originally Posted by ManagHead
We are starting to get a nice database here!! Good job GR!!
I'm waiting for my new D-Tek FuZion block and BIX-II to see if I can lift my E6600 to new levels.
@ billdavis. Maybe my eyes playing games on me, but i don't see an orthos stability test...
@ GrimReaper. Nice usage additions on the 1st post... :)
User Name: mele
Stability: Orthos(8 hrs, 40 min)
CPU name: X6800
OC: 3609MHz
Stepping: 6 B2
Week: L627
Code: A872
Vcore: 1.55
Cooling: Water
Cooler brand/model: Apogee
Motherboard: Asus P5B Dlx
Bios Version: 804
Operating System: XP 32
RAM brand: GSkill
RAM rated speed: PC-8000
RAM actual speed: 501
Latency: 4-4-4-12 2.35v
User Name: McPhisto
Stability: 12hrs Orthos Small FFT's
CPU name: Intel E6400
OC: 3.5GHz
Stepping: 6B2
Week: L630
Code: A489
Vcore: 1.45V
Cooling: Air
Cooler brand/model: TT Big Typhoon
Motherboard: Asus P5B Dlx WiFi
Bios Version: 0711
RAM brand: Supertalent
RAM rated speed: PC6400
RAM actual speed: 1000
Latency: 4-4-4-8
http://img488.imageshack.us/img488/2...5ghzez8.th.jpg
User Name: zevia
Stability: 12 hours+ ORTHOS
CPU name: E6400
OC: 3,203 Mhz
Stepping: 6 B2
Week: L625
Code: A452
Vcore: 1.3625
Cooling: Air
Motherboard: Asus P5W DH Dlx
Bios Version: 1801
Operating System: XP 32 (SP2)
RAM brand: Corsair XMS2 2x1GB
RAM rated speed: 6400
RAM actual speed: 800 Mhz
Latency: 5-5-5-12
Memory Voltage: 1.95V
BIOS Settings
AI Overclocking: [Manual]
CPU Frequency: [400]
DRAM Frequency: [DDR2-800Mhz]
Performance Mode: [Turbo]
PCI Express Frequency: [115]
PCI Clock Synchronization Mode: [33.33Mhz]
Memory Voltage: [1.95V]
CPU VCore Voltage: [1.3625V]
FSB Termination Voltage: [1.20V]
MCH Chipset Voltage: [1.50V]
ICH Chipset Voltage: [1.05V]
**12 hours Orthos stable**
http://upload.cdfreaks.com/zevia/C2D...0307_12hrs.png
http://valid.x86-secret.com/show_oc.php?id=152613
Somebody else must have an e6300. I feel lonely down there by myself. Maybe they are all intimidated by my beastly score. ;)
I have an E6300 but i'm waiting for my Zalman CNPS 9700 LED & Asus P5N32 -E SLI and than Scores :D...
Edi: why.. what mb do you have now.. and what are it able todo ?
I'm waiting for a new mb. my old died at a fsb at 540.. :eek:
but I hope the new will break the 100% OC. :banana:
So.. I'll add mine soon shifty803 :)
not for nothin', but #6 on the E6600 list seems to only have done 6hrs. of Orthos. I thought we needed 8hrs?? Just checking the rules here for an "official" OC.
There are probably some E6400 that would not want to post next to yours;)Quote:
Originally Posted by shifty803
My E6300 was able to boot at 500MHz but became unstable due to ram issues. It's Doing 3.36GHz Orthos stable right now :)
User Name: zevia
CPU name: E6400
OC: 3,400 Mhz
Stepping: 6 B2
Week: L625
Code: A452
Vcore: 1.400
Cooling: Air
Bios Version: 1801
RAM actual speed: 850 Mhz
Latency: 5-5-5-12
Memory Voltage: 2.00V
BIOS Settings
CPU Frequency: [425]
DRAM Frequency: [DDR2-850Mhz]
Memory Voltage: [2.00V]
CPU VCore Voltage: [1.4000V]
FSB Termination Voltage: [1.50V]
MCH Chipset Voltage: [1.65V]
ICH Chipset Voltage: [1.20V]
**11+ hours Orthos stable**
http://upload.cdfreaks.com/zevia/C2D...407_11h02m.png
http://valid.x86-secret.com/show_oc.php?id=153045
Although these 3.4Ghz settings are stable but Everest temp reading often jumps around above 50°C on full load so I prefer 3.2GHz instead. ;)
OK, it's been over 48 hours an no update to the list.
