MegadeTCI, how about the impact of the flow meter on the previous flow?
damn. is that D5 shooting right into the cpu block?
nice.
I want to see him take out his memory :p:
Well, I can not tell you what the flow was like before installing the flow meter, because......there was no flow meter. But during my initial testing with two flow meters connected in series one after another, adding the 2nd flow meter reduced the flow by about 0.2GPM compared to a loop with only one flow meter. Since I am still able to get close to 2GPM flow, I'm in the "Great flow" category according to the flow graph I recently saw.
I was considering orienting the D4 pump so that it would shoot straight into the Maze4 waterblock, since the pump and the water block are perfectly alligned. I decided to stick with my previous design, where the pump sends the water to the radiator first, which then feeds into the water block. This way, I could efficiently route the tubing to the flow meter.
Dude, this computer has seen all the hardware updates it will ever have. So, nothing gets put in or taken out! :D
Aren't dual loops great? That's some creative component mounting! I like it
Boyu = No clamps :eek:!
How hard is it to get the 7/16" Masterkleer tubing over the 1/2" barbs?
Not hard at all if you are using brass/nickel barbs. The process becomes harder when you are using nylon barbs, since they can have a long, straight section where the tubing just sticks to the smooth surface of the barb. I found it hardest to put the 7/16" tubing over the inlet/outlet of D4/D5 pumps, since they don't have a tappered beginning - as opposed to typical barbs, the D4/D5 barbs have the largest diameter at the very beginning, followed by a long, smooth section, where the tubing again tends to stick. So for the D4/D5 pumps, I found it necessary to immerse the end of the tubing in nearly boiling water for 5-10 seconds.
I Like.... Nice Work Select
I like it too. Compression fittings are great, I hope they will become cheaper someday :(
Great work select. I'm curious if anyone's been able to get the OCZ ram fan to work on RAM sticks with overly large heat spreaders like the Dominators.
Worklog link: http://www.xtremesystems.org/forums/...=1#post2428701
Front and top sides
http://i233.photobucket.com/albums/e...orizon2004.jpg
Top side
http://i233.photobucket.com/albums/e...orizon2005.jpg
Right side
http://i233.photobucket.com/albums/e...orizon2006.jpg
Internal view w/ completed wire management
http://i233.photobucket.com/albums/e...orizon2007.jpg
http://i233.photobucket.com/albums/e...orizon2008.jpg
http://i233.photobucket.com/albums/e...orizon2009.jpg
http://i233.photobucket.com/albums/e...orizon2010.jpg
BigNG in the bottom right hand corner
http://i233.photobucket.com/albums/e...orizon2011.jpg
2 x MiniNG's and Sensorbus attached to underside of horizontal motherboard brace with velcro
http://i233.photobucket.com/albums/e...orizon2013.jpg
Pictures taken in the dark:
http://i233.photobucket.com/albums/e...orizon3001.jpg
http://i233.photobucket.com/albums/e...orizon3002.jpg
http://i233.photobucket.com/albums/e...orizon3003.jpg
http://i233.photobucket.com/albums/e...orizon3004.jpg
http://i233.photobucket.com/albums/e...orizon3005.jpg
http://i233.photobucket.com/albums/e...orizon3006.jpg
http://i233.photobucket.com/albums/e...orizon3007.jpg
just awesome GIZIU !
Nice Cable Management, and Setup GIZIU
looks very neat man, where did you stash the HDDs, Do you have a worklog..?
well "ranker" you seem to got too much money so much so you dont know what to really do with it...your res is resting on your rad, thats not a good look.
overall its an alright build could be better, the only thing i'm amazed by is the cluster of expensive parts.
"GIZIU" love your tubing size and coolant color, very neat and sexy...whats your tubing and barb size by the way ?
first i'm seeing liquid cooling on a DFI P35 do you have any cooling on your PWM, if not, is it ok not to ?
nice and clean, great work GIZIU !
Haterade??Quote:
This is the wc case gallery not the talk s@#$ gallery m8
