I err...whats after quadruple :D
5Douple? (umm no)
Awesome rig trouble what did you put to cover the drive bays and on the middle divider? i like that alot is it black acrylic?
cheers
It is ac ryan black acrylic. The sata cables are these one: http://www.revoltec.de/english/produkte/rc049.htm 1st on that list.
What did ya use to cut the acrylic dremel?Quote:
Do you mind if i copy ur idea but with blue panels?
It was the store where I buy some of my stuff that did the cutting, so i really don't know how it was cutted :|
You can copy all that you want :)
trouble me fav shot is the one with ur kid!!!! teach em young
Last revision with this stuff:
http://img48.imageshack.us/img48/4328/dsc06300qi9.jpg http://img48.imageshack.us/img48/7647/dsc06302jb0.jpg
http://img64.imageshack.us/img64/79/dsc06306wz5.jpg http://img64.imageshack.us/img64/6088/dsc06305sy1.jpg
http://img77.imageshack.us/img77/7509/dsc06304jb6.jpg
http://img77.imageshack.us/img77/9886/dsc06307ii4.jpg http://img64.imageshack.us/img64/9964/dsc06308to2.jpg
http://img64.imageshack.us/img64/5053/dsc06310dt2.jpg
New blocks on way :)
very nice and clean setup..keep it up..
Lol so i should keep my jigsaw then? I'm still going to purchase that angle grinder you recomended only 40dollars with postage very cheap.Quote:
Your probably gonna hate me for this but...you could probably use your jigsaw for that. Dremel will melt it pretty good at any RPM.
Best bet would be bandsaw or some sort of circular saw (table or portable) with high tooth count blade (80-100+).
I need to cut through my lian li alu panels some modders mesh and acrylic will these 3 tools all i need,dremel,jigsaw,angle grinder?
cheers
What did you use to cut the side panels? I'm afraid that the dremel might melt the alu at any rpm, that is unless you've had success with it?
For most simple things, yea, that's all you'll need. From what I can find on the webs, you should get some 10-20 tooth count blades (looks like thin kerf) for the JS to use on the Acrylic.
Dremel won't melt Alu.
Mr. Sulu bring both Nacel's upto full power ;)
@ spacemaster : you bought that ugly case, afterall :D
red is sooo better then that boring, so common blue :up:
ps. kad postujes ovo na bench?
Thanks mate!
P.S
Na bench necu jos kaciti, jer Deki treba da okaci tekst neće nigde da pobegne, ali imas to i ovde ;)
http://www.sx-team.com/forum/index.p...st=0&#entry781
http://forum.pcekspert.com/showthrea...374#post817374
http://si.hwstation.net/forum/viewtopic.php?t=19
thanx !
i see, you choped case a little bit...
SX-team did a nice job on the case but I think the rads stick out too far
For more pictures http://www.sx-team.com/forum/index.p...st=0&#entry808
Thanks mates for critics.