User Name: Ron 61
Stability: 8 hours Orthos small FFT
CPU name: Xeon 3060
OC: 3672MHz
Stepping: 6 B2
Week: L628
Code: B211
Vcore: 1.46v in bios, shows 1.36v/1.32 idle/load
Cooling: Water
Cooler brand/model: Aquaxtreme 50Z/Aquaxtreme MP-05 SP LE
Motherboard: Asus P5N-E SLI
Bios Version: 202
Operating System: XP Pro 32
RAM brand: G Skill
RAM actual speed: 816MHz
Latency: 4-4-4-12
I am a bit confused with some of the results I am seeing here with Orthos.
Why is it that for all the Orthos runs (small fft) over 8 hrs, we are showing different amounts in the "rounds" window?
As I run it, I get 1 round for every time it passes a test.
Some results are showing 0/0, I got 31/33.
Also, I think the screenshot should be with Orthos running, NOT idle or crashed, with cpu-z in the same shot, as I know Orthos can be faked.
I would prefer to see an official acurate db.
Note: I am not in anyway accusing anyone here of false shots, just my input. :toast:
My 2 cents.
4X4N used large FFTs test and is on the list as well :nono: Though I think large FFTs test is great for stressing CPUs, rules should be rules.Quote:
Originally Posted by cdelong
I think the difference in rounds is just that one core slightly faster than the other. As for results showing 0/0 I do not know.
As soon as I go watercooling in a few weeks, I have no doubt that my E6300 will reach 3.5Ghz+...the only thing holding me back right now are my temps.
Best $180 processor EVAR.
Same here buddy. Booted up at 500MHz Fsb and the cpu was rock solid stable, so was my ram. Northbridge temps were awfully disgusting so I had to back down.Quote:
Originally Posted by darcon
CPU name: Intel E6300
OC: 3.5GHz
Stepping: 6B2
Week: L631
Code: where is this located?
Vcore: 1.4V
Cooling: Air
Cooler brand/model: Scythe ninja
Motherboard: Gigabyte DS3
Bios Version: F5
RAM brand: Kingston
RAM rated speed: PC4300
Latency: 5-5-5-15
http://valid.x86-secret.com/show_oc.php?id=151175
http://valid.x86-secret.com/cache/151175.png
What does it mean when on dual orthos- one of them just freezes, but there are no errors while the other one is running fine and continues till I stop it?
What do you mean by "Dual Orthos"? Orthos by default stresses 2 cores so are you running 1 or 2 instances?Quote:
Originally Posted by Stx
^ oh ok, I was running 2 instances on my e6400- so thats why one was freezing up later on while the other one was fine
You should see 2 fields of info start when you click the start button.
User Name: flyfisher
Stability: 13+ hrs. Prime95 blend
CPU name: E6400
OC: 3400MHz
Stepping: 6 B2
Week: L628
Code: B179
Vcore: 1.2875
Cooling: Air
Cooler brand/model: Thermalright SI-120
Motherboard: DFI Infinity 975X/G
Bios Version: 97TIDC01
Operating System: Win2K SP4
RAM brand: Team Group
RAM rated speed: DDR2 667
RAM actual speed: DDR2 850
Latency: 4-4-4-12
http://img183.imageshack.us/img183/8...2001yc3.th.jpg
User Name:famich
Stability: Orthos 10H+
CPU name : E6600
OC: 3834MHz
Stepping: 6 B2
Week: : L630
Code: A754
Vcore: 1.54V
Cooling: Water
Cooler brand/model: Alphacool Nexxos XP
Motherboard: Asus P5WDG 2WS PRO
Bios Version: 0604
RAM brand:TeamGroup XTREEM
RAM actual speed: 852
Latency: 4.4.4.12
http://img473.imageshack.us/img473/2...web2sd2.th.jpg
:clap:
PS: This CPU was sold to me by a friend from Germany, who s visiting this forum quite frequently as well- TYA :toast:
3.8ghz and 70ºC with water cooling is a little hot. I can be at 3.6ghz and be under 60ºC on air.Quote:
Originally Posted by famich
Not really considering he's giving it 1.54v:eek: Is it a single core or dual core rad.? If it's a dual core rad. try reseating the waterblock to get a better contact. Crank down on those thumbscrews!! Ceramique is great for WC'ing. If you don't have any, try it;)Quote:
Originally Posted by Nmbr1Ballr
I'm running a measly BIX with a single 120mm Sunon pulling into the case- that gives me 55- 59C @ 1.4875v in bios (1.44v real). I have a BIX-II all ready to slap on this rig Monday when my new D-Tek FuZion block arrives. Monday am this rig gets drained as long as UPS shows "Out for Delivery" when I check in the morning.
