Succesfull Ultimate capacitor modifiaction
Hi all,
I have a Gainward 6800le one of the really early one, came in a bulk box a year ago. Black screen was instant and did capasitor mod as soon as I found out about this. Used 2200uF power supply capasitor and worked fine.
http://img398.imageshack.us/img398/3...dcap4ht.th.jpg
Wanted to be on the safe side and decided to change the bad caps and to get rid of the extra cap. Took an hour to solder the old capasitors off, even if I had some good leverage.
http://img489.imageshack.us/img489/8...cap13hj.th.jpg
Old ones off and new PXH ones (from SikaRippa) waiting to get in.
http://img230.imageshack.us/img230/7...cap21vw.th.jpg
Some 30min of soldering the new in place. pretty good job, if I say so myself
http://img230.imageshack.us/img230/2...cap32tp.th.jpg
Artic Cooler NV5 back on place (put some Artic Silver 5 on the core) card's not bent, just distortion from the lens.
http://img230.imageshack.us/img230/3...cap46lu.th.jpg
2½ hours for the whole job, working fine without the extra capasitor, tested with ski alpine and some flatout. Used to run the card 350(core)/850(mem) 10mhz under what the driver would pass, now memory passes 880, so a little bit extra from the mod.
Thanks again SikaRippa and let me know how bad the old caps were :)
Sanyo Os-Con 4SVP1200M capacitor
Hello to all of us.
First of all ... please ... forgive me in advance for my bad english.
I have a similar problem with a Quadro FX-3000 grafhic card.
I know that in this card is missing one capacitor, marked as follows:
"449 SVP 1200 4".
After reading this thread, and after downloading technical sheet from the Sanyo web site, I think that the missing capacitors on my card should be the Sanyo Os-Con "4SVP1220M".
But, at this point, I have encountered a big problem: it cannot be found in Italy. And also in Europe it cannot be sold in small quantities.
Is there anybody there who could help me to find a reseller in USA (or in any other country), where to buy 2 or 3 pieces only ?
Thank you in advance for your kind support.
Sandro
Ultimate+Enhanced capacitor modifiaction
Originally Posted by SikaRippa
Some short (?) comments/answers.
"The RoHs issue" in practice means a solder having larger melting point (30-40 C) due to 'exotic' materials in solder. Therefore, desoldering (solderring with RoHs solder) is more difficult at when using a low power iron.
If you ever consider modifying feedback components, practice with old MOBO etc and if you need extra help ask in this forum (or email) :)
I am not 100 % sure freezing is relating to BS. Freezes have been appeared also to other GF-cards (e.g. ultras, 6600GT's) and therefore those can not be directly connected to the design fault of the 6800le-cards (=origin of BS). One user reported that freezes with MSI 6800le-card removed when a good, low-ESR, capacitor added to those TP's. So, that would be another reason to test adding capacitor again. Maybe that is the reason you did not have freezes earlier !!?? I did not get/fond data what model capacitor you had, too few labels..
It is hard or impossible to say you have now 'BS free card' FOR EVER. However, I believe by changing capacitors the life time of those becomes many times longer than with originals. The life time of a capacitor is related heavily to operating temperature (+some other things, voltage ..). Ripple-current (=ESR) increases internal temperature and decreases life time. As a rule of thumb life doubles for deacrease each 10 °C !! The specified life time is 2000 hours which is only 12 weeks !!! ( 105 °C and maximum ripple current, PXA's). In reality computer is not allways 'on' AND load is not maximal whole time AND temperature is much lower, so realistic life will be some years. Propably some other component will broke down before capacitors again.
In the case of original CV-EX capacitors the ripple current (=charging/discharging due to load hanged) is ~ x2 higher than specified and the life time in such case cannot even be caluculated !!(with the equations provided by manufacturers)
Yes, got that RoHs thing, just tried to be funny with the comment, guess lead in motherboards (and other stuff) is coming more of an enviroment issue.
Oh and before I forget, put the mobmo cap on the testpoints (after 30min on the other pin, gave up for a good solder, it just would not make a good contact, no matter how I tried) but it works and fit is tight. So on with testing I went, first time ever I was able to OC so much that it would do artifacts on 3dmark05 (360 on core and 865 on memory), weird black and green polygons flashing here and there, but it went through. Played toca with 800 on memory couple hours, no black screen, don't remember for sure if there were no freezes also, have to test some more. I'll go for that 850 again 'cause it BS:ed so soon that it's easy to see any improvement.
EDIT: Tested toca a while with the 850 on memory and no problems :banana: so working like it did before and even better. Now that I have a working card that overclocks fine, went and ordered a new one :D Well someone gets a good and tested card for cheap and I get a faster one not so cheap :p:
Thanks for the comments/answers, made me wiser again. That capasitor lifetime was a real eye opener, so best way to go would be overclock memory as you need and not by bios mod, Have 325/700 12 pipes 6 shader bios in right now, was about to put 325/800 in for good, but have to think about it.
