But here's the MAGIC about the Dothan....
you don't NEED a HS/F like that!!!!!
A Swiftech MCX159 and a MicroCool NorthPole are good for 2.8++
Customize a s370 hs/f just for fun....
C
C
The DFI board has standard northbridge holes, which is all is required to cool the dothan really.
http://www.x86-secret.com/pics/cm/dfi855/socket-sch.png
http://www.x86-secret.com/pics/cm/dfi855/board-17b.jpg
I think the numbers are off. If you look at the schematic of the 479, the holes are 41mm x 41mm. Based on measurements I just took on a P4C800, the 478 socket's mounting holes are more like 77mm x 60mm! :eek:Quote:
Originally Posted by Naughtyboy
http://209.35.180.29/emotes/479.gif<<479 478>>http://209.35.180.29/emotes/478holes.gif
3 inches = 76.2 mm. 2.34 = 59.4 mm. So my cheap plastic ruler measurements were a little off, but you get the point.
WRT the height of the CPU and socket, no problemo. When you install the Vapo, the evap is supposed to protrude from the foam like 2mm. As you tighten it down, it makes contact with the IHS, and snugs up against it. To some degree, it retreats back into the foam/housing. It really is quite flexible in terms of height. Just let the evap protrude 2.1 mm for the Dothan. ;)
Need? Need? LOL, since when is XS.org about practicality? :ROTF: These pursuits are about conspicuous excess, getting faster, quicker, lower times. If I lived in Antarctica I'd be burying my Vapo's compressor in the permafrost! If I got my processor down to absolute zero, I'd wonder, what if I added a bigger fan on the raddy? (yes I know this would be both impossible and futile).Quote:
Originally Posted by charlie
2.8 on air might be nice, but I'd like to see these at 1.7 vcore at -50, and we might kick some serious arse. :slobber:
Bottom line, it would need a custom evaporator housing, something I don't have the time, energy, or likely the skills to fab. :(
Any volunteers? :lol: WTH did FUGGER use for his cascade?
charile which mobo do u and macci prefer? the aopen or the DFi, reason im askin is that ive jus recived a 1.6 dothan and i need a mobo to go with it, im not really in a massive rush, so if there is another mobo around the corner which will be better then plz suggest it. all otha users plz freel free 2 answer this question also...
shigs
^^^^ good Question, Aopen seem to be freely available in the UK but I can't find a single DFI board unless I import :(. I'm currently leaning towards DFI as they usually follow a mobo with good BIOS support whereas most manufacturers only upgrade their BIOS if a problem is found, rather than attach better overclocking options.
macci can you verify one thing on aopen?
On mine i see a weird behaviour.
If you open aopen software inside windows and look at the cpu T you will see the same or higher T that you see inside bios.
Now is it the aopen software that grab its T from bios (weird) or idle is not working properly in your opinion?
My windows driver is uniprocessor ACPI and idle process is in my task manager.
Other weird thing is that bios cpu T starts at 36.5° w/ 20° ambient T and goes up to 41/42° and stops there. Full load or not full load.
Give it look if you can.
P.S. a first Pi look w/o booster. :)
http://xoomer.virgilio.it/kikoguru/img/34atto2.png
http://xoomer.virgilio.it/kikoguru/img/34.png
P.S.S. philippines chip...:/
Ciao
Charlie, I totally understand what your saying, the fact is these CPUS will overclock to ~2.7GHz on air due to their great thermal properties. Perhaps I should reword my question a little. Is there anything feasible to be gained from using watercooling/TECs over air, or is the performance gain minimal when you reach these dizzy heights?
Im from the uk also mate, can u post the links of all the websites that sell the aopen mobo??Quote:
Originally Posted by Johnny Bravo
ty
Watercooling would likely yield smaller gains than it usually does on other processors, because watercooling is limited to slightly above ambient temps, and these Dothans don't run all that much higher than ambient compared to other hot-as-hell processors. So the efficacy of water on these wouldn't be all that great (unlike, say a Prescott, or a 6800GT that runs 80C under load, LOL).Quote:
But TECs and phase go lower than ambient, much lower. If this forum stands for anything, it's that even at room temp, no processor works as well at one running zero or subzero. ;)
I firmly believe if someone puts out a decent mobo (which neither the DFI or Aopen are, by modern enthusiast standards) that could hit higher FSBs and memory clocks, a phase on these things would be scary. :slobber:
Shigs,
So far I've seen Dabs and Kustom PCs plus according to the overclockers.co.uk forums they should be receiving Aopen boards today and DFI boards by the end of the week (heres hoping!!)
