Yes :p:
But its logical, e.g. my C1 whit 1.25VID runs 1.3V just ~50c and i still got 4 core that make heat!
I need high volts for nice clocks, E0 owners needs lower volts, but they top out usually becouse of too high temps :up:
so you are saying that E0s heat up more than C0 with less volts?
Absolute max under non chill liquid:(:
http://i11.photobucket.com/albums/a1...s/546x95-1.png
Im gonna get this RAM; Corsair TWIN2X4096-8500c5 to try to get my Q827Axxx past 460fsb-wall. (my ram dont like it now)
specs:
1066Mhz//5-5-5-18@1.8
1140Mhz//5-5-5-15@2.1 (tested bij ASUS http://www.corsair.com/testreports/r...tner_id=238134 - These r the 4th mem)
Only nice ram on stock in local store, are these good? Could not find true 1.8v 1066 555-15 dimms out here...
True, the difference is sometimes about 5C or even more (@ same volts), but as it was already mentioned it's quite logical. The newer stepping probably wastes less energy by consuming and outputting as heat same energy (thus same clocks & same temperatures) at lower volts. But that's just my humble theory.
Hello just received these
DFI lanparty JR
E8500
patch q822a466
retail package says max 1.26 vcore good or bad?
ughh sorry for double post
Just got one off of eBay for $150. Q825A652...hoping its a winner!
Just bought the E8400 this week and made a quick overclock so far.
4.02Ghz @ 1.29Vcore (disregard the voltages in Speedfan)
ALL AIRCOOLED
http://img413.imageshack.us/img413/2...nch1nr0.th.jpghttp://img413.imageshack.us/images/thpix.gif
I'm hoping to gun for around 4.5 - 4.6. =)
Howcome it's showing 1.472v on the core in CPU-Z as well?
That is what's been plaguing my mind since I bought this processor.
I'm recently still running on an old board (DFI INFINITY P965-S) which was
flashed to it's newest BIOS for 45nm compatibility. For that overclock, the
voltage in BIOS is 1.29, but during windows, cpu and speedfan, are at
1.46-47.
Initially, when I increased the BIOS voltage to 1.21V, I was able to not only
boot the computer, but was also able to overclock it to a stable 3.81Ghz.
However, on cpu-z and speedfan, it tells me the voltages are at 1.36-37.
I recently created a thread earlier prior to posting these results explaining my
dilenma regarding this situation.
http://www.xtremesystems.org/forums/...d.php?t=204776
Any more input is appreciated. =)
Got an E8500 E0 some time ago. Batch Q820A925, one of the earliest. VID 1.25V. :rolleyes: Both sensors get stuck @ 36C (still way better than previous E8400 C0 with temps like 32/19 and 10C difference under load :p: ).
Currently running 506 x 8,5 = 4302, vcore under load 1.344V. Very hot compared to C0 8400.
Finally some time for LinX to do its job. :) Temps are insane though (~75C), and no Thermalright to be found anywhere around. :(
Pics:
http://img366.imageshack.us/img366/3...1632wg4.th.jpghttp://img366.imageshack.us/images/thpix.gif http://img366.imageshack.us/img366/4...ote0kx6.th.jpghttp://img366.imageshack.us/images/thpix.gif
Just a quick testing so far.
It's a DFI board with 965 chipset. And CPU-Z isn't perfect. Looking at what Speedfan shows on most of voltages one can assume CPU-Z is wrong too.
Anyone have a Q825 E8400 yet? I got one off of eBay but it wont be here for another days. Haven't seen the Q825 in the XLS file so just wondering..
E8400 Q745A822 owners around ?
@Dua|ist; My E0 runs very cool on 1.30V on Air 42 degrees C max stressed(4.2Ghz).
Xigmatek s1283 cooler.
Im just stuck there but i can run Bios stable @ 7*572FSB :confused:
Anyone have suggestions or is there another reason I can't oc more?
settings:
http://www.xtremesystems.org/Forums/...79580&page=286
