Oh do you mean that you can't change any values? I noticed this...thought maybe it was the fact I was using XP x64 cause it was wierd. :shrug:
There is information that memset don't work bcos of 14bios - on 12 memset works. But there was old version of memset. What about new ones, especially beta?
Might try powering off the PSU, then holding down the power button for the mobo for 10 or so seconds. This will discharge the capacitors on the motherboard and give it a fresh start. I've noticed sometimes my CPU temps become locked (BIOS reported CPU temps don't change) at one temp and the above process gets it going again.
Thanks man. I thought my windows install went bad so I reinstalled windows but then I had no internet connections so I reset my Cable modem and router but I still have no internet connections in windows. When I unplugged that 4 pin power lead my GPU wasnt powering up either. If I cant get my internet working on the motherbioard by 2pm tomorrow Ill RMA the motherboard.
Tried that and tried reflashing to bios 16 b04 but my ethernet still doesnt want to work. Think Ill have to rma the board and reassemble my AMD machine again :(
Well its now up and running and it came with bios 14 on it. Ive done the bolt mod and my pwm is 34 idle. I also used the mx2 paste on my cpu and it dropped my temp also. So now if i wanted to hit 3.4 Ghz what should i be looking for settings wise as im also gonna run 4gb of dominator 8500 ram so i will need more volt on my nb. And what divider should i use to get my ram close to 1066Mhz ???
Thanks Paul
Try this one:
memtest86+-1.70.iso.zip
Or this one:
memtest86-3.4a.iso.zip
Both will need to be unzipped then the iso burnt to a CD, boot up from the CD and they give test options. It won't run in Windows as it would only interfere with the testing.
Hey,
My computer will not start... kind of. It boots, I get power to the mouse but screen is completely blank, can't even go into the bios.
ABit code is 7F
Any ideals?
Never thought of doing that Ace. I will try that tomorrow morning. Its 1:23am here now and im tired. I dont want to mess things up even more.
received a message from Gary Key of anandtech.com fame, AKA, bingo13 here in XS forum.
he said, abit will have another beta bios release in about a week...once gary tests it, he will post the link for the bios in this thread.
I think we had enough with the beta bioses. It's about time they sit down and deal with a new one which will solve the matters with memory and wolfies
poor mans oc on bios 14. 1.44mch, ich 1.12, vdimm 2.00v 5:6, v 1.69 (real 1.65v~)
1m super pi, hit sub 12's
http://img2.freeimagehosting.net/uploads/9076480f67.jpg
as high I can get this sucker on air, after 458fsb hits wall without vdroop m od.
Could browse, surf net though etc.
yup this chip aint that great. Waiting for E8600 to come out before i do something new
anyone have a spare bios chip from a broken board/boards... mine is totally :banana: :banana: :bananal: :bananal: :bananal: :banana: :banana:ed
6 bucks plus shipping http://www.uabit.com/WebStore/produc...1e4qv5aodq1752
Hi Joker im on air and @ 3.2 my temps where about 37,36,38,38 with 1.32v so im guess they will be about 40 or more with it higher. I have just used some MX2 grease and have now got two 2000 rpm 120mm fans on my thermalright cooler so i hope this will help keep it below 40 or so.
