Coop: Temps arent the problem, it idles 27 and full load is 35-36 with 1.57v
@turbox997, they are only about $10.00!
@neoman, that is a good temp, but for example when I did the 3.1ghz one above, I had to keep it below 20-21c. What type cooling did your friend have and at what temps when he was doing 2.8? Have you ruled out memory or other setting?
144 Opty CACJE O6O2 GPMW This is a great chip capable of 3ghz stable. I have been having real problems getting any divider besides 100 stable. Well, with the new 3/29 bios I think I've got it. :woot: Here's 9x334 32m with 150 divider putting memory at 250. Now I just have to work at getting the mal and rp lower.
http://img136.imageshack.us/img136/1...x3344hu.th.jpg
Sorry I posted this in the other thread also, but:
If I buy either an A64 3700+ or an Opteron 146 today, which one will have a better chance to hit 3GHz on air? (under ~1.60V, preferrably under 1.55V)
its very hard to tell. Id go for 146 since they have better memory controllers also.
Don't think so. ;)
I would always prefer the 3700+ because of the 11x multi.
That 11 doesn't mean anything...
I would choose the Opteron anyday!
Go with the opty. Even with 9 multi you can still get there. I can go higher than this with more voltage. Look just a few posts back and see a 3ghz 32m pass.
http://img384.imageshack.us/img384/9...x3393xq.th.jpg
I really like your results, 4X4N! I just got a very similar 144 and I'm getting the Sapphire RD580 card tomorrow or the day after. One could guess it could do as well as yours, right? :D What is your cooling?
http://img.photobucket.com/albums/v2...astein/144.jpghttp://img.photobucket.com/albums/v2...n/TCaseMax.png
http://sponge.ez.pri.ee/data/media/3/UUSREKORD.JPG NO COLDBUG finally , + dcie ! Evil & spongebob
http://sponge.ez.pri.ee/data/media/8/OC_022.jpg
Right now it's in my other ultra-d, (AD0 version) with just an xp-90 and panaflo fan. I think I'll pop the lid on this and use my big typhoon. I doubt that I'll get much more out of it, but I'm sure the temps will drop.Quote:
Originally Posted by Marlowe
EDIT: Very nice sponge bob :toast:
Not? U will love the bigger multi everyday, believe me. :rolleyes:Quote:
Originally Posted by ugp
On my system the 3700+ with a 10 multi can't handle prime95 with 3100MHz, doesn't metter wich voltage or settings, and with 11 i got this - http://213.202.211.105/gravedigga/05...263mhz_BH5.jpg
U must think, that there can stop u overclocking something else, then the physical limits of the CPU. ;)
Even the 146 is more expensive then the 3700+ here in euroland.
hi.
first post here.
Opteron 146 0546 GPAW + XP90/Enermax 92mm
DFI Ultra-D (623-3)
2X 1 Go Gskill PC4000HZ
OCZ Modstream
Hope i can do better. Just waiting for my watercooling system.
http://img86.imageshack.us/img86/3069/f300011uz.th.jpg
http://img86.imageshack.us/img86/4614/f300024lu.th.jpg
Prime stable.
;) from France
Here's my Opty 146 CACJE 0603fpmw
http://www.dfi-street.com/forum/show...&postcount=170
Hey funkflix, that's nice 3700 you have there. I'd keep it, but I believe it's the exception to the rule.
Opty 144 -1.425v@3.0ghz 34hr prime stable on air.
http://img62.imageshack.us/my.php?im...me30ghz7hg.png
@dud, that is really decent.
What stepping? Thats is really an amazing chip :fact:Quote:
Originally Posted by @_dud
CAB2E 0602 GPAW
I like it. :D
And the Wafercharge?
CAB2E0602GPAW
XXXXXXXC60XXX???
does the first line matter? what's it for?
anyways it's 140076AA60093.
Both are important.
Memcontroller>CAB2E0602GPAW<important
Wafercharge important>140076AA60XX<Batch not so interesting.
what about the first line ie. OSA144DAA5GN?
Just CPU model number, means you have a 144.Quote:
What board & memory is that with dud??? I'm having real trouble getting my once 3.0ghz stable opty, stable again on my DFI Expert.
It is a DFI NF4 ultra-d, and the memory is value vx, but they are on a really low divider and not with any OC during the screenshot.
