Guys, what the hell is this?!
With both RF0401 (earlier) and MF1201 (later warnings). The last time i had to stop occt ram test because dram ref voltage stayed high for seconds! This is scary...
Please say it's a sensor bug or something.
Settings (MF1201):
Code:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : 08.0
- Ratio CMOS Setting :
FSB Frequency : 447
PCI-E Frequency: 100
DRAM Frequency: DDR2-895
DRAM Command Rate : 1T
DRAM Timing Control: Auto (5-5-5-18)
Ai Clock Twister : Strong
Transaction Booster : Auto
(these are all bios settings, not "real")
CPU Voltage : 1,33125
CPU PLL Voltage : 1,60
North Bridge Voltage :1,71
DRAM Voltage : 2,18
FSB Termination Voltage : 1,40
South Bridge Voltage : 1,100
CPU GTL Reference : 0,63x
North Bridge GTL Reference : 0,67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1,55
Advanced CPU Configuration
CPU Ratio Control : 8
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Disabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
Earlier had weird drop problems with SB voltage (when occt, sb voltage dropped to approx. 0.5V for a moment), upped the SB voltage (and SB 1.5V voltage) and the problem disappeared.
These voltages are not final (most of them are more than enough), system has been unstable, after upping PLL it's been stable but these problems appeared. Too much PLL? Less is unstable though (crashes after 19min of occt ram).
