Ok thanks, I have a drill, after work I will go grab that hole cutter, and then take measurements for the holes.
How did you guys get that part done? Ex: Process in which you traced the holes, and the drilling holes to mount the rad to the case. I guess thats my biggest concern is how you lined it all up.
