I'm kind of concerned with my temps actually.. Idles at 38C (23C ambient) on a Freezer 64 Pro.. I have an Ultra-D and I rotated the mounting clip on the freezer 64 so that the fan would blow horizontally as it's supposed to instead of up (from video card into psu).. However, the plastic mount that holds on the fan pushes against my memory, which I think is limiting my contact with the cpu.. this make sense to anybody? Should I rotate it back to the way it was? My temps are much higher that I saw in reviews and stuff before I got the cooler..
Edit: I rotated it.. temps are still around 38C idle.. Been running prime for a few minutes, and the load temps are only 43 - 45C.. so I guess that's not terrible.. less than 10C delta.. I wonder if it'll jump doing 3d tests, 'cause it's drawing air right off the top of my video card..
hey i got a 3700+ KAB2E 0547DPCW. Is this a good catch?
mhh, the 0547 weren't the best, but it should reach a substantial 2.8-2.9 with adequate cooling...
