Originally Posted by
Robin77
Hi!
I bought the Maximus Formula SE and fired it up with a C2D 6850.
So here are my problems I've:
- I can only leave the Vcore setting on auto (or set it manually to a value 1,325 or less). All values above will lead to no boot. The auto value sets it to 1,325 (BIOS and CPUZ show this value)
- My NB temp is even idle at around 57 C and at full load even around 65C+.
I use default coolings (no watercooling installed) on NB. I've no problem with CPU temp. I use the Thermalright Ultra-120 eXtreme with a Scythe S-FLEX 1200, 120x120x25mm cooler. I also use 2 casecoolers (both 120 mm) and only top quality components (Enermax Infinity 650 Power supply, Corsair RAM, ...).
Concerned with my NB temp I searched Intel page for X38 specs. The official Intel NB max temp is over 90 C, so my temp is fine and I've no probs with stability (ran all kinds of tests over 48 hours with CPU overclocked 435x8 setting)
So I wonder how u guys get NB temps about 45 C loaded and all talk about unstability with temps over 50 C. T%his isn't true, as my example and official Intel document proves.
Even without OCing my NB temp is in Idle far above 50C, and this in a well cooled room and 100% stable running....
someone confirms this NB temps and also have this strange behavier with only auto set vcore working?