Well ... the temps are well for the setup he`s running - and keep in mind - it`s not his 24/7 setup :rolleyes:Quote:
@famich: well done mate :clap:
@all: As soon as i have the new screens ready with 3,9 from my L629B - they`ll be posted here but right now some Xeon 3060`s keep me buzy :slobber: - some teaser screens are in this thread -> http://www.xtremesystems.org/forums/...9&postcount=14
Someone asked for the background i use on my testbeds ... it´s attched here :cool:
OK, It has now been 3 days with no updates to the database???
Guys, please read the first post before putting up your overclocks. Grim specifies 8+ hours of dual Prime95 small fft or blend and/or Orthos. I don't mean to get anybody angry, but that really is necessary to verify stability of the overclock. Try not to clutter up the thread too much with invalid or incomplete posts. :stick:
Good luck!
User Name: CyC
Stability: 20 hours Orthos Blend
CPU: E6600 (Lapped)
OC: 3600mhz (400x9)
Stepping: 6 B2
Week: L628
Code: B368
vCore: 1.40
vMCH: 1.55
vICH: 1.05
PCI: 33
PCI Express: 100
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Full Load Temp: 50c
Idle Temp: 32c
Motherboard: Asus P5W-DH Deluxe
Bios Version: 1707
Operating System: XP Pro x86
RAM brand: Patriot
RAM rated speed: 667
Latency: 4-4-4-12
http://valid.x86-secret.com/show_oc.php?id=149015
http://img96.imageshack.us/img96/2959/24dec06ds1.th.jpg
as requested by grim :toast: :
User Name: Pete@X
Stability: Dual Prime 24.14 Blend 18hours+ / 3DMark / Games /Name it
CPU name : Xeon 3060
OC: : 3718MHz (not the final ....)
Stepping: : 6 B2
Week: : L630
Code: A986
Vcore: 1.3125 (Bios) / ~ 1.3400 under full load
Cooling: Water
Cooler brand/model: NexXxos XP Blocks
Motherboard: Asus P5W64 WS Pro
Bios Version: 0402
Operating System: XP 32,
RAM brand: GSkill 2GBHK
RAM actual speed: 826
Latency: 4-4-4-12
http://img442.imageshack.us/img442/7...34m2vl2.th.jpg
... and the 2nd 3060: :woot:
User Name: Pete@X
Stability: Dual Prime 25.1 Blend 12hours+ / 3DMark / Games /Name it
OC: : 3600MHz (not the final ....)
Stepping: : 6 B2
Week: : L630
Code: A986
Vcore: 1.2875 (Bios) / ~ 1.3120 under full load
Cooling: Water
Bios Version: 0402
Latency: 4-4-4-12
http://img243.imageshack.us/img243/9...17mxzh7.th.jpg
Is this thread even still being maintained?? new submissions not enterd, invalid submissions not deleted....
I'm just wondering if I'm wasting my time making any more "valid" runs on my rig.
Maybe he's on vacation or something. I'm sure it will be updated.
I am right here :toast:
Last updated on the 2nd of 2007 ;)
I am just not feeling soo well for the last couple of days.. the Flu is floating around at this time and its got me down real bad amd my boss is eating my head calling me to work. :banana:
Pete another 3060 doing soo well :slobber: :woot:
Grim, you got pm ;)
GR- seems the flu season is giving a pretty good kick in the pants this year. Lots of rest and fluids;)
Dr. DeLong
Update (!):toast: on my E6600: :clap: and now it moves to the Gameing-PC :eek: and i`ll see what the 3060`s can do :D
User Name: Pete@X
Stability: Dual Prime 25.1 8hours+ / 3DMark / Games /Name it
CPU name : E6600
OC: : 3906MHz (9x434) :woot:
Stepping: : 6 B2
Week: : L629
Code: B374
Vcore: 1.5125 (Bios) / ~ 1.5400 und full load
Cooling: Water
Bios Version: 0402
RAM actual speed: 868
Latency: 4-4-4-12
http://img171.imageshack.us/img171/5...m167lj0.th.jpg
Congrats , Pete , Well Done !
haha thanks Doc ;)
p.s
you really a Doc? :D
updated guys :toast: please keep them comming
The Screenshot must have orthos running.. Idle or crashed results will not be included from now on.
