This thread shows how to do it. It worked on my old DFI SLI-DR and it also works on my new DFI Expert.Quote:
Originally Posted by Onepagebook
http://img358.imageshack.us/img358/3...ime10oh.th.jpg
I tried 6/4 and it froze immediately. Maybe I'll need to change some secondary timings.....MBM5? All I did was change mobo's on the same windows install I had before and it worked fine, BUT now I'm getting weird things happening with the Dashboard such as it flickering or not even showing on the destop...Quote:
Small Question:
Anyone tried Partiot XBLK on Expert???
Originally Posted by end0
well, if you just use old system from nf4 series, then uninstall the current mbm5 you have and then reinstall. I just figured that out.:D
@Hirotaro , what is the IC on that ram? UTT?
Yup it's BH5-UTT
I tried some of the new redkine 4000 ce-6 gig sticks and got nowhere. Went back to balisitx 4000 and it was back to fine again. Bios 17 seems to be the best so far but I haven't tried #25. Afraid to mess with anything for the moment. :rolleyes:
No one tried the 1125 bios yet?
Are there any official BIOSes beyond the original shipping BIOS? I haven't tried anyhting else as I'm not having any issues. But I am curious.
No... There r two Betas => 1711 and 2511
mean your redline ce-6 couldn't o/c on the expert ? expected mine to arrive soon and hope it'd reach 262 mem clock :stick: :stick:Quote:
Originally Posted by xgman
seems pretty slow even for those tight timings ?Quote:
Originally Posted by TheMeatFrog
here's on my DFI NF4 UT SLI-DR,
@3000mhz 47s faster
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
@3102mhz 29s faster
My experiences with the beta bios's was not so goodQuote:
Originally Posted by Hirotaro
the 11/17 said it was not compatible with my board and would not flash :(
the 11/25 bios flashed BUT when i went through the bios the first screen that shows the time and storage drives, the screen to the right was all messed up, instead of giving a description it gave me stuff like this (-// ΓΏ{)
also the performance was not there my benchy were slower :( But that is just my experience every setup is different.
Also does anyone else have to move there vga cable to the top video card to see the screen after clearing cmos and a new bios flash ???? and then after you setup the bios to auto broudcast you need to move it to the bottom video card ????? or you do not see windows. Thanks
Originally Posted by nop
horrible. I'm not even sure it could run stock stable. I didn't waste much time with it. maybe I had bad sticks.
I don't know what's up with that. For some reason my PI times are ALWAYS slower then they should be. I thought the new board would fix that but it didn't.Quote:
Originally Posted by eva2000
Any ideas? :slapass: :slap:
What OS are you using? Server 2003 is better than XP Pro in 32M.
I'm using XP home SP2, wonder what eva is running :confused: I think hes running XP as well though :slap:
Try setting Trrd at 2 instead of 0. I think it's a little faster.
I have this 3500+ that's not a great overclocker. But I've gotten an extra 50MHz out of it using the Expert board. This is with single-stage cooling.
http://img202.imageshack.us/img202/5...x10tccd8hr.jpg
I'll try trrd 2 but I think my problem is something bigger than that I just don't have a clue what... :slap:
Have you got a copy of XP Pr0 ???, I dont even know anyone who uses XP Home so maybe thats your problem :)Quote:
Hi,
I have some trouble with my 2gb GBZX and the Expert , I can't pass 8M Spi with ram @ 250 but can do all 3d0x at this speed and even running memtest86+ for more than 8H00 , is there a new bios that could help me ?
I have tried to tweak the ram setting but all I gain was more confusing as first I had need 2.7v to pass 3d05 @ 250 and yesterday I succeed it with only 2.62v but still can't run more than 4M Spi, 8M failled.
ps: :woot: trouble solved :clap:
It was caused by the crapy NVIDIA IDE drivers .
:stick: Nvidia :slapass: .
Hmmm I actually installed them this time and have found no problems (see my sig), though I might try to uninstall them and test for any difference :)Quote:
Originally Posted by tomati
Nice to see for the most part that things are working out for people...it was pretty rough early on hearing about so much dead hardware associated with this board, but it seems like things are looking up.
It really sux that it'll be a good while before I can afford to build an actual OC'ing rig again...but I guess it just leaves more time for prices to drop and new toys to hit the shelves. :rolleyes:
anyone can tell me please if MBM is compatible with this strange motherboard???(I now if it was i have to change a folder )
I Try to install speed fan even knowing that was not compatible and my windows no longer boot,i had o format.:nono:
Yeah it is.
http://endo.zaphosting.be/MBM.JPG
What version are you using?Quote:
