Nice overclock...
What is the RMA Replacement document on your desktop? LoL...Something break?
Nice overclock...
Gskill ram that I sold to chew and someone took.:( Guess I need to take that off the desktop.:rolleyes:Quote:
Originally Posted by ugp
Did this today. http://img85.imageshack.us/img85/4192/pm5hs8kc.th.jpg
17c... lol that's awfully cold, chilled water?
or bugged temp reading?
Chilled.
How do you get smartgaurdien? what kind of program is that?Quote:
Originally Posted by coop
It's on the DFI cd...Quote:
Originally Posted by TVFREAKAZOID
If you lost it I can send it to you if you wish :)
yea, its on your cd that came with the mobo, or you can download it at dfi's websight.
While i had my system apart to change my ancient RBX for a Swiftech Storm block i could'n resist the temptation and popped the spreader. :)
Temp dropped a healty 5C under load, cpu can now do things it couldn't do before:
Im getting a opty 146 tomorrow wich will run 2800mhz @ 1.38v :) i will test that and try to Prime @ 3ghz
Oh really??? Well I put in the cd but for some reason it won't open. If you could send it to me that would be great.Quote:
Originally Posted by Garrett
I have another question. I realized that amd has a damn patch. I didnt' know about this. It also has to do with registry keys as well and I'm not that technical with comps. I'm a newbie. I did download the amd patch and microsofts hot fix as well. I guess someone else did a zip file of the registry key so that way it would save us the trouble. But I was told that I would have to do something with the boot.ll or something like that. So what do I need to do first? Install the amd patch, then the hot fix, and the regisrty key? What order do I need to do it in?:confused:
Finally had to go to bed. New bios is nice! 3hrs@3100 with 1.408v
http://img464.imageshack.us/img464/5...m3hr6yd.th.jpg
Over 3hrs@3200 with 1.52v
http://img464.imageshack.us/img464/1...2mpm9ef.th.jpg
http://img464.imageshack.us/img464/3...2mpm7kt.th.jpg
This Opty sure got some bawlls since i removed the HS:
http://img.photobucket.com/albums/v6...rime3170-2.jpg
New Storm block must help as well, gained 120MHz for Prime 95. :)
Go pifast @ 3300... you can do itQuote:
Originally Posted by Zeus
Awaiting my new RAM from RMA.
Kakaroto had trouble with his testrig for testing my new pair. :(
Once here, interesting shots will be taken. ;)
Zeus after removing IHS ur using Shim also ?
No, no shim.
The Storm waterblock has a very good mount without it.
Atm i have IHS removed but im afraid of put it on naked . I have TT SE watercooling . I dont know how well does that CPU block suits with my CPU .
Can you give more info on this "new bios" ? I haven't heard of it, is it on the DFI website? I'm currently using 704-2bta, its nice and stable I guess, but none of the ram dividers can suit me on a x10 multiplier. If I use 623, then its not stable for some reason...=/
I flashed my bios 4 times in 24 hours...is that bad?
Im confused now. I removed IHS and it helped with temps but i didnt gain anything with overclocking.
I got that chip from my friend who was running it @ 2800mhz with 1.39v prime stable on Dfi lanparty .
I cant even run 2800 prime stable @ 1.55v ........i have Epox 9NPA+SLI
Opteron 146 CAB2E 0546GPAW
And what means HT Width in bios ? its 16 up and 16 down. What does this give.
Ok, now what is the difference between the DFI.com driver date code 11/14/2005 and the DFI-Street.com driver 704-2bta???? I have the DFI.com driver date code 11/14/2005.Quote:
Originally Posted by turbox997
hello there, this is my first post
i want a computer to play (nfs:mw, quake4, bf2 ...)
i thought about this:
opteron 144 (cause its got 1mb L2)
7600gt(not yet in romania, i am from romania)
2x512 geil ddr400
i saw u guys do some really nice oc-ing on the opty over here ...and
i have some questions:
1). [in games] is it worth the difference between athlon64 512k and opteron 1mb cache?
2). how much can 144 go with stock cooler ?
3). is it worthed getting hyper 6+ or thermalright+vantec tornado,scythe or what would you reccomend?
i dont have any experience with oc-ing, but i like to believe im a fast learner :D
please help
zpimp,romania
I've been fortunate enough to get my CABYE Opty148 upto 2.82Ghz (11x255) @ 1.375v and a maximum of 3.03Ghz (11x274) @ 1.45v
I have not gone to the max of 1.55v yet though. Until I have something better then the stock fan, it will have to wait.
The best PC upgrade in many a year....
@turbox997, you can find it here. http://www.xtremesystems.org/forums/...51&postcount=1 It has some updates and convenience features. I found I could run Prime for a longer time. I like it. I had to 'reset cmos' with this though. Never had to do that before. I used 623 for quite some time, then 11/14 for a couple weeks prior to this one. This one is very nice, and no, as long as you do it correctly.
@neoman, you have to keep it cool. 1.55v makes more heat than 1.39v. Yes, if you are on the line, a couple degrees will make a difference. Also maybe you will still need to configure your board slightly.
@TVFREAKAZOID, 11/14 is a dfi bios. The 704 is a modded one. Many people like it. I did not.
@zpimp, 1) yes 2) some 3)yes. Read what some others use for air cooling. It has come far and works very well.
@Jacksn, nice job. Do some research. It seems you have a good cpu. Get a good fan and get the most from it.
@coop, you the man! haha, answering all the questions in one beast post! Thanks for the info, too bad I don't have a floppy disk drive on any of my computers! I guess I'll have to wait for Tmod or someone to press a CD.
