http://www.pic-upload.de/12.03.09/4ic7y2.jpg
http://www.pic-upload.de/12.03.09/etbsbs.jpg
building my new rig...
Ordered some of that dynamat/akasa noise dampening material a couple weeks ago from Crazy PC and finally got a chance to fight w/ it. Wicked sticky stuff! But it covered the poor stacker's lame grayness and got rid of the directionally variable high frequency whine from the raptors for about $10 so I'm pumped! I think the next step from here will be to paint the exterior. I'm thinking yellow w/ black stripes. :D
http://img.photobucket.com/albums/v2...k/IMG_2890.jpg
If you don't watch out, that GTX is going to eat your apple. :P
@OverDozed - Is this soundcard that should be put on PCI-e then you just used some connectors? What do you call that kind of connector and where to find it? Thanks
http://img99.imageshack.us/my.php?image=4ic7y2.jpg
It's a Bernstine Audio Card that comes with DFI high end motherboards such as UT or LT series. They connect by a special connection only high end DFI boards have. I believe it can not be used in other motherboards. Just think of it as onboard sound on a little card itself like that Asus Supreme FX.
Some last minute pictures before i7 upgrade.
http://img22.imageshack.us/img22/904/24965387.th.jpg
http://img7.imageshack.us/img7/3594/93822843.th.jpg
http://img18.imageshack.us/img18/9337/24958999.th.jpg
http://img18.imageshack.us/img18/131/19499714.th.jpg
http://img12.imageshack.us/img12/9209/45819964.th.jpg
http://img12.imageshack.us/img12/2898/31326735.th.jpg
http://img21.imageshack.us/img21/9225/12279063.th.jpg
Looks like a contender for... you don't wanna know... Guess we all have our own tastes :)
Mate props to you, that is a SENSATIONAL setup.
I've never seen that done before... actually now i think about it friends of mine are into car audio in big ways i should go chat to them about their materials as they are forever pulling setups in/out so an abundance of deadening would be easy to get.
Looks very professional and very different... would go well with some PC's im building for a bit of a special look!
Sorry? What have you do?
Overkill :shocked:
funniest part is the stock intel heat sink.
OMG! how did you manage to get two hr-03gt on one card ? Overkill.
Wow thats just awesome and overkill :clap::up:
jbl2226h, HR-01 HSF? That's one of the HSF's I'd like to get someday, or just one where 2 fans can be mounted easier.
http://img.photobucket.com/albums/v2...pc_interno.jpg
I cant put the side window with Hyper212 :(
