Indeed, it will be fine. If you are unsure, install another service of D2OL on your pc, it then runs 50/50 on the two services, but you are at least able to download 4000 cands into your rig. :)Quote:
because of daily server problems and recommendations here I increased tasks from 200 to 2000.
How big are the files, because I have small partitions for my windows systems. Are they stored in the d2ol installation folder? I can't find files with informations about canditates.
Maybe this was asked years ago but I worked 12h today and just want to get this small info without reading 19 pages here and maybe more ;)
Thanks a lot for your help, I will go sleeping now, but compressor stays up for d2ol of course ;)
It was powered off for a long time because I hadn't the time to play or to do video worx. now it can run sensefull without doing anything on my own :hehe:
Only a few megs, 20 I believe. My whole D2OL folder is 60...
thanks for this info!Quote:
Originally Posted by Martijn
having problesms guys. i;ve got d2ol up and running n this machine but i;m having a fit with the linux install. im;ve made a post over at d2ol site, any of you guys ahve a clue as to what im soing wrong?
http://www.d2ol.com/cgi-bin/ultimate...;f=11;t=000117
Try the one that comes with Java, if you already haven't. That's the one i used with SUSE 9.0 and didn't seem to have much trouble.
yea its the nongui installer with the java. i didint try the one wihtout it. i;ve never fooled wiht any java in linux.
I think MoP used the non-java installer (do u already have java installed?). Send him a pm (masterofpuppets).
not as far as i know, i dont have java installed. i figured the jvm files were enuff java, and vm to run it. let me see if i install java if it'll work. be back in 20
EDIT: according ot yum it looks liek java is installed and up to date. back to ground 0
Alrite, what I got from your edit is that you do have java installed, right. Here's mop's old thread: http://www.xtremesystems.org/forums/...33#post1071233
He said he used the jre-less version and it worked
went back and tried the one without java still no go, treid up dateing the system and yum is having a problem with a librarie im gonna try to figre out how to remove it or repari it and update hte whole system to see if that helps any.
Maybe give the GUI installer a shot? I doubt it will make a different, but I guess it worth a shot.
okkaaayy got band lib removed and have a 142 megs of updates its doing so i'll bea goo 45 mins or so before i take another stab at it.
im not sure it;d be worth teh gui isntallation as there is no gui on the system :eek:
ahhh, scratch that one then lol Would be pretty useless wouldn't it
lol yea, i think it;s gotta be my install, im gonan redo it, i removed and added java again, let the updates fly and still nothing, the path its pointing to (that it says is wrong) is the path to the jre folder in the jre bunlded install. im gonan remove it and install it as root hoping all these changes are what it needed. otherwise its gotta be a bad *.lax file. it said put the absolute directories i jsut assuemd that meant the entire path (home/usr/fold/SergentD2OL/D2OL) i'll fiddle aroudn with each combination i can come up with till im out of logical ones. at least one comptuer will be crunhing tonite :/
EDIT"!!!!!!1111ONE
ok we're gettin somewhere now, i isntalled it as and ran it as root and got all this
sooooooooo it tryied to let me register, and wont run, any ideas? im gonna go update my post over at d2ol and see what they say. if this looks familiayr to any of you let me knowCode:[root@localhost D2OL]# ./D2OL controller:cli
Running with Command Line Interface Controller...
Please Register your Agent to continue.
Note: You must be connected to the Internet for Registration to succeed.
Please enter your email address to Register ('q' to quit): callusedfingers@musci an.org
Please wait, Registration might take a few seconds to complete...
GUI OutputStream] FATAL [com.sengent.d2ol.node.gui.GUIController] Error Initial izing GUIController.
GUI OutputStream] java.lang.InternalError: Can't connect to X11 window server us ing ':0.0' as the value of the DISPLAY variable.
