NeroVision5, overclocked?
Is anybody using NeroVison 5 of the Nero * Ultra Suite v8.3.2.1? I ask here only cause I was curious of the tweaking of RAM sub timings as I keep asking for advice on, if it can improve for real time video rendoring. Here's the daily tested stable profile for a Core 2 E6750;
Code:
Ai Overclock: [Manual]
OC From CPU Level Up: [Auto]
CPU Ratio Control: [Manial]
Ratio CMOS Setting: [8]
FSB Frequency: [480]
FSB Strap to North Bridge: [Auto]
PCI-E Frequency: [110]
DRAM Frequency: [DDR2-1153]
DRAM Command Rate: [2T]
DRAM Timing Control: [Manual]
Primary Info : 5-5-5-15-3-50-6-4
CAS# Latancy: [5]
RAS# to CAS# Delay: [5]
RAS# Precharge: [5]
RAS# Active Time: [15]
RAS# to RAS# Delay: [Auto] = 3
Row Refresh Cycle Time: [50] = 50
Write Recovery time: [Auto] = 6
Read to Precharge Time: [4] = 4
Secondary Info : 8-3-5-4-6-4-6
Read to Write Delay(S/D): [Auto] = 8
Write to Read Delay(S): [Auto] = 3
Write to Read Delay(D): [Auto] = 5
REad to Read Delay(S): [Auto] = 4
Read to Read Delay(D): [Auto] = 6
Write to write Delay(S): [Auto] = 4
Write to Write delay(D): [Auto] = 6
DRAM Static Read Control: [Enabled]
Ai Clock Twister: [Moderate]
Transaction Booster: [Disable]
Relax Level [0]
CPU Voltage ----------------- [1.49125v] = 1.480v
CPU PLL Voltage ------------- [1.52v] ==== 1.632v
North Bridge Voltage -------- [1.49v] ==== 1.52v
DRAM Voltage ---------------- [2.12v] === 2.22v
FSB Termination Voltage ----- [1.40v] ==== 1.472v
South Bridge Voltage -------- [1.075v] === 1.104v
Loadline Calibration -------- [Enabled]
CPU GTL Refference ---------- [0.63%] --
North Bridge GTL Reference -- [0.67%] --
DDR2 Channel A REF Voltage -- [Auto] ---
DDR2 Channel B REF Voltage -- [Auto] ---
DDR2 Controller REF Voltage - [Auto] ===== 1.152v
SB 1.5v Voltage ------------- [1.55v] ==== 1.600v
voltages in [] are as set, followed by actual reported, used.
Can anybody with knowledge of RAM and its sub timings look over and see where I can alter to make more stable for the sole purpose of video rendoring in NeroVision 5? On some projects it just cuts out (app only, not system). It happens during a long period of real time shifting through file in either slow mo or scrolling through w/ minute selector. It starts by responding sluggishly, then crashes. The profile is tested in several runs of Prime 95 v25.5 in all 3 modes with good results. Maybe it is just NeroVision, but just wondering if I can do anything for it just for editing. I doesnt happen a lot, but it does and thats the point.
EDIT: CPU/RAM in sig
