how do you start the PSU which is hooked up to the drives?
do me a favor...disconnect the drives and dvd drives from the board (just unplug the SATA cables)...now, don't power up the 550W supply...just power up the main supply that runs the mobo, cpu and VC...hook some of your fans up to this supply temporarily, for cooling...let us know how that works out.
EDIT:...i presumed you use this type of PSU array in your previous rig with the same VC?...correct?