GUI OutputStream] at sun.awt.X11GraphicsEnvironment.initDisplay(Native Met hod)
GUI OutputStream] at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEn vironment.java:125)
GUI OutputStream] at java.lang.Class.forName0(Native Method)
GUI OutputStream] at java.lang.Class.forName(Class.java:140)
GUI OutputStream] at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironm ent(GraphicsEnvironment.java:62)
GUI OutputStream] at java.awt.Font.initializeFont(Font.java:309)
GUI OutputStream] at java.awt.Font.<init>(Font.java:345)
GUI OutputStream] at com.sengent.d2ol.node.gui.GUIConstants.<clinit>(Unkno wn Source)
GUI OutputStream] at com.sengent.d2ol.node.gui.GUIController.main(Unknown Source)
OH SNAP! i jsut looked at my term scree and look at this!
does that mean its working? and how do i add my email to it i want some credit for this machin as itt'll be my 24/7 cruncher. also do i jsut make another folder for the second node i want to run?Code:Enter Command or '?' for help>
**> D2OL: Docking Candidate
Analyzing Candidate IBS_STOCK2S-46497 on Target: Anthrax Lethal Factor
Analyzing Conformer #7
Tasks Assigned: 50
Tasks Downloaded: 50
Results to Upload: 0
Completed Candidates: 0
ohhhhhhhhh yea, we got tow working only one question now. :D whe ni do a "ps ux" command, it says shows this.
does this mean that each instans is using xx percent of that givine processor? is there a way to vewi individual processor usage for a givein PID? bascailly i want to make sure im running at capacity. (reminder, non gui commands only) thnx a bunch and you now have 4 more cores of d2ol to get to number 1!! 2 dedicated and 2 will run as i sleep!! SHWEET!Code:the 2592 0.0 0.1 38232 1852 ? S 04:12 0:01 sshd: the@pts/0
the 2593 0.0 0.1 55140 1668 pts/0 Ss 04:12 0:00 -bash
the 3621 0.0 0.1 60732 1212 ? Ss 05:03 0:00 SCREEN
the 3622 0.0 0.1 55136 1684 pts/1 Ss 05:03 0:00 /bin/bash
the 3645 0.0 0.1 53928 1232 pts/1 S+ 05:04 0:00 /bin/sh ./D2OL controller:cli
the 3686 0.2 2.0 288104 21032 pts/1 Sl+ 05:04 0:01 /home/the/fold1/SengentD2OL/D2OL/../jre/bin/java -Xmx134217728 com.zerog.lax.LAX /home/the/fo
the 3720 0.0 0.1 21904 1072 ? S 05:05 0:00 /usr/sbin/vsftpd /etc/vsftpd/vsftpd.conf
the 3847 0.0 0.1 60736 1208 ? Ss 05:09 0:00 SCREEN
the 3848 0.0 0.1 55132 1680 pts/2 Ss 05:09 0:00 /bin/bash
the 3869 0.0 0.1 53924 1236 pts/2 S+ 05:09 0:00 /bin/sh ./D2OL controller:cli
the 3910 0.4 1.9 287136 19540 pts/2 Sl+ 05:09 0:01 /home/the/fold2/SengentD2OL/D2OL/../jre/bin/java -Xmx134217728 com.zerog.lax.LAX /home/the/fo
the 4029 99.1 5.1 55340 52728 pts/2 R+ 05:13 0:42 /home/the/fold2/SengentD2OL/D2OL/res/data/bin/DockWin.exe -p /home/the/fold2/SengentD2OL/D2OL
the 4050 97.5 5.1 55340 52724 pts/1 R+ 05:13 0:17 /home/the/fold1/SengentD2OL/D2OL/res/data/bin/DockWin.exe -p /home/the/fold1/SengentD2OL/D2OL
the 4060 0.0 0.0 54024 960 pts/0 R+ 05:14 0:00 ps ux
why is everyone :slapass: cows
The team at no. 1 call themselves 'Dutch Power Cows', and we're close at getting them :)
ooooh! right, thx!
btw: ive just finished my 26th candidate assignment drug whatever proteine thing :woot:
:up:Quote:
Originally Posted by phelonius
Welcome to the... http://rodzilla.xtremesystems-dc.com/smiles/CowXS.png
Alright, been doing this d2ol for a while now (since we were #11) and have always wondered is there any performance difference between the service installer and the regular sengent installer?? If I was setting up a dedicated cruncher, would the service installer be a better idea?
No difference... I have a XP-M that used to run the service and averaged about 130 a day... now it runs the client and still averages about 130 a day... same deal with a regular XP... 110 with the service.. 110 with the client. That's just my 2 cents.Quote:
Originally Posted by moddolicous
Thanks Shmaa, just wanna hear some other people's experiences here. It looks like my dad's P3 got a huge boost from using the service installer instead of the sengent installer (although it also might have something to do with a new HD and windows install). Anyone else got some input?
It's the same software... just started different.Quote:
One major thing you pickup with the service installers in stability! Run XWD with it and your uptime will be much better. (As XWD watches the services and restarts them if they get stuck)