EDIT: just noticed that Overclockers has an Aopen board on their site now, DFI to follow...
Actually anyone know what the thermal rating of a Dothan is when overclocked. I know the TDP rating is ~21Watts but this'll shoot up somewhat when running high clocks. Reason being this is the operating range of the MCW50-T and I'm curiousto see if the TEC needs upgrading or if the 80 Watt one currently installed will suffice?
http://www.swiftnets.com/assets/imag...tingrange2.jpg
Hehe, that thing would keep the biggest Dothan frozen @ stock wattage :)
And then chill the water.... :)
mcw50-t would be awesome!!! It'd probably keep the CPU under 0C even under load...
C
Use this handy online wattage calculator. But first you'll need to visit the processor finder to know the stock values. There is no single answer, as it depends on which chip, what voltage, and how high you overclock it. For example, the 2.0 SL7EM, default voltage at 1.34, stock wattage 21, set at 1.6v running at 3.0 would be under 45 watts. Even at 1.7v, at 3.0 GHz it would be under 51W. To hit over 80W, you'd need to run the 2.0 at 1.7v @ 4750. If you find a 2.0 that will run at 4750 under any conditions, let me know, so I can come over to your house and conk you on the head, take it from you, and pwn every bench known to mankind, SLI or not. :lol:Quote:
Keep in mind also, I'd be surprised if that thing fits on either board without some custom solution. In fact, no way it fits on the Aopen.
I have a MCW50 without the T, and its mounting holes/screws are about 55mm apart, too wide for the 41mm Aopen and way too small for the weird DFI holes. The block itself is larger than 41mm, so it would be very hard to mount on the Aopen (80-172W peltiers themselves are 40mm X 40mm). DFI could be done, but you'd likely need to fabricate a bar or star bracket to attach on the back of the mobo. Not hard for some of the McGivers here, but know what your are facing.
I don't want to poo-poo this idea. Frankly, I love it. I'd buy a DFI and Vapo it if I could fab a evaporator housing (I actually use my PC, on my desk, in a pretty case, so I don't want to do the messy foam-and-clamp in the garage method). But even if I could make it work, these boards really do suck (even the almighty FUGGER tried phase change, and it was like perfume on a pig with these boards).
If a good board comes out for this thing, I'll be on it like a pit bull on a poodle, and make the Vapo work. And for those of you who think I don't need a Vapo, I already have one, and they are very expensive paperweights.
Hmmm..... are you sure the DFI pattern is too small? I use a standard Swiftech NB cooler on mine and that's the same size as ATI pattern, isn't it?Quote:
Originally Posted by uclajd
C
No, the Aopen is too small, 41x41. ;)Quote:
So, did you sell the Dothan? :confused:
sold the DFI board ONLY.... I have a 755 AND a 735 sitting here, looking for LOVE :)
M8 you got it mixed up...DFI board is the one that is having 41x41...and Aopen is utilising P4 mounting braket.
Does anyone have a link to the in-socket Vmod for Pentium-M?
I've got a Dothan and the DFI 855GME, but I'd rather not remove the resistor for more Vcore, since it's a test board and will eventually go back to DFI.
I can't seem to find a link to the wire trick anywhere, my searching skills on the forum and Google are weak today!
Need more Vcore to push past 2.4GHz with my 1.7 :D
Rys
THERE ya go m8..!!!Quote:
Originally Posted by Rys
Uclajd, the plan was to fabricate a new mounting frame for the MCW50-T aka their very own FX adaptor style one. I was plannig to buy the DFI mobo rather than the Aopen anyway.
Charlie, you sold the DFI?!?, what was the problem, was it too flaky?
Non working agp lock I guess. Go for the aopen anyway.
what on offer from the Aopen that the DFI doesnt, apart from the socket mounts. Isn't the DFI capable of 533MHz as opposed to the 400MHz of the Aopen?
There are some issues when you go past 133 FSB and have an Ati card, it freaks a bit out. We think the AGP Lock on the DFI board is not working.
About the agp lock on Aopen...I don´t know if it´s only mine or if anyome else experienced same thing.
All 3 agp/pci lock options work up to certain levels of FSB....it doesn´t work completly. I.E ....when I set 66/33 I can go up to about 140fsb...with 75/37 it craps out at about 156..and finnaly with 88/44 it allows me to go up to about 170, but when running an ATI 9250 with the 88mhz lock I get stutters/lagging when running 3DMark wheras it dosen´t when locking at 75mhz.
