P5B Deluxe No Post, No Boot, No Screen
I was running perfectly stable(12+hrs) Orthos at 9*355 and I decided to try and
run 8*400 so I could run 1:1 RAM. When I applied the settings everything booted fine and loaded windows properly. Once I was in windows I started Orthos to test it at the new settings and it froze after ~20sec. Ever since it froze I have not been able to get it to boot again. I've searched a lot and tried numerous fixes posted by people with no results. I'll list what I've tried.
1. Initially just jumpered the reset CMOS for ~10sec, nothing
2. Removed battery and jumpered CMOS, nothing
3. Disconnected all CDROMS and hard disks, nothing
4. Removed all RAM and booted it with none, then rebooted with one stick, nothing
5. Left the power off and unplugged all night, nothing
6. The one last thing I'm trying is leaving the CMOS battery out and the jumper set all day while I'm at work.
Also, ever since it froze when it boots new it will boot the turn off for a bit then reboot. Almost like it does when you apply new clock settings. I'm really at a loss for what to do and would appreciate any help/advice. Do you think the board is dead and if so what new board should I consider without dropping $300. Thanks!!