Must have atleast 8 hours of Orthos, (small FFTs or Blend) or Prime. Initially several 4-6 hours were added but from now only 8 hours or more will be added.
User Name: TSFroggy
Stability: 24 hours Orthos blend
CPU name: E6300
OC: 3150 MHz
Stepping: 6 B2
Week: ???
Code: ???
Vcore: 1.28v
Cooling: Stock Intel Cooler
Cooler brand/model: Intel
Motherboard: GA-P965-DS3 rev.1
Bios Version: F5
RAM brand: A-Data Vitesta 2x1GB
RAM rated speed: PC2-4200
RAM actual speed: DDR2-900
Latency: 5-5-5-15
Hi dude.. take care and hope you getting better. :DQuote:
Originally Posted by GrimReaper
@pete .. you really got bunch of nice chips.. :clap:
@famich .. nice results from both 630A chips you have :woot:
:) :) THX, Argon , to go higher on WC is very difficult, because the chips get very HOT :D
Yapp - that´s the Prob most of the time ... but ... i`m already working on the 4GHz on water - let´s see IF :confused: it´s possible with the 629 i have here. If not - i have to find some "Z" CPUs to give them a try :toast: .Quote:
@Argon: thanks for the flowers :toast: and btw .... don´t ask famich about his source for the 2 nice 630`s :D
@Edit:
Looks promissing so far -> 4,005GHz (9x445@1,54/1,55)V :woot: :clap: :woot: :clap: :woot: :clap:
http://img403.imageshack.us/img403/4...m167rn8.th.jpg
Will keep ya updated when there are more news :slobber: :eek: :D
User Name: mele
Stability: Orthos(8 hrs, 11 min)
CPU name: X6800
OC: 3707MHz
Stepping: 6 B2
Week: L627
Code: A872
Vcore: 1.6
Cooling: Water
Bios Version: 910
RAM brand: GSkill
RAM rated speed: PC-6400
RAM actual speed: 424
Latency: 4-4-4-12 2.25v
@ pete.. why can't ask ... something fishy .. :D
@ Famich .. i think water max should be around 3700 to 3750. Dun dare to use the 3800 for 24/7. But one thing really nice is that almost all the
L630A75x chips did quite well .. :D
Can I join with E6400 and two speeds? I have incredable stepping, very low voltages..
3800 at 24/ is quite possible for me , as my chip is capable to run at that speed at 1,5 V Core, which is acceptable.Quote:
Originally Posted by argonmtt
And the temps are below 69-68 C, which is OK for the Conroe . But- why ? ;) The output diff is small..
Yapp - agreed, here is a screen from my last session with the L629B @4GHz. It´s something over 5h Dual-Prime stable, then i had to stop because i needed the testbed for some 3060`s :toast: :Quote:
http://img158.imageshack.us/img158/9...m167rj4.th.jpg
It shows that 4GHz with simple water is possible, with some tweaks it should be no problem to get it 24/7 stable - if you do not care about the temps around the borderline ... lapping could help to get the temps down a bit too and - as last resort - chilled water could do the trick also, but i`m happy with the 3.9GHz i´m running the cpu now 24/7 :clap: and now let´s have a closer look at some 3060´s :toast:
:toast:
Way to go, Pete ! :clap:
User Name:VicFalc09
Stability: 8 hours 44 minutes orthos blend
CPU name E6400
OC: 3200 MhZ
Stepping: 6 b2
Week: l626
Vcore: 1.3250v
Cooling: Air
Cooler brand/model: Zalman 9700
Bios Version: 0804
Operating System: xp 32 pro
RAM brand: G.Skill
RAM rated speed: DDR2-800
RAM actual speed: DDR2-800MHz
Latency: 4-4-4-12
http://img411.imageshack.us/img411/3996/untitledzb6.jpg
Where do I go from Here?!?
