Go IHS mod :D
Go IHS mod :D
hi, i have an Opteron 144, he makes 2900mhz@1,45v but when i go higher to 3000mhz he needs 1,61v -.- and all over 3ghz is unstable, i have an dfi lanparty ultra-d, cpu without IHS and bh-5 rams. Can some one give me tips? or better timings?
http://img84.imageshack.us/img84/2963/xspost2kw.jpg
Have you lowered your multi and tested your ram for max clocks? Might be the ram that's causing instablity. Try tref 3684, drive strengths at 7/1 and maybe play with mal and rp settings. Also, I'm completely stable at 3.0ghz, but even with more voltage can't get past 3.05ghz. You might just be at the cpu's limit. Good luck. :)
HAHAHAHAHAHA....try 33 minutes ;) Look at his start time, then the time on his clock, then the time/date of his post :clap: :clap: :clap:Quote:
Originally Posted by thunderstruck!
http://img62.imageshack.us/img62/762...me30ghz7hg.png
My little Opteron 146 seems to get better and better over time.
50% overclock on stock voltage is pretty nice in my book:
http://img.photobucket.com/albums/v6...3GHzstockV.jpg
Load temp is only 30-31C
Just on plain water and 20C room temp.
Does Prime up to 3170MHz and SuperPi 32 at 3230MHz (see sig) but won't run 1M over 3260MHz -- have to work on that. ;)
http://img356.imageshack.us/img356/7098/31265df.th.jpg
Always on air with xp90
Zeus not bad ;)
Nice chip there littleDevil.
heya, does anyone know if the early cabne 0530 apmw's were known to be cold bugged? in general? what about for a single stage to -20º?
Hey dude
Should work fine on -20c core :)
They do DICE too i think, should get to -35c or so with pretty high HTT. Not very coldbugged compared to latter Opterons
this step does not coldbug a lot:
nearly at 360htt for -20°C I think
thanks guys, any body else?
OPB's currently got this cpu. He'll be testing it on his cascade tomorrow and if it's fine at those temps, you'll be seeing it on my -120C autocascade. Also, OPB should be receiving #0001 any day now ;) Time for some single core Opties to give us some more mind boggling numbers :wth: If anyone's interested in purchasing this cpu, drop me a PM, but I warn you....it's not gonna be cheap. On SINGLE STAGE:
http://www.ocxtreme.org/onepagebook/...op154tpmw2.jpg
http://www.ocxtreme.org/onepagebook/...p154s34g8m.jpg
http://www.ocxtreme.org/onepagebook/...4sbh535g1m.jpg
http://www.ocxtreme.org/onepagebook/...sbh535g16m.jpg
hahah nice steven. again folks, someone is asking me about cold bug info, this time on the other chip i have for sale, opb will recognise it.... CABYE 0543
http://mail.kilter.com/ftpclients/ma.../CABYE_ihs.jpg
and the one from before
http://mail.kilter.com/ftpclients/ma.../CABNE_ihs.jpg
yep, i really want someone to buy these chips and put them under sub-ambient. i wanna see em SHINE!
dude. OMGzzzzzzzz :eek: thats pretty good in ANYONE's book. can i ask how you have trained it so well that it can do these things? get better over time? do you TSST it? DOMINATE? like the dog whisperer did to cartman? if there was something you have been doing over the course of the chips life, please let me know! i'd love to train mine into submission!Quote:
Originally Posted by Zeus
Originally Posted by el rolio
Ghehe, i'm gonna learn it to fetch and sit up straight for me. :D
Seriously, i burned it in with Prime95 for a couple of days when i first got it and a few weeks ago i decided to chop 'n pop it's top.
Beside that, the daily abuse (3GHz at 1.4V) seems to be enough to make this chip what it is now.
From now on it will run 3GHz at stock voltage 24/7.
I hope the max benchable frequency will go up in time as well. :)
Btw, going back some 180 (!!) or so pages back you can see how it performed when i first got it, it did Superpi 1M at 3GHz stock voltage and that was pretty much all.
Still not bad but it improved a hell of a lot over time.
aww man! i wass hopin for some super voodoo style where you remove 10mv every month or so and prime for a day and then you eventually get back to stock volts.
soooooooooo dissapointed! :P
thanks fo the reply. we'll see what my chip does for me. its at home priming and curing the AS5 at stock volts, 290x10
Sorry mate, can't make it any more beautifull than it is. ;)
I've had a friend tell me about the CABYE 0543's. He tells me that they bug @ ~-40Core IIRC. The ONE CABYE Opty I tried barely booted @ -50C Windows temp @ 1.60V :rolleyes: I actually had to turn my autocascade OFF with the cpu running in order to get "hot" enough so I could boot. The chip was able to run OK (300HTT) @ ~-30C core temps while my unit was off :p:Quote:
I recently had to swap out the RAM in my 144 folding box, & start from scratch to get back to the 2.6Ghz it was at (I think @ 1.45v). Managed to get 2.9Ghz this time @ 1.52v, but using a divider since I have dirt cheap 2x256Mb sticks in there now (they could probably handle more than 214mhz but I haven't had time to eek any more out of 'em). Its been folding 24/7 since and hasn't budged @ 40c :D Some great OC's in this thread.
my 0543 starts to show issues @ 10c. it actually clocks better on air than water. took 1.75 @ 4c for 3350mhz, primed for 2 hours. and then my board tossed it's cookies. I just got a 8L res for my chiller, so I'll be trying again soon.Quote:
Originally Posted by s7e9h3n
This is a 148 CABYE 0543 ive had. Stock Mach II and around -20 idle in MBM.Quote:
http://img.photobucket.com/albums/v6...oc/148test.jpg
thanks man, awesome clockage. like i said to my window shoppers... throw 1.6v at these chips and let me see em FLY!
This is the only screen i have for you unfortunately. This was max 1M with this vcore. It did a little less then me 146 and sold it. IIRC coop put one under dry ice and had great 32M results, screens included.
