I asked AMD for JTAG docs and accessibility to C0010042 MSR via JTAG. They answered that this data is confident.
So I think we get right way to dig in. Try to find some BSDL's for AMD dies.
How I hate that... You f* own the chip and you have the right to know how to handle and play with what you own. Sh*t, it makes me so mad :upset:Quote:
Originally Posted by TiN_EOF
yes but if you can unlock a 3000+, 3200+, 3500+, 3700+, 3800+ and 4000+ to FX speeds why would you pay the extra $$$ for the FX
logicaly most people wouldn't pay the extra money for the FX chip; would you?
But it discourages people to try but let's not stop trying!
In the end its all about the money!
i say we make 60 e-mail accounts and spam randomly until we get the damn document!
If they made a 4800+FX x2 chips, maybe it would be worth over $500, but as of now the P4D's are priced way below the A64 dual cores and all the non xtreme types flock to them..... bad for AMD's bottom line longterm. OEM design wins going to $400 less$ P4D's instead of A64 x2's.
Hint to AMD.... I'd pay $500 for a 4800+ FX(unlocked).... not $501.
i think we should have fugger ask AMD but that is just me since he is a ledgend for ocing and is the owner of XS.
Mr_Slinky
You can try. :) But I don't think that AMD will tell that info even to Fugger :)
This is info how to earn $$$$. Bad people can reprogramm 3000+ chips to FX and get 9 times more money (bought 10 3000+ (1500), programm them = sell as FX (10000))
It is easy :)
Isn't that what AMD does? hehehe :stick:Quote:
Yeah, there is no way to get AMD to give up the documentation. This would destroy their profits if they gave away the stuff to the public. I know that only a select few people at AMD know this information.
Well the chips used to come unlocked back when.. It was what made AMD special!
How do you know that? :confused:Quote:
Originally Posted by eliminate
ok figured i would rma my 3000+ venice tomorrow anyways so i tried the u wire and it doesn't work to change the multi just though i would let you know i tried one with each and one at a time and the fricken cpu still works!!
You tried every possible combination? :slobber:Quote:
Originally Posted by Mr_Slinky
that takes ALOT of time and ALOT of effort dude
This may be nothing but has anyone seen this?
http://www.findarticles.com/p/articl...40/ai_15321368
and this
http://www.sightsys.co.il/products.asp?class=21
interesting...Quote:
Originally Posted by njkid32
yeah theres abunch of info out there like that, but nothing technical, all iv been able to find are those news releases or 15 billion JTAG developers offering AMD debugging
Originally Posted by Daved+
only 3 combos i tried since it looked like they were connected in the above picQuote:
Originally Posted by |SiLA|
Troman.
Try to read all of them.
If you therioe is true I'll figure this less than a month.
But. I think that there was some ESD influence to CPU when it lies on table, and a few registers are wrong, and it is a bit luck that multi unlocked with this.
So, I'm just waiting for hardware to try JTAG-programming CPU's.
TiN_EOF
AMD uses microcode which is permanent (Intel's CPU can have microcode updates) so I doubt it was "updated" by static electricity.
Pirs told me that the CPU was not freely on the table, but in a plastic box that came with the CPU.Quote:
esd = elector static discharge???
Yes, it is when a voting citizen discharges electricity :stick:Quote:
Originally Posted by i found nemo
:rofl:Quote:
Originally Posted by nweibley