User Name: Spookz
Stability: Orthos Blend 11hrs+
CPU name: E6600
OC: 3204MHz
Stepping: 6 B2
Week: L631
Code: A500
Vcore: 1.325V (Bios), but Probe Shows 1.36V
Cooling: Air
Cooler brand/model: Scythe Ninja Plus Rev.B
Motherboard: ASUS P5N32-E SLI
Bios Version: 0501
RAM brand: OCZ
RAM rated speed: PC4300 (Value Ram)
RAM actual speed: 667MHz
Latency: 4-6-6-16 <-LOL, i'll work on them...
http://img239.imageshack.us/img239/2...0stableeq7.png
I've got my E6600 up to 3.6GHz (400x9) on the P5N32-E SLI now.. But my cpu is running SOOO hot! BTW i'm on air cooling in a fairly hot room..
Still on OCZ DDR2-533 Value Ram.. =)
Probe is showing 63-64C IDLE.. i don't dare touch any full loads like Orthos..
It's not safe right?
User Name: Comminadian
Stability: 10 Hours Orthos
OC: 3609 MHz
Stepping: 6 B2
Week: L628
Code: B299
Vcore: 1.38v @ Load (1.41v idle, 1.450 BIOS)
Cooling: Water
Cooler brand/model: Koolance/Exos-AL/CPU-300G
Motherboard: Asus P5B-Dlx
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 802 MHz
Latency: 4-4-4-12
http://img329.imageshack.us/img329/9...croppedio7.png
As long as you're loading under 80 it's ok. I've had my D820 @ 75C for ages on the boxed cooler. Tried lapping the CPU already? :)Quote:
Originally Posted by spookz
LOL.. i dont quite wanna void warranty yet.. =)
I'm waiting for ASUS to get their act together..and release a proper bios for the P5N32-E SLI... atm if i set anything at like below 1.4V Vcore.. it'll default to 1.39V in Probe... so.. it's kinda locked Vcores.. =S
I hope they can release a fixed bios..so i can adjust the vcore step by step..=)
Until then...ahh....
Orthos blend priority 1 is no stability test....
Try custom (small ffts in place) and prio 9! You'll see the difference...
User Name: Stx
Stability: 8 hours+ Orthos Blend
CPU name: E6400
OC: 3200MHz
Stepping: 6 B2
Week: L626
Code: A288
Vcore: 1.3125V(set in BIOS-vdroop to ~1.26 from mbm5)
Cooling: Air
Motherboard: Asus P5B Deluxe
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 800Mhz
Latency: 4-4-4-4
http://img406.imageshack.us/img406/9...2751pm1iq6.jpg
User Name: Chri$ch
Stability: dual Prime (9 hrs, 6 min)
CPU name: X6800
OC: 3500MHz (500x7)
Stepping: 5 B1
Week: L617
Code: A954
Vcore: 1.33v (idle & load)
Cooling: Water
Cooler brand/model: Zern PQ
Motherboard: Asus Commando
Bios Version: 0601
Operating System: Win 3k3 Server
RAM brand: Cellshock
RAM actual speed: 500
Latency: 4-4-4-12 2.19v
http://www.muenster.de/~e30pics/Bild...-1/Prime-4.jpg
user name: burn what?
stability: 15+ hours prime 95
cpu: E6400
oc: 3.6 Ghz
stepping: 6 B1
week: L628
code: B179
vcore: 1.425 set in bios
cooling: air
cooler: zalman 9500
motherboard: gigabyte ds3
bios version: f8i
operating system: win xp pro
ram brand: patriot
ram rated speed: ddr 800
ram actual: ddr 900
latency: 5-5-5-15
stupid question time, with the 200kb limit on picture uploads, how is everyone posting these large screenies that look crystal clear?
Imageshack.usQuote:
Originally Posted by burn what?
