Decent clock I think:D
I was just wondering... LDBHE 0601 is the best week of X2 3800+ Manchesters (?). Is the same true for the 4600+?
My Athlon 64 X2 4400+ Toledo Socket 939 stepping CCBIE 0610DPMW OC'ed 273x11 with vcore stock :D
http://img475.imageshack.us/img475/8...024x768ok8.jpg
my old cpu 4400+
2.9 on air http://home.no/smy/dataromme/sp%201m...%202900mhz.jpg
3.3 on phase http://valid.x86-secret.com/show_oc?id=117133
3.2 stabil
old time :)
My 4400+ on water, normal air temp (20-22C I believe).
I have a cvf file of this one at 345xMHz, but damn CPUZ released a new version a few days before so I couldn't validate it. On water, same air temp as the screenie.
I WILL test it more when I get some better cooling:D
running too on 1,30V
http://img382.imageshack.us/img382/1...benanntgt7.jpg
Here's my 6000+ on air 247 X 13 stock volts
is the HT link too high at 1235 ?, should the HT Link be lowered to 4X ? if so which one is it in BIOS
AMD Athlon 64 X2 6000+ AM2 3.0GHz
Asustek M2N32 AM2 nForce 590 SLI ATX 8 ch Audio 2xLan W/Less Lan
GeForce 8800GTS 640MB DDR3
2GB Crucial Ballistix Tracers DDR2 PC6400 (2 X 1GB)
Samsung SpinPoint T HD501LJ 500GB SATA-II 16MB Cache
Windows XP Home OEM
http://img.photobucket.com/albums/v1...og/24713-1.jpg
http://img.photobucket.com/albums/v1...g/super_pi.jpg
http://valid.x86-secret.com/show_oc.php?id=228003
Current Time = Mon Aug 13 16:46:37 2007 W. Europe Daylight Time
Computer Name = ZEUS
Number of Processors = 2
========== Operating System Information ==========
Microsoft Windows Vista (Build 6000)
========== Motherboard Information ==========
Motherboard Vendor: DFI
Motherboard Version: 1.0
Motherboard Model: DNF4DAGE
========== DirectX version Information ==========
DirectX 10.0 (6.0.6000.16386)
========== Driver Version Information ==========
Audio Driver Not reported
GART Driver 163.86 (6.0.6000.16386)
Graphics Driver Not reported
Ethernet Driver Not reported
IDE Driver Not reported
nTune 5.05.47
========== Processor, Bus, and Memory Speed Information ==========
CPU Speed = 3025.312
CPU Multiplier = 12.000
FSB Frequency = 252
Memory Frequency = 418.000
PCIE Frequency = 2500
tRas = 8
tRcd = 4
tRp = 2
tRc = 0
tWr = 0
tRrd = 0
tRwt = 0
tWtr = 0
tWrrd = 0
tWrwr = 0
tRdrd = 0
tRef = 0
========== GPU's Core and Memory Speed Information ==========
GPU Core Speed = 605
GPU Memory Speed = 902
========== System Voltage Information ==========
CPU Voltage = 1.550 v
Core Voltage = 1.600 v
AGP Voltage = 4294.967v
Aux Voltage = 4294.967v
Memory Voltage = 2.600 v
========== Processor and System's Temperature Information ==========
CPU Temperature = 26 C
Second CPU Temperature = Not Reported
System Temperature = 44 C
GPU 0 Temperature = 53 C
========== Memory SPD Information ==========
Memory Dimm 0 (0x50) Memory not present
Memory Dimm 1 (0x51) Memory not present
Memory Dimm 2 (0x52)
Memory type: DDR SDRAM
Error correction: NONE
Voltage interface level: SSTL (2.5V)
Data width: 64 bits
Number of physical banks: 2 (double sided)
Number of logical banks: 4
Number of row addresses: 13 13
Number of col addresses: 11 11
Bank density: 512 512 MB
Primary RAM Width: 8 8 bits
Error checking RAM Width: 0 0 bits
Module density: 1024 MB
Refresh rate: 7812.500 us
