eek, bling aside, but rad sandwiches :shrug:
Meet my mobile rig, Katipo.
http://www.thebestcasescenario.com/kayin/Katipo/004.JPG
http://www.thebestcasescenario.com/kayin/Katipo/013.JPG
http://www.thebestcasescenario.com/kayin/Katipo/014.JPG
http://www.thebestcasescenario.com/kayin/Katipo/017.JPG
Specs:
Lian-Li spider ITX bench
E6550@stock
Zotac G43 mITX board
2GB DDR2-1066
ASUS DirectCUII 550Ti (clocks aren't finalized, they're still climbing)
Laptop 4x DVD-RW
Seagate 7200.10 640GB SATAII (pretty sure)
Cooler Master 430w PSU
Cooling consists of:
AC Cuplex HD 775
Koolance chipset block (modded heavily)
Koolance RAM block (modded as well)
Masterkleer 1/4" ID red tubing
DDC3.2 w/Bitspower top
Bitspower 5 1/4 bay res, inverted and Kaptan taped to the chassis w/G1/4 male double sided fitting to pump
All lighting is LED, and even at full load for 6+hour gaming sessions she's deadly silent. Much like her namesake.
Very nice my brother...ficou show
http://i56.tinypic.com/2ez5p2a.jpg
http://i53.tinypic.com/2myq4vo.jpg
http://i54.tinypic.com/24qntqf.jpg
http://i51.tinypic.com/10rlrg9.jpg
Please remember the rules for this thread -
4 image limit per case
No quoting images
Minimize chit chat - if you have more detailed questions, please use the PM system.
(it's okay to occasionally post a comment in a language other than English, but this isn't the place to carry on a prolonged conversation - please use PMs)
the red stickers on the ram coolers are really killing the look
http://img9.imageshack.us/img9/3600/dsc3380o.jpg
^That build made me say "Whoa that's awesome" out loud. Did you edit the photos to make all the blues so equal, or are they just like that retail?
Is that radiator 480mm? I though you can't use it in ATCS 840, because it will block the usb panel on top. Unless you don't care.
I did not edit photos just used a Canon T1i
Yes it is a radiator panel 480 and USB really is locked
sorry for english I use google translator kkk :rofl:
there will a photo with pc off
http://i56.tinypic.com/2a5fbew.jpg
very nice builds guys!
excellent work
@Mendes_Jr: (White W.C.ed 600T's is what is all about these days... beautifull combo. May i suggest an inverted L shaped acrylic cable canopy placed as an extension of the psu to hide those cables at the bottom and maybe getting some black sli bridges as well)
@WCRF: (love the total blackness but datestamps?)
@riwar: (perfect choice of blue parts and accessories)
@>D4L70N<: (amongst other things, you've managed to turn a thermaltake into a desirable and interesting case, now thats an achievement imho!
@Screamer: (nice build and beautiful pics, can you give us a general view of the interior from the side? i suspect we are missing something on the framework)
@lowfat: what coolant are u using
lowfat, babyblue from Mayhem + icedragon?
Coolant is Ice Dragon. With a whole lot of Mayhems deep blue added.
Gaming rig for a friend...
Worklog
http://foro.noticias3d.com/vbulletin...d.php?t=371808
http://img714.imageshack.us/img714/4748/img9473s.jpg
http://img851.imageshack.us/img851/7672/img9475z.jpg
http://img828.imageshack.us/img828/8799/img9474z.jpg
http://img818.imageshack.us/img818/7995/img9437g.jpg
http://i304.photobucket.com/albums/n...n/DSC01344.jpg
http://i304.photobucket.com/albums/n...n/DSC01351.jpg
http://i304.photobucket.com/albums/n...n/DSC01346.jpg
http://i304.photobucket.com/albums/n...n/DSC01347.jpg
System Parts
Case: Silverstone FT03
Motherboard: Asus Maximus IV Gene Z Z68
Processor: Intel 2600K @ 4.6 GHZ 1.35v BIOS
Ram: 16 GB Corsair Vengeance DDR3 @ 1600 9-9-9-24 1T
Graphics: 2 x XFX 5870 CrossfireX Flashed to MSI Lightning BIOS’
@ 1000 Core 1200 Mem 1.2v
Storage: Corsair Force GT 120GB SSD SATA III 6 GPS OS
Western Digital Velociraptor 300GB 10k RPM Storage/Games
Optical: Sony Optiarc Slot Load Slim Line DVD+R
PSU: NZXT HALE90 80 Plus Gold 1000 Watt Power Supply with Modular Cable
Cooling
CPU Loop: Koolance CPU 370 Water block
1x 200mm Phobya Radiator
1x NZXT FN 200RB 200mm Fan
1x Koolance PMP 400 Pump w/ Koolance Top and Heat sink.
1x Phobya Balancer 250 Silver Nickel Reservoir
GPU Loop: 2 x Koolance VID-AR587 REV2.0
*Note radiator is cooled by the PSU’s Intake Fan and the lower 120mm Case Fan*
Various Bits: Koolance Fittings/ Quick Disconnects/ Single Slot Adjustable SLI Fittings
Tygon ½” ID ¾” OD Silver Antimicrobial Tubing ~5 feet for both loops.
Lamptron Aluminum Hose Clamps
Koolance Non Conductive Fluid
Case Fans: 2 x Zalman ZM-SF3
Very little modding was needed. Basically just widened the 4th PCI slot for the quick disconnects, drilled two holes for the bottom rad to mount (Third is the same screw that mounts the frame for the bottom 120mm fan it just lined up :P Fourth is not used as it sits under the psu cable plug), and made 2 notches with a dremel one in the upper right corner for the GPU loop res and one in the bottom 80mm fan mount for clearance for the barbs.
Temps are here:
http://www.overclock.net/water-cooli...l#post14690103
wtf... do u have dual ddcs in there?!
and is that single fan rad enough to keep everything cool?
That single rad must be just dissipating the heat from the pumps..but I must say thats one really tight setup....must have been killing to get everything in there.