User Name: Babalouj
Stability: 12 Hours+ Orthos blend
CPU name E6600
OC: 3600mhz
Stepping: 6 B2
Week: L632
Code: A734
Vcore: 1.46V
Cooling: Water
Cooler brand/model: Swiftech 6002a
Bios Version: 0910
RAM brand: Crucial
Latency: 4-4-4-12
Now can i get my spot
User Name: menlatin
Stability: 15 Hours Dual Prime Blended
CPU name E6400
OC: 3901mhz
Stepping: 6 B2
Week: L628
Code: B194
Vcore: 1.56V
Cooling: Water
Cooler brand/model: Swiftech Storm Rev1
Bios Version: 0711
Operating System: XP 32 Sp2
RAM brand: Patriot
RAM rated speed: PC5300
RAM actual speed: 988
Latency: 6-6-6-15
http://i89.photobucket.com/albums/k2...901prime-1.jpg
Dual prime @ 3900 with a 6400 on water is remarkable. Could be used as a standard itself. This was on the front page though and not that I'm trying to take away but it needs to be clarified maybe. "The Screenshot must have orthos running.. Idle or crashed results will not be included from now on." Is that for orthos only? I will try, won't do dual (my ver. has an instance for both cores)or more than 8hrs though. I want to use my board. Congrats on your run.
http://thasp.net:4000/pictures/computer/stability.PNG
e6400(I will post the stepping later, I wrote it down I just don't know where) @ 1.45v
G.Skill DDR2 1000 4-4-4-12, 2x1 GB
Gigabyte DS3, F5 BIOS from late september
Windows XP SP2 pro
Check the other pics in that directoryfor the cooling and the rest of the computer. The details are, rebranded laing d5 pump @ 8.35v, swiftech mcr320 radiator, aquaextreme mp05 waterblock, swiftech mcw30 northbridge block, a mix of thermaltake/zalman vga ramsinks on the mosfets next to the CPU and the stock e6400 heatsink's fan over it. All fans attached to a sunbeam fan controller(including the pump).
3.8 is a bit trickier, I'll have to try more later, but the voltage increase is definately not worth it.
LOL I got relegated to the E6600's... mines a 3060 though! ='(
edit:pm sent
User Name: buckshot
Stability: 10 hours + Orthos
CPU name: E6600
OC: 4300 MHZ
Stepping: 6 B2
Week: L630
Code: A844
Vcore: 1.58
Cooling: Phase
Cooler brand/model: Modded VapoChill LS (Thanks! Jin)
Bios Version: 0908
RAM brand: Crucial 10th Anniversay
RAM actual speed: 1060
Latency: 4-4-4-15
User Name: Comminadian (Replace my other entry please)
Stability: 8 Hours Orthos
OC: 3600 MHz (450x8)
Stepping: 6 B2
Week: L628
Code: B299
Vcore: 1.39v @ Load (1.42v idle, 1.4750 BIOS)
Cooling: Water
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 900 MHz
Latency: 4-4-4-12
http://img209.imageshack.us/img209/1307/450x8pp5.png
EDIT: Delete this post
User Name: Mongoose420
Stability: 10+hours orthos blend
CPU name E6600
OC:3600mhz
Stepping: 6 B2
Week: L632
Code: A734
Vcore: 1.43v
Cooling: air
Cooler brand/model: Theramltake Big Typhoon vx. Custom backplate and bolted through
Motherboard: DFI ICFX3200 T2R/G
Bios Version: 12/22/2006
RAM brand: Crucial
RAM rated speed: PC8000
RAM actual speed: 1010mhz
Latency: 4-4-4-18
http://img267.imageshack.us/img267/9...core6nx.th.jpg
I have an e6400 sl9s9 l626 a773 coming to me in a bit. Hopefully my first experience with C2D is a good one ;). I will edit my post with results ASAP.
where's grim? gone again, i posted last week and still not in the spreadsheet. don't start a sticky if you can't update at least once a week! i try to get my wife on board with the once a week theory too, no go on that front either! grim, don't be a once a monther like some wives out there!!!!
User Name: Ic3man
Stability: 12+hours orthos blend
CPU name E6600
OC:4000mhz
Stepping: 6 B2
Week: L632
Code: A663
Vcore: 1.6v
Cooling: Water
Cooler brand/model: Alphacool Nexxos 64
Motherboard: ECS 680i
Bios Version: P23 (EVGA)
RAM brand: Corsair
Latency: 5-5-5-18
http://img.photobucket.com/albums/v6...4gigic3man.jpg
Upset with so poor info on L631A 6600. Got mine 2 days ago, waiting for the mainboard delivery (damn, a whole month of waiting) P5N32-E SLI. Statistics has plenty of data on 30th and 32nd week, but only couple of results of 31st week. Mine one has L631A640. Hope it's not worse than 3600; if not-will change it. Cooling is Tt BigWater 745.
