I never regretted doing the L12 mod...
I only know, I once took it out cause OSKAR wanted to test if we still need the L12... and that was horrible. Nothing was stable as before... I had to lower my fsb 20MHz to get a semistable bench!
damn....273 on LP-B....
the hell of Nb cooling you must got there...
yea boblemagnifique that is a really nice oc. what mods have u done to the board? what bios are u using?
Hello
First of all, it is a lan party rev A, seen on the pcb, but it assembles well level fsb, level vmod, there is that the MOD Vdimm (200k) and in full aircooling (120m on the south, 80mm on North and mofset and Slk 800 on Cpu)
The BH5 is between 3.75v and 3.92v but does not change large thing
(Timmings 2/2/2/2/11/9/12/E/E/F/E)
The bios is LanParty 8KA Rev.2 http://hellfire.enclavenet.com/N24LD619-8KA-REV2.zip
倒
到底这块板好不好呀
should i get a lanparty A or B?
There is a marking of rev A on the pcb of the DFI Lanparty Ultra B (NF2U400).... but it only tells ya the revision of the pcb indeed, but the board's still a Lanparty B (B does not mean it's revision B - it's a COMPLETELY different board from Lanparty A -> layout, SATA vs. IDE RAID, ... )
SAE- wuts up man :)
was just wondering what kinda scores ur getting with your current setup (new x800). im guessing around 27-28k??
man I wanna see u get an A64 mobo and tweak the shizzle out of it, like you have done with the LP-B. :)
no doubt in my mind... SAE = nf2 king :worship: :up:
peace out man
FH
Originally Posted by FlyingHamster
Hey, my friend :D
I am not benching at the moment ;) But I totally doubt to get a score like 28k! Been facing some stability probs lately playing NFSU2...
I am gonna get me a 939 sytsem in the beginning of 05. Hope it's affordable! (NF4+PCI-Xpress vid card+cpu should be a lot of bucks)
Thanks for your compliments :D
later, SAE :cool:
lol well I figured since u got 25.8k with your 9800, the x800 would get around 2k more. you underestimate yourself! ;) :p:Quote:
Originally Posted by SAE
gl with the new rig.. looks like its gonna be shweet
Hmm. Yeah, of course it could theoretically hit 27k easily, BUT there's no driver supporting the x800 optimized for dx8.1 :(
That's the problem....
The newer drivers suck bad on 3dm01 IMO.
ok im upping my nb cooling now (threw a 60mm on the stock nb) im making some ramsinks (gah this sucks spend an hour and im not done with 1st 4...need jigsaw or a var speed dremel) tommorow im getting the pots and i have an old video card in the freezer soon to have its passive sink pulled for mosfet cooling...
btw i had this thing running 255*10.5 prime stable stock on air, 260x10.5 almost prime stable, and now your saying 10.5 wasnt that stable... hehe... im getting exited lol, but maybe these ramsinks will be easier to just buy for $20 then spend 20 hours making them lol, im going to have to use two different hsf's by the time im done. (edit - i want ramsinks because this bh5 did 260 3.3v memtest stable before i pulled the spreaders, not even close without them, so i put them back on and still im not stable, hoping that sinks will fix this hehe
Hey Guys, hey SAE (originally Magedburg? My Hometown is Bernburg ;) )
Well, i might have a problem with overclocking my CPU via the Lanparty B...
My Hardware:
Lanparty B / Hellfire Rev3
2x 256 Corsair XMS Rev 1.1 Dual (Slot 1 and 3)
AMD XP-M 2600+
OK, the first i did was to set my timings vor the Ram on 2-2-2-11.
I increased the FSB up to 245 with multi on 9.5
VDimm is 3.3V and Chipset is running on 1.9V. VCore is still on auto...
So, the Problem for me... with this settings its impossible to set the multi to 10... even if i increase the Vcore...
The PC is not starting (blackscreen) or it starts and just before loading WinXP Pro SP2 it's restarting again...and so on.
Well, i'm a bit dissapointed of 2330 MHZ :(
I would be pleased for some hints...
I'm new in this field but hey... at one point i have to start a new hobby!? :D
Thx a lot!
Hi man :DQuote:
Originally Posted by Esox
No, my origins ain't in Magdeburg, but in Berlin :D I am studying in Magdeburg...
According to your problem, I must admit, it could be caused by many things.
1st What cooling are ya using??
2nd Try to do the L12 mods... I can supply you with a pic when I am at home.
3rd try to use the multiplier 11x. then start at 210 and work your way up. :) (I hope your cooling 's great ;))
4th check your die contact, reapply thermal paste and ensure you only put on a veryvery thin layer.
5th Oh, and the main thing I consider a problem, is you set the vcore to auto... not quite a good move! It means the cpu only gets supplied with 1.45V Vcore, so try to set that manually to 1.75V (don't worry, even with aircooling you can use that). Now try again! :D
Good luck, and report back your results please. :thumbsup:
P.S. Welcome to the sickness, pal :D :toast:
Salut!
Thx for the quick reply!
My origin is BBG, but working in Potsdam right now :D
Ok, the cooling:
Watercooled, but maybe not so good (about 50 degree without doing anything)
L12 mod: ??? :rolleyes: :D
3rd: i will check this!
4th: i will check this also. i think my waterblock is crap (aquarius 3)
and 5th: the vcore on auto is on 1.55V... and if i increase it seems not to be really stable (1.7 if i set 1.75 for example)
I look foreward when i'm at home!
Many Thx!
Hmm, Aquarius is a cheapa$$ kit, huh? :DQuote:
L12 mod has the purpose to set default fsb from 133MHz to 166MHz, it gets ya better stability at high fsb and may increase your total possible fsb.
Drop me a pm about it. :)
The Vcore thingy is weird, there has to be a serious problem. Either cpu contact is bad, or cooling's insufficient. (I don't only refer to your cpu cooling, but also to your mosfet cooling and so on...)
Greetz, Stefan
OK!
I'll look for the contact of the CPU and check the heatsink and afterwards look for Vcorestability...
The L12 mod... i found this big thread here, thx :)
I'll come back to your "PM offer" (plz in german :D :D )
cya!
Marcel
Hi!
Ok, i did the L12 Mod. Set Multi to 11 and increased the FSB up to 215. More is not possible with Multi on 11. On the other hand, L12 helped to increase FSB from 245 up to 253 with Multi on 9.5...
Increasing the VCore is also not possible. On Auto it's running on 1.53-1.55 and if i increase to 1.65 for example i have around 1.61... :confused:
Looks like a hell of work to be done :D
Marcel
im using the hellfire rev3 bios so doesnt that mean i dont need to do the L12 mod?
Doing the L12 mods in hardware always gets you some better results IMO ;)
So there's not only the romsip tables modified, but also the cpu.
hrmmm maybe ill try that out..
*goes to look for L12 thread*
50c is way too hot! Heck, i'm running silent air at 2400mhz 1.75v right now and load at 55c with ~28c ambient..
What power supply are you using?
Hi,Quote:
Originally Posted by STEvil
i'm using Thermaltake Butterfly 480W!
should be good enough...
are any of the capacitors near your CPU bent, bulging, or leaking fluid maybe?
