well, u cant use the same memory due to teh fact amd uses ddr and intel uses ddr2, so rule that out, intel apparently cant use nforce, tho now i think they figured out it wasnt the chipset that was the prolem, im sure that if they used the "correct" heatsink, it would work on the nforce board, with sli, heatsink, well they used the one provided, to provide "stock" performance charts, so really, the only thing u could use the same would be, psu, mobo, and video, unless u wanted to use xp 120 hs&fans insted, but stock heatsink should suffice for the tests since no overclocking is involvedQuote:
Originally Posted by bypolar