Heys my L631A500 can do 3600 on air with the P5N32-E SLI.. just haven't benched with it yet cause the temps are so high due to the very warm 26-28C ambient room temp... =D
User Name: fasttruck860
Stability: 8+ hour orthos small FFT's
CPU name E6400
OC:3760
Stepping: 6 B2
Week: L630
Code: A992
Vcore: 1.45v
Cooling: Water
Cooler brand/model: Storm G4, thermochill 120.3, Iwaki MD-RZN
Motherboard: P5B-Deluxe
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 940
Latency: 4-4-4-15
User Name: oxia
Stability: 6 hours orthos (can't do more coz of BF2 ladder)
CPU name E6600
OC:3708mhz
Stepping : B2
Week: L629
Code: B382
Vcore: 1.45v
Cooling: Water
Cooling Brand: Nexxxos xp + Black Ice GT 240
Bios Version: 804
RAM brand: Gskill
RAM actual speed: 824
Latency: 4-4-4-12 (2.15v)
http://img138.imageshack.us/img138/4...rthos129ub.jpg
user name: LCD
stability: 8+ hours prime 95
cpu: E6400
oc: 3.37 Ghz
stepping: 6 B1
week: ---
code: --
vcore: 1.381 set in bios
cooling: water
cooler: --
bios version: f7
ram brand: corsair
ram rated speed: ddr 663
ram actual: ddr 842
latency: 4-4-4-12
I cant get higher than 3400 >< anyhelp will be appreciated!
User Name: Spookz
Stability: Orthos Blend 12Hrs+
CPU name: E6600
OC: 3200MHz
Stepping: 6 B2
Week: L631
Code: A500
Vcore: 1.425V in Bios, 1.33V (Idle), 1.31V (Load)
Cooling: Air
Bios Version: 0302
RAM brand: OCZ
Latency: 4-5-5-15-1T
http://img105.imageshack.us/img105/9...hr131vw9sw.png
** You can replace my previous entry in the Database with this one~ thanks grim! =D
Got to push my 6400 a bit further:D
User Name: The Nemesis
Stability: 12 hours prime95
CPU name E6400
OC:3820mhz
Stepping: 6 B2
Week: L628
Code: B194
Vcore: 1.5v set in bios 1.43vdroop
Cooling: air
Cooler brand/model: Tuniq Tower (Stock)
RAM brand: G. Skill
RAM actual speed: 1000mhz
Latency: 4-4-4-12
http://img.techpowerup.org/070123/E6...me 3820Mhz.jpg
User Name: Farwalker
CPU name: E6600
OC: 3600MHz
Stepping: 6 B2
Week: L628
Code: B368
Vcore: 1.450
Cooling: Air
Cooler brand/model: Thermaltake/SI-128
Motherboard: eVGA NF68 (680i)
Bios Version: P21
Operating System: Windows XP Home SP2
RAM brand: Corsair Dominator
Latency: (Example: 4-4-4-12)
http://valid.x86-secret.com/show_oc.php?id=160739
User Name: Lasse.j5
Stability: Orthos 8 hours+
CPU name: E6400
OC: 3320 MHz
Stepping: 6 B2
Week: L628
Code: B103
Vcore: 1.50
Cooling: Air
Cooler brand/model: Scythe Infinity
Bios Version: 0910
RAM brand: Crucial
RAM rated speed: PC5400
RAM actual speed: 830
Latency: 4-4-4-8
CPU-Z Validation: http://valid.x86-secret.com/show_oc?id=160810
Screenshot:
http://img127.imageshack.us/img127/5063/erwfewf8wv.jpg
keep them comming will update them during the weekend :D
User Name: Blackoberst
CPU name: E6300
OC: 3010 MHz
Stepping: 6 B2
Week: L628
Code: A221
Vcore: 1.25v
Cooling: Air
Cooler brand/model: Scythe Mine
Motherboard: Asus P5B Deluxe WiFi/Ap
Bios Version: 0910
Operating System: XP 32 SP2
RAM brand: Kingmax
RAM actual speed: 860
Latency: 4-4-4-16(2.15v)
User name: Zeus
Stability: 8hours Orthos small ftt's prio 9
Cpu name: E6600
OC: 3603MHz
Stepping 6 B2
Week: L632
Code: A898
Vcore: 1.4375V set in bios ~1.4V real
Cooling: water
Cooler: storm G4
Mobo: Asus P5W DH deLuxe