Self-refresh: Yes
Burst lengths supported: 2 4 8
CAS 2.5:
Cycle time (tCYC) = 6.000 ns fMax = 166.667 Mhz
Access time (tAC) = 0.700 ns fMax = 1428.571 MHz
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer ZEUS
Generator Kay
Operating System Microsoft Windows Vista Home Edition 6.0.6000
Date 2007-08-13
Time 16:48
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type DualCore AMD Athlon 64 X2
CPU Alias Toledo-512 S939
CPU Stepping JH-E6
CPUID CPU Name AMD Athlon(tm) 64 X2 Processor 4600+
CPUID Revision 00020F32h
CPU Speed:
CPU Clock 3024.13 MHz
CPU Multiplier 12.0x
CPU FSB 252.01 MHz (original: 200 MHz, overclock: 26%)
Memory Bus 201.61 MHz
CPU Cache:
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties:
Motherboard ID 07/27/2005-NF4-SLI-INF-6A61FD51C-00
Motherboard Name DFI Inifinity NF4 SLI
Chipset Properties:
Motherboard Chipset nVIDIA nForce4, AMD Hammer
Memory Timings 2.5-4-2-8 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
SPD Memory Modules:
DIMM3: OCZ OCZ4001024PF 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM4: OCZ OCZ4001024PF 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS Properties:
System BIOS Date 07/27/05
Video BIOS Date 04/13/07
Award BIOS Type Phoenix - Award WorkstationBIOS v6.00PG
Award BIOS Message (CK8LD727) EVALUATION ROM - NOT FOR SALE
DMI BIOS Version 6.00 PG
Motherboard (CK8LD727) EVALUATION ROM - NOT FOR SALE
Motherboard 07/27/2005-NF4-SLI-INF-6A61FD51C-00
Motherboard DMIMOBO: NF4-SLI-INF
Motherboard DMISYS:
PCI/AGP 10DE-0193: NVIDIA GeForce 8800 GTS [NoDB]
My Little OC with Aquagate mini R80; modding Black Ice GTS 120 XFlow Rad.
Computer ZEUS
Generator Kay
Date 2007-08-13
Time 16:48
CPU Properties:
CPU Stepping JH-E6
CPU Speed:
CPU Cache:
Chipset Properties:
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
SPD Memory Modules:
BIOS Properties:
Motherboard DMISYS:
nTune 5.05.47
FSB Frequency = 252
tRas = 7
tRcd = 3
tRp = 3
tRc = 0
tWr = 0
tRrd = 0
tRwt = 0
tWtr = 0
tWrrd = 0
tWrwr = 0
tRdrd = 0
tRef = 0
GPU Core Speed = 620
GPU Memory Speed = 918
:D :rofl: :shocked: :clap: :ROTF: :confused: :p:
OCCTQuote:
My Brisbane
AMD BE2350+ & HR01 (Fan 2700 rpm) (Vcore 1.475)
Asus M2R32-MVP (BIOS:0906)
Kingston D9GMH 1024*2 (Vmem 2.4v)
XFX 7900GS (@630/850)
HDD ST3120814A (7200.9)
Enermax Liberty 400w
http://www.upfile.us/file/jpg/occt.jpg
Orthos
http://www.upfile.us/file/jpg/Orthos_3Hr.jpg
SuperPi 1M & 32M (1 Cores)
http://www.upfile.us/file/jpg/SuperPi1M_32M.jpg
SuperPi 32M (2Cores) 1/2
http://www.upfile.us/file/jpg/SuperPi_32M_01.jpg
SuperPi 32M (2Cores) Finish
http://www.upfile.us/file/jpg/SuperPi_32M_02.jpg
FritzChess
http://www.upfile.us/file/jpg/FritzChess.jpg
It's quite ok ... :)
You have a key on your keyboard that reads "print scrn" or something similar... it will take a screenshot of all that is visible on-screen at the present time... use the key, and then paste in mspaint or some other software that handles images :) voila, you have a screenshot :)
here's a cpuz validation link of my work in progress ;) trying to hit max HTT on am2 without no stability issue ;)
http://valid.x86-secret.com/show_oc.php?id=241553
my try on highest htt
Tested the same thing here a couple of days ago..
