Originally Posted by
mc2k
I know this is already been adressed but I never thought it will occure at "low volts", the prob is regardless FSB I put, as soon I put in BIOS any value higher then 1.4000v Prime95 under Small FFts wont run 99%( anything lower it would, lucky that my Q6600 @ 3.825ghz is stable @ 1.400 BIOS set and it will load 99%, but anything higher then 1.4000 BIOS set, it will load 87% and the rest goes to system. I found out while I was testing for 445x9 ( 4.01ghz....., to confirm this that it isnt FSB related I tried 400x9 and put 1.450 BIOS , also the same prob)
However If I run Blend however it will use 99% of the cpu usage assigned to Prime.....
Could be the BIOS or I got a Dudd board ?, I am on 0802.