Bios: 1503
OS: Win XP SP 2 32 bit
Ram: Gskill HZ 2x 1GB
Ram ratio: 6400
Ram actual speed :DDR800
Latency: 4-4-4-12 (2.1V)
CPU-Z validation: http://valid.x86-secret.com/show_oc?id=160879
User Name: j4mes
Stability: 11+ Hours Orthos Stable
CPU: E6600
OC:3608
Stepping: 6 Rev. B2
Code: B368
VCore: 1.35
week: L628
Cooling: Apogee GT (Water)
Mobo: AW9-D Max
BIOS: 13
OS: XP 32
RAM: Corsair XMS 6400
RAM Ratio: 667 FSB: 401x9 @ 802 MHZ
RAM Actual: 802 mhz
Latency:4-4-4-12
CPU-Z Validation:http://valid.x86-secret.com/show_oc?id=161599
stable: http://img178.imageshack.us/img178/614/e638iu0.th.jpg
User Name: sephiroth8748
Stability: 8+ hours prime
CPU name X6800
OC: 3600 Mhz
Stepping: 5 B1
Week: L617
Code: A778
Vcore: 1.43
Cooling: Water
Cooler brand/model: Swiftech Storm Rev. 1
Motherboard: Intel D975XBX2
Bios Version: 2507
RAM brand: OCZ
Latency: 4-4-4-12
CPU-Z Validation: http://valid.x86-secret.com/show_oc?id=161796
Stable: http://s118.photobucket.com/albums/o...rent=bench.jpg
CPU e6400
OC: 3600 mhz
Week L628
Code: B191
Vcore: 1.425
Cooling:Water
Cooler brand/model: TDX
Motherboard: iCFX3200 (RD600)
Bios Version: 12/12
Operating System: Win XP Pro
RAM brand: Crucial 10th Anniversary
RAM actual speed: 1004
RAM voltage 2.25v
Latency: 4-4-4-12 and 4-4-4-18
http://i27.photobucket.com/albums/c1...00stable-1.jpg
http://i27.photobucket.com/albums/c1.../8hrsprime.jpg
Update:
User name: Zeus
Stability: 8+hours Orthos small ftt's prio 9
Cpu name: E6600
OC: 3700MHz
Stepping 6 B2
Week: L632
Code: A898
Vcore: 1.525V set in bios ~1.49V real
Cooling: water
Cooler: storm G4 - Thermochill PA120.2 - laing DDC+ w/ Petra's top
Bios: 1503
Ram ratio: 6400
Ram actual speed DR822
Validation: http://valid.x86-secret.com/show_oc.php?id=162248
The weekend is over and no update:confused: :stick:Quote:
Originally Posted by oxia
arf, sorry i did not read the first topic. Only screen @ 6h with orthos.
again sorry.
Update :D
Using the new bios I can now run the ram with 2.15V :eek:
more droop with the 1004 bios?? :confused:
User Name: GrimReaper
Stability: Orthos 13hours+
CPU name : E6600
OC: : 3510MHz
Stepping: : 6 B2
Week: : L630
Code: A528
Vcore: 1.472 (Real at load ) (1.525 Set in Bios) Soo much droop :(
Cooling: Air
Cooler brand/model: Thermalright Ultra 120
Bios Version: 1004
RAM actual speed: 975
Latency: 4-4-4-12
http://img265.imageshack.us/img265/3708/grimocwf2.jpg
Farwalker
ThermalRight SI128 :P not thermaltake lol
Blackoberst
congrats on being the 2nd 6300 :D really amazing chip :O 1.25 and 3GHZ :D
Shifty come company for you lol :P
RD600 comming into the List and doing well :D
Note--must have atleast 8 hours of Orthos/Prime Small ffts or Blend.. should be running will not accept stopped or crashed results :toast:
Keep them comming :toast:
Thanks Grim!!!! <3
Thanks Grimm! :) Shifty won't be lonely anymore :D. Unfortunately it's max for my E6300 at that voltage. I wanted more :D.
And I noticed now that there is a bigger drop with 1004, 1.2650v in BIOS, 1.22v load. On 0910 I had 1.265v in BIOS, 1.25 in load. Damn, Asus did it again. :slash:
But seems to be stable even at 1.22v load, running Orthos now. On 910 wasn't stable at 1.22v load. Weird.