412,7 HTT link
http://valid.x86-secret.com/show_oc.php?id=240940
Rock stable @HT link votlage 1,5v, nb-core 1,5v, sb pll 1,6v, and sb core 1,65v
The board booted at 450 HTT set in bios, but 412 HTT was max anyways, anything above that, and clockgen didn't work! I'll upload screenies of it later..
http://img517.imageshack.us/img517/4...t450ez1.th.jpg
Edit: Picture of 450htt, booted in at it, but the clock generator apparantly could not handle it...
Highest ht I've tested was at 1500MHz..
Anyone know how my 4000+ CAALG 0705TPAW should oc? has anyone with this stepping hit 3GHz?
I have a few programs that worked well for me they are #ClockGen# CrystalCPUID# these all work with the AMD AM2 processors the best one to use is CrystalCPUID e-mail me if you want any more
Systool is a very handy application also.
X2 4200+ LCB9E 0719WPMW
Air cooled (XP-90), IHS still on
245x11=2695 mhz
System---DFI nF4 Ultra-D
Bios 704-2bta
OS---Windows XP SP2
VID= 1.325 v
VID SPECIAL= 110%
CHIPSET= 1.5 v
LDT= 1.3 v
LDT= 4 X
vdimm = 2.7 v
CPC = Enabled 1T
CAS Latency(CL) = 2.5
RAS to CAS(Trcd) = 4
Min RAS# Active time(Tras) = 8
Row Precharge Time(Trp) = 3
Row Cycle Time(Trc) = 12
Row Refresh Cycle Time(Trfc) = 16
Row to Row Delay(Trrd) = 3
Write Recovery Time(Twr) = 3
Write to Read Delay(Twtr) = 2
Read to Write Delay(Trwt) = 3
Refresh Period (Tref) = 3120
Write CAS Latency(Twcl) = not in this bios
DRAM Bank Interleave = Enabled
Skew = Auto
Skew Value = 0
DRAM Drive Strength = Weak 4
DRAM Data Drive Strength = Level 3
DDRAM Response Time= Normal
Max Async Latency = 8 ns
Read Preamble Time = 6 ns
Idle Cycle Limit = 256 cycles
Dynamic Counter = Disabled
R/W Queue Bypass = 16X
Bypass Max = 4X
32 byte Granularity = Disabled
http://img230.imageshack.us/img230/5120/occtft7.th.jpg
http://img230.imageshack.us/img230/8749/cpuzkm2.th.jpg
When I get time I'll run Orthos 24 hrs & post it here. - Scott
my rig..
G1 step. 5000+ Brisbane on polished HyperTX with AS5..
soon to remove heatspreader, see if that is going to make any improvement..
this res. is on my old Twinx 6400C4, rev. 2.1 kit, with ProMOS chips.
3000MHz& 850MHz@CL4-4-4-12-2T
http://valid.x86-secret.com/show_oc.php?id=255635
http://img84.imageshack.us/img84/505...122tem3.th.jpg
3100MHz& 888MHz@CL4-4-4-12-2T
http://valid.x86-secret.com/show_oc.php?id=255639
http://img84.imageshack.us/img84/837...122tbl4.th.jpg
3170MHz& 900MHz@CL4-4-4-12-2T
http://valid.x86-secret.com/show_oc.php?id=255840
http://img85.imageshack.us/img85/188...xzaslb3.th.jpg
these are max stable for SPi and 3D Mark, also suicide shot is possible on 3200MHz+ but hardly is any important..
will try in a couple of days what this cpu can do with these new dominators and will put a Sempron 2800+ to see what's what..:up:
here is my X2 4000+
http://valid.x86-secret.com/show_oc.php?id=261171
@ 1,47v
i need a new board ^^
A friend of mine built a computer few days a go. Got chance to play with them :D
Processor : AMD Athlon 4000+ AM2 Brisbane
Mobo : Biostar TA690G
RAM : 2x1G KVR
VGA : Winfast 7300GT Extreme
Cooler : Thermaltake Mini Typhoon
Max suicide shot @ 1.5 V : 3381 MHz on TForce 6100 AM2 : http://valid.x86-secret.com/show_oc.php?id=268534
