Originally Posted by
Texray1
HI guys. First post. I've spent the last couple of days reading through the 8,381 pages of this thread to try and get a feel for this motherboard. This is my 3rd build, the 1st was 4 years ago and the 2nd was 2 years ago.
I guess I'm spoiled because they both went as perfectly as could be. Only a couple of minor glitches and both machines just hummed along rock solid.
I'm now rebuilding my first machine with basically all new parts, except the case and optical drives. And all heck is breaking loose.
At first I kept getting all sorts of varying codes and problems. The random reboots, the C1 code, no video on occasion, etc. I finally figured out how to flash the bios and that went well. I was still having the same intermittant turn-offs and sometime turn-ons. Then I noticed that my cpu cooler was very, very close to the north bridge heatpipe. Not touching but very close.
Just to elimate any trouble ther, I put a thin piece of cardboard in between the two components. I finally got back into the bios again and looked through everything and and then tried to load Windows. I got it started and it was on the formatting section which takes a while.
Against my better judgement, I had to run an errand for about an hour. My wife got home while I was gone and called me. She said there was something on the monitor about what language did I want but before she could call me to ask what to do, the machine started a hi-lo siren and cycling on and off.
I think I may really be screwed now. Every time I turn it on I get that alarm and no video. It will either cycle on and off or might stay on but still no video signal. I happened to have another video card and swapped that but no fix. Since all of the main parts are new, I can't really point to anything as a suspicious item.
The LED code I get is either 90 or 99, neither of which is on the error list in the manual. I'm really stumped. I'm by no means an expert at this computer stuff but my first two builds went so smoothly that I was expecting the same.
I really have no clue how to proceed now. Any help would be fantastically appreciated.
