Got a CACJE 0605BPBW today, went straight under my XP-90 and a Delta 92mm @ 2800rpm.
http://img239.imageshack.us/img239/4...20041xi.th.jpg
Just a shade under 2.9GHz at stock volts.
Will keep playing with it...I'll be back when I reach 3G :cool:
How about this: Opteron 144, CAB1E 0604.
Stange stepping?
I've seen Cab1e on an FX something or other once and some dual core opty's, but never on a 144.Quote:
Originally Posted by Electroid
It should be pretty good.
Dayum! :eek: All these CACJE steppings doing extremely well. I've got an Opty 148 comming with 0601 CACJE stepping. Hoping she'll give me the 3Ghz with ease on water :cool:
Best of luck to you :up:Quote:
Originally Posted by Nebulous
Here's my 3G shot:
http://img155.imageshack.us/img155/9...z32m1sf.th.jpg
Prime stable at ~2990.
i have it, 1,5v 3 ghz prime with airQuote:
and max i managed to bull out was 3269 mhz with AIR cooling and SuperPi of 25,406 :banana:
Hey guys need your opinion. I getting bored with my oc and I'm going for 3ghz but I am only getting stability after 1.68v in bios and 1.64 smartgaurdian my temps are 45c load and 55c for the pwm. Am I safe???? Sort of? Not at all? Let me know what you think.
45 @ load is safe, pwm temp could be a bit lower. I d say ur safe
Not meant to cramp your overclock, but it's so clear that you cheated on SP2004 (prime lite) since you claim (and it shows in the time elapsed) that it's been running 24h, when the scrolling bar is so very large. Looks more like 1h at most. Just making an observation.Quote:
Originally Posted by @_dud
I always thought that pwm was good up to like 70-80c. Even though most peoples are much lower. That is really the only temp that worries me. I'd like to put more voltage, but not sure how the cpu will react I've never reallly figured it out I guess because some people say that you can keep uping the volts as long as the temps are good, but then some say otherwise. What do you think?
http://sponge.ez.pri.ee/data/media/3/25.407.JPG Aircooled with estonian cold air ~5*c + zalman9500+
Get a fan blowing over the RAM/ PWM area, 55C is pretty hot although with dualcores 60C is a common occurence.
PWM is regulating Vcore, having this IC blistering hot will most likely influence Vcore stability.
I feel unconformtable with PWM ic temps over 40C but i'm a bit paranoid i guess. :D
edit: Uh Sponge Bob posting in between huh? lol, nice result man but at 3269 i get 25.078 , can i have some Estonian air please? ;)
After like lots and lots of days of burning in and testing i was finally able to get my 3ghz oc stable. I realized that the major limiting factor was heat, if it got over 54C it would fail prime and sp soon after. Hits a pic of 3ghz 3 hour stable on sp2004.
http://http://img206.imageshack.us/i...ble155v8hp.jpg
I have no idea how u guys can oc ur opty's so high, its ridiculous. Is it the cooling? Good steppings? I had to work hard just to get to 3ghz. :confused:
2x512mb Gskill GH BH-5, i am using 2x256 corsair pc3200 memory :P and 1gb vs 512 is about 0,3-0,4 in superpi :fact: My UTT (teamgroup 2x512)acts crap, 3,4 v 250 mhz and 3,5-3,6v no go :OQuote:
Originally Posted by Zeus
Get rid of the heatspreader, this chunk of metal is holding you back big time, second is cooling, overclocking is all about voltage and cooling. ;)Quote:
Originally Posted by smartasien
Yeah, Bank Interleave gives a nice boost.Quote:
Originally Posted by sponge bob
Did you mess around with Data/drive strength on your Team group RAM?
These two settings seem to be related to Vddr.
BH-5 that doesn't even like 3,5V is a bit hard to imagine.
Right now, wondering whether i should remove IHS for cooler temps, isn't it supposed to make a huge difference? How risky is this btw? i don't wanna like cut off a transistor...
Use the "search" function, there are a few threads about this subject.
If you take your time it isn't that hard at all.
what do u advise for data/drive strenght ?Quote:
That's hard to tell, every memcontroller-RAM combo reacts different.
Mine for one seems to like 7/1 best with BH-5.
Start of with auto and tweak from there.
Opteron 146 CAB2E 0604 DPAW retail box just shipped from the egg.
Was able to run Prime Torture Test all the way up to 2.96 at 1.4v.
To get it Prime stable at 3.0 I had to raise vcore to 1.45. But I don't think
it's the cpu giving out yet, Just topping out this ASUS A8N Sli Deluxe.
Guess I need a to consider a better motherboard at this point.
Is the DFI LANPARTY UT nF4 Ultra-D still the best bang for the buck if you don't need SLI?
Opteron 144 CAB2E 0602GPMW
DFI Ultra-D
2GB OCZ UCCC
http://img.photobucket.com/albums/v6...3150SP2004.jpg
OMFG thats sickest opteron 144 aircooled result so far i think
Wow, is that watercooled?
51C is blistering hot but 3150MHz prime stable for 13 hours is very nice! :up:
Opteron 146 CABYE 0540FPBW - Liquid Chiller CPU@+3°C
http://img223.imageshack.us/img223/8708/cpu35112rp.png
http://valid.x86-secret.com/show_oc?id=89153
The Prime ran 24hours?something wierd on the screnie:D
