http://www3.atelco.de/8AbLlS76jsc2Gq...=5003&agid=399Quote:
Originally Posted by WeedJunk
but expensive ...
but expensive ...
450+ posts and not much has happened yet but the anticipation is tremendous.
What's the eta for the first boards ? Dumb question time ..is the version of Superpi that people are using now multithreaded or not? If it is then it's going to get a real bashing soon. Otherwise it will be interesting for 3dmark06 results.....
Regards
Andy
Ahh, thanks for clairing that up, cause i wasn't quite sure about yonah. But I think 8x will be the lowest you will ever need. The question was more like if ES's are upwards unlocked or not ;)Quote:
Originally Posted by wwwww
The superpi we use is not multithreaded, but initial results have shown that Yonah is much faster than Dothan per core, so it will be a real bashing even in single-core applications. And well, in 3D the FX60 will be easily beaten :fact:Quote:
Originally Posted by zakelwe
Sorry for not editting my previous post. For some reason my clipboard doesn't work anymore so i can't copy-past :(
DAMNQuote:
Originally Posted by C_B
I've already noticed that 2 seperate 512mb sticks are a lot more expensive than a kit :stick:
exactlyQuote:
Originally Posted by alexio
so max multi is like non ES ??
Where is the advantage of ES ??
all mobile ES'es have locked multipliers (incl p4 etc)..Quote:
Originally Posted by yotomeczek
advantages? ES yonahs are available in numbers (at least in ebay).
also.. bragging rights? :)
often ES chips oc a bit worse than retail ones, because ES chips could be used
as early qualification samples etc..
remember 780? all early ES chips had problems with lower multipliers + high fsb when cpu speed was over 3.2ghz or so..
780Es have probs ???
I had 100 units and never probs and the best had from me now hipro5
not too far away now.......Asus listed their offering on the site as well :)
full specs here
http://www.asus.com/products4.aspx?l...92&modelmenu=1
http://www.asus.com/999/images/products/1092/1092_l.jpg
Thanks for the info, I run the odd Superpi but I prefer pifast if it is not 3d.Quote:
Regards
Andy
No dual channel?:(Quote:
Originally Posted by dinos22
Shame it's not black with an enthusiast bent...Quote:
Regards
Andy
sucky chipset, hmm... Are you sure about that locked multi, cause I've heard quite different... up to 50x multi, which is quite more than everyone would ever need... 300*14 :slobber:
Yay for Asus crap board :D What, are you gonna glue heatsink to your chip, no mounting holes :D
Its not 975 chipset.Quote:
Originally Posted by kiwi
Any info on the multiplier? downwards we know.. upwards also unlocked?
Multi is locked i think.
Perhaps the ASUS-Board isnt so bad and it´s not 280€......it has DC, take a closer look ;)
The anticipation goes up a notch
Sure it's not, did you see that I used word crap :DQuote:
Originally Posted by Dumo
and a really awful design, and no ICH7-R .. :(
Upwards is locked 6-13 are all the options for T2600ESQuote:
Originally Posted by Waus-mod
Hope the chipset will do 300 FSB without trouble..Quote:
Originally Posted by mikeguava
BTW, you've got PM mike :rolleyes:
Well with at least 350fsb "we" are save, i guess 4.0ghz+ will be easily made!
I start playing with MSI 945GT Speedster Plus:)
<img src="http://222.151.185.113/c-board/file/MSI_945GT-S%2B_all.jpg">
The BIOS has not any setting for voltage,
so I've done Vcore-mod;)
<img src="http://222.151.185.113/c-board/file/945GT_SP_Vcore-mod.jpg">
ClockGen-1.0.4.2 is available, but unfortunately, there is FSB limitation
around 210MHz...owe to PLL(ICS954129) specification, I wonder.
SuperPI mod1.5XS: 1M -> 22.547s @2721.04MHz
<img src="http://222.151.185.113/c-board/file/22.547s_Yonah_2721..04.png">
SuperPI mod1.5XS: 8M -> 4m18.797s @2715.74MHz
<img src="http://222.151.185.113/c-board/file/4m18.797s_Yonah_2715.74.png">
I'll try Vdimm-mod later:)
Damn, a 4 Ghz dualcore would completely own EVERYTHING :eek:Quote:
