http://i.imagebanana.com/img/obqpuv9...0328145154.png
Woohoo, a 7770 was apparently what I needed to make the top 10.
No more Hypernova?
I believe Hypernova also crunches for another team, so he switches back and forth.
Welcome Back HyperNova... Sure hope that you can stick around until the end of the ATI_hcc GPU WUs....:yepp:
Indeed jeanguy2. This is the last run. The last mile. The last sprint. The last ............:(
Unfortuntely due to high temps I cannot run anymore full power. Seven units are out. Running on 11 machines.
My temps are at 91C for 1210 MHz and 1.2V and the fans are spinning at 84%. I have a bit more fan speed to go until I have to lower clocks.
1.S,
91 deg C is a might hotter than what I would dare to set for 24/7 crunching. Everything I have read on video card OC suggested a Max of 85 deg C except for short benching run. I personally use a max of 70 deg C for 24/7 GPU crunching. I now run 2 Gigabyte R7950 WF3/OC in Xfire in one rig. They ru @ 1200 core and 1.288V VDDC. Temp for top video card range from 58 to 62 deg C. Ambient room temp presently 19 to 21 deg C. Fans are set at a fix 78% setting for both video cards.
Suggest that you try to add a side exhaust fan above video card to remove hot air being generated by video card and insure that you have an unrestricted cool air intake airflow into the case. This extra side fan, above the video card, reduced the top video card temp by 10 to 12 deg C for my crunching rig.
