What was the room temp? CPU at 51c and PWMIC at 32c on a Ultra-D usually means environmentally controlled room. ;)
Hello, I have bought a new opteron 148 with stepping CAB2E 0604CPMW
What can you say about this opteron?
Opteron 146 CABYE 0540FPBW :D
http://img286.imageshack.us/img286/8...u1m35040fp.jpg
http://img258.imageshack.us/img258/2667/cpu36320aa.jpg
1,9v omfg :D
This shot is from another forum with a 0604cpmw.Quote:
Originally Posted by squaresoft
i see some of u guys clocked to 2.9 on ur opterons and getting sub 30 sec superpis, for some reason at 2.9 im only pulling off 31-32 seconds
Just received an Opty 146 from Monarch - CACJE 0606MPMW. Anyone tried OC'ing this stepping? If so, please post your Hz and Volts. Thanks
There are X2 LBDHE0606APMW known.
Under Dice up to3,6Gig under water around 3Gig.
Dude, with 2,9GHz u should easely get sub30. Get some decent dual channel RAM clocks and u will get it.Quote:
Originally Posted by xerogenesis
Here's an update - currently "toasting" at 2.95GHz with 1.6v on air. :) I'm tempted to see what it'll do naked on water...Quote:
Originally Posted by RekLess
It ran 4hrs Prime at 2.8G/1.42v.
CACJE 0607 EPAW
http://img140.imageshack.us/img140/7753/275cp.jpg
http://valid.x86-secret.com/show_oc.php?id=89626
2.8ghz stable with 1.35V for 24/7 :banana:
eraser, where did you get your chip? It looks like this year's week 6 and 7 chips are pretty strong.
Opty 144
CAB1E 0605 GPBW
3010mhz@Vstock
Aircooling Xp90
http://popol55.no-ip.com/~popol/hfr/...010@vstock.jpg
Max screen aircool :
http://popol55.no-ip.com/~popol/hfr/...3453@1.648.jpg
http://valid.x86-secret.com/show_oc?id=86710
temp room 17°c
processeur : 38°c
Opty 144
CAB1E 0604 CPBW
2900mhz@stock
3030mhz@1.504v
Aircooling Xp90
temp room 25°c
http://popol55.no-ip.com/~popol/hfr/...900@vstock.jpg
http://popol55.no-ip.com/~popol/hfr/...3031@1.504.jpg
Opty 144
CAB2E 0610 GPAW
2874mhz@stock
2970mhz@1.536v
Aircooling Xp90
temp room 25°c
http://popol55.no-ip.com/~popol/hfr/...2874@stock.jpg
http://img241.imageshack.us/img241/2...97015368vo.jpg
:toast:
From france :clap:
Omg this makes me want to try 144 even more :O
I presume IHS was still on ?
No IHS mod :DQuote:
Originally Posted by neoman
Got this 148 yesterday, still testing it out...
http://img137.imageshack.us/img137/7...ime29006vy.jpg
It's a CACJE 0544 EPAW... Does 3050Mhz stable @ 1.45 but my temps are wayyyy high... Is it usual ? I have about 40º idle and 54º full with 1.45v, cooling is a XP90c + Tornado 92mm... My Venice wouldn't do more than 39º @ 1.6v with the same cooling... Already remounted it 3 times to check good contact and thermal grease, all's fine...
I can change it for a 148 CABYE 0536 GPMW what do you think ?
It's the same for me with my xp90.
> 1.5v my temps are very high, 40° idle and 55° in full
Opteron releases more heat than the venice :(
Try maybe an IHS mod :confused:
Amazing stuff man, nice one :toast:Quote:
Originally Posted by popol55
My first Opty was a 144 CABYE 0536GPMW, I think most people who had one will tell you not to bother :p:Quote:
Originally Posted by God_Lx
8x coeff, for fun, max htt maybe
http://popol55.no-ip.com/~popol/hfr/144/cpu-3414.jpg
First Post Here:
AMD Opteron 144 CAB1E 0604 CPBW
3GHz @ 1.44v :banana:
http://img146.imageshack.us/img146/1...mins7pp.th.jpg
MD Opteron 144 CACJE 0604 APMW
Is it good and are there anyone who have test one?
I don't have that stepping, but it sounds like a really good one from the info that you've given. ;) I've seen some APMW CPUs do really good and CACJE seems to clock good when aircooled.Quote:
Originally Posted by Smy
I have a problem, my opteron cab2e 0546gpaw, have high temp than X2 4400
whate cooling
X2 4400@2500 temp idle 31º
Opteron 146@2800 temp idle 34º
i look the temp whit ite smart guardian of DFI
I'm sorry if I don't see your point, but who cares about idle temperatures?Quote:
Originally Posted by white_zombie
Show us the difference in load temps, then we can talk about a real difference. BTW, no CPU is like the other, thus temperature values can differ quite a lot from one to the other.
in load its 7º high opteron than x2 4400
